Arksey(at)aol.com Guest
Posted: Wed Nov 08, 2006 2:46 pm Post subject: carburetor ice question |
Hello Group,
Has anyone had carburetor ice problems running a 503 rotax? I had to land in a hayfield today, engine was running sporadic, pulled on some enricher and that did not seem to help, could not reach to primer or i would have tried that, kept loosing RPM, engine quit when I throttled back to land. After landing I pulled engine thru and it was not seized up so i checked things over, there seemed to be fuel in the carb. when I pumped the primer bulb so i tried to start engine and it started ran ok and developed full RPM's I checked the mags and took off as I was only about 1 mile from my strip. It ran fine. However I now want to determine what was wrong...The condition's was excellent for carb. icing, but I have not much time on 2 cycle engines and am not familiar with them as pertaining to carb. ice.
Thanks in advance for your imput....and by the way the Kolb handled a wet hay field very good.
firestar ll 503 dual carb and ing.
jim swan MI
planecrazzzy Guest
Posted: Wed Nov 08, 2006 3:26 pm Post subject: Re: carburetor ice question |
I had the same thing happen with my 582 after take-off in my Powered Parachute.... My Dad told me ( later ) that I should have hit the primer...
Somebody's supposed to bring a fist full of cash and haul my PPC away today.... I'll finally have the room to start my next plane ( W-10 )
Gotta Fly...
pj.ladd(at)btinternet.com Guest
Posted: Fri Nov 10, 2006 9:21 am Post subject: carburetor ice question |
Has anyone had carburetor ice problems running a 503 rotax? >>
Hi ,
not too serious. I had it happen a couple of times in my Challenger which with the high wing pusher position is similar to the Kolb.
When the engine coughed I slowly opened the throttle and that kicked the ice on through. Never had to land out becauase of it.
Cheers
Pat
cwolf41(at)comcast.net Guest
Posted: Fri Nov 10, 2006 11:17 am Post subject: carburetor ice question |
On Fri, 10 Nov 2006 17:13:10 -0000, you wrote:
| Quote: | Has anyone had carburetor ice problems running a 503 rotax? >>
I was once flying a powered parachute, at dusk, temperature about 68
degrees, and humidity so high that fog was starting to form. 503 engine
suddenly coughed and died. Couldn't be restarted. I landed unpowered in
the nearest hayfield. No problem. Tried to restart the engine shortly
after landing. Started just fine. Figured I must have had a seizure, so I
opened the engine up. No sign of a seizure anywhere. Figured it must have
been carb ice (most likely explanation).
I solved the problem by buying an electric carb heater (Cyclone) It was an
electrically heated ring of metal that fit around the throat of the carb
air intake, and warmed the metal enough to prevent ice crystals from
sticking. Ran off the 503 electrical output. Never had an another engine
failure. Very nice gadget.
Chris Wolf
