luigi316(at)libero.it Guest
Posted: Wed Nov 01, 2006 8:16 am Post subject: Ground run |
Hi All,
I have just completed the overhaul of my Kitfox II and made first ground run. I have a 582 grey head and a new Ivoprop 68". I set the pitch for 6200 static and putting a dynamometer between the airplane and the truck i have a thrust of 290 lbs. Is this a good value ? I also a doubt on the rpm, i have a change of 200 rpm more in the reading when i switch off the battery. I don't understand the reason as the istrument is connected directly to the engine and ground. I think that before the first flight it'll be better to install a tiny tach.
roncarolnikko(at)hotmail. Guest
Posted: Wed Nov 01, 2006 9:54 pm Post subject: Ground run |
Luigi try to borrow a prop tach from model airplane buddies. You will have
to do the math for the gearbox, but they usually have 2 or 3 blade settings.
Tiny-tach has 3 or 4 models and can be misleading. I used a $30.00 model
airplane photo tach and found a HUGE discrepancy which cured my problems.
Ron NB Ore
| Quote: | From: "luigi" <luigi316(at)libero.it>
To: "kitfox-list" <kitfox-list(at)matronics.com>
Subject: Ground run
Date: Wed, 1 Nov 2006 17:15:26 +0100
Hi All,
Stay in touch with old friends and meet new ones with Windows Live Spaces
http://clk.atdmt.com/MSN/go/msnnkwsp0070000001msn/direct/01/?href=http://spaces.live.com/spacesapi.aspx?wx_action=create&wx_url=/friends.aspx&mkt=en-us
Float Flyr
Posted: Thu Nov 02, 2006 7:09 am Post subject: Ground run |
You certainly need the right tiny tach for your engine. (2 stroke Vs 4
stroke) And you need to follow their instructions for installing/ making the
pickup coil. I covered mine pickup with black electrical tape to make it
look clean. It works like a charm.
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
