experimental208nd(at)comc Guest
Posted: Fri Nov 10, 2006 7:48 pm Post subject: Rough Running 912 UL Fixed! |
Hi List,
Well I think it is fixed. I only tried one thing at a time to narrow down the results and the culprit. Someone sugested moving the c-clip down a notch to enrichen the carbs as it might be starving in the middle range. I did it to both by moving the clip to the 3rd groove. I wanted to make sure I was not going to make it too lean so I ran the plane for a half hour at diff speeds.
The EGTS only got up to 1,250 deg F at 4200 RPMS for about 5 min. CHTS stayed at 180 deg F. 63 deg F OAT.
It ran so much Smoother on start up and it was like glass trough all rpm ranges, even quick trottle adjustments up and down.It was great! I only did the clips , and have not changed the plugs yet so It seems to be the clip adjustment that helped.
Question is I have NEVER Had to move it before in summer or dead of winter, So WHY now??????
I did also do the methanol test of my gas with the water and it tested out to have 10% methanol in it! Maybe that is the reason why I now needed to adjust it as there was not that much over the summer?
I will report back with the test fight next week hopfully.
Thanks to all that helped,
Jay Fabian
ddsyverson(at)comcast.net Guest
Posted: Sat Nov 11, 2006 5:17 am Post subject: Rough Running 912 UL Fixed! |
Jay,
If you found that enrichning the mixture solved the problem, AND, you know
that you currently have 10% alcohol (methanol according to your test) fuel,
there is a theoretical and logical explanation as to why you now need to
enrichen the mixture now, but did not need to at some time in the past. The
reason I say "theoretical" is because we don't have an analysis of the fuel
you were using before the engine began running rough - that part may be a
guess at this point.
Consider the chemistry involved with burning gas versus alcohol.
I provided some if this information in an earlier post when we were discussing
corn gas on the list (ethanol added to gasoline). Alcohol has less energy per
gallon than gasoline. Ethanol has approximately 60% of the energy that
gasoline has - this means that if a person burns pure gasoline and compares
it to burning pure ethanol, it will work like this (disregarding the factors
of octane rating and a couple other minor things): If you get 20 nautical
miles per gallon on pure gas, you will get 12 nautical miles per gallon on
pure ethanol. - Again, this does not take into account a few other minor
factors, but it is ballpark for government work. Taking the logic a bit
further - this means you need to enrichen the mixture for ethanol so you can
now burn an additional 8 gallons in the same distance IF you are running 100%
ethanol compared to 100% gasoline. Actually, we do not burn 100% ethanol
(maybe in cars in Brazil), but the need to enrichen the mixture due to
additional of alcohol is exactly porportional to the amount of alcohol used
to dilute the gasoline. Gasoline with 10% ethanol has approximately 94% of
the energy as 100% gasoline - so the mixture needs to be enrichened to
account for the missing 6% energy content.
NOW - you mentioned that your current fuel was actually 10% methanol, not 10%
ethanol - if this is the case, methanol has LESS energy yet per gallon than
ethanol so the 10% dilution would cause a somewhat greater reduction in BTU
content than if the 10% was ethanol - not a lot, but some. This is due to the
shorter chain structure of methanol (less carbon, less haydrogen=less
energy).
Science trivia - Back during the first energy crisis in the US (the second
also + during the runup in gas prices this summer) there were all kinds of
snake oil guys coming out of the woodwork. Some claimed a 200 MPG carburetor
for a 6000# vehicle was buried in some sort of conspiracy between the
government and auto companies. This little crock of bull is easily debunked
since it takes a defined quantity of gasoline to do a defined amount of work
and there just isn't enough energy in a gallon of gas to push a 6000# vehicle
200 miles. I actually have seen a 200 MPG carburetor - it is on a very, very
tiny radio controlled car which can actually carry four passengers, provided
the passengers are four hummingbirds. My point of this is the big picture
(energy needed versus gallons burned) is subject to the laws of chemistry and
physics and these big picture items will sometimes provide us with answers to
the puzzling things we observe.
Aside from all this chemistry stuff - give yourself a pat on the back for
solving your original issue with the rough running; but keep your eyes and
ears working. The only other thing I will mention is this - if it actually is
not a difference in fuel, don't forget the possibility that some other
problem may have it's solution manifest through enrichment (such as a vacuum
leak, induction air temperature to name a few) Engine systems have several
factors which affect the ideal mixture for smooth running - sometimes one
change masks another issue. Or, you might have the problem solved and it
might be that simple.
Please conside that my experience has been more involved with auto
applications than aircraft engines. Some things transfer and some things
don't; But, basic chemistry and physics doesn't distinguish what vehicle an
engine is mounted on.
Sincerely,
Dave S
St Paul, MN
DO NOT ARCHIVE
On Friday 10 November 2006 9:47 pm, Jay Fabian wrote:
| Quote: | Hi List,
Fox5flyer Guest
Posted: Sat Nov 11, 2006 7:26 am Post subject: Rough Running 912 UL Fixed! |
Great primer Dave. Thanks.
Deke
