Paul Valovich
Posted: Mon Nov 13, 2006 8:16 am Post subject: 5702-75-060 Washer |
Monday morning – can’t get through to Vans. Have hung the tail and am now connecting the elevator push rods on my -8A QB. Drawing 25 shows F-840 and F-839 connecting to the aft stick wiedement WD-412A. However, for the aft connection only, the drawing specifies two 5702-75-060 washers.
What the hell is a 5702-75-060 washer? I checked the hardware sections of the both the Standard Aircraft Handbook and AC 43.13-1B and couldn’t find it.
Paul Valovich
Ridgecrest, CA
n616tb(at)btsapps.com Guest
Posted: Mon Nov 13, 2006 8:28 am Post subject: 5702-75-060 Washer |
Hi Paul,
I think they were the small outside diameter washers that I used to put next to the bearings. They are only as big around as the bearing surface so they don’t cause any clamping of the bearing. None came in my kit (-6) but I ordered some from Van’s.
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Valovich, Paul
Sent: Monday, November 13, 2006 8:15 AM
To: rv-list(at)matronics.com
Subject: 5702-75-060 Washer
Paul Valovich
Ridgecrest, CA | Quote: | | www.aeroelectric.com | 0123456789012345
jabowenjr(at)hotmail.com Guest
Posted: Mon Nov 13, 2006 8:39 am Post subject: 5702-75-060 Washer |
I use the inventory list as a guide sometimes.
Jim
RV-8
| Quote: | From: "Valovich, Paul" <pvalovich(at)dcscorp.com>
Reply-To: rv-list(at)matronics.com
To: <rv-list(at)matronics.com>
Date: Mon, 13 Nov 2006 11:15:17 -0500
Monday morning - can't get through to Vans. Have hung the tail and am
washers.
of the both the Standard Aircraft Handbook and AC 43.13-1B and couldn't
find it.
Paul Valovich
Ridgecrest, CA
Live Search!
Dale Ensing
Posted: Tue Nov 14, 2006 6:26 am Post subject: 5702-75-060 Washer |
They have a small OD and are used for spacing between the rod-end "ball" and the fork to allow the rod-end room to rotate on the ball without binding on the fork.
_________________ Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
