jusplanefun(at)juno.com Guest
Posted: Wed Nov 22, 2006 7:47 am Post subject: rudder horn-vixen |
I am about ready to cover my fuselage on a series 5 vixen. While I was getting measurements where the rudder cables will come through the fabric to attach to the rudder, I noticed that there will be alot of contact between the cables and the fabric, and also the rudder itself. In my manuals table of contents under fuselage assembly, there is a reference to page 86 which is titled rudder horn modification. This page is missing from my manual. I was wondering if someone has found a good solution to this situation, or if was unique to my plane. If anyone has a modification to the rudder horn that has worked well, I would appreciate any information I could get from them and a picture would be great. Thanks for the info! Chris. [quote][b]
dosmythe(at)cox.net Guest
Posted: Wed Nov 22, 2006 9:42 am Post subject: rudder horn-vixen |
Chris,
I'm not sure what the rudder horn modification was but, you might check the below link for rudder cable fairings. The cable fits through these little fairings (on the outside of the fuselage) and are cemented to the fabric after the holes are cut. They help cover the hole and provide a little aerodynamic design. I assume you are talking about the cable rubbing the fabric at the hole location and not down the length of the fuselage??? I built the Classic IV and the cable doesn't come anywhere near the fabric except at the hole.
http://www.aircraftspruce.com/catalog/appages/ccfairings.php
Don Smythe
Posted: Wed Nov 22, 2006 10:53 am Post subject: rudder horn-vixen |
I have not thought of moving the cables with pulleys, but I will look at that option. Don, the cables actually will be on the fabric for about 4". This is caused by the cable and the fabric being on just about the same angle at the exit point.Then when the rudder is at max throw, the opposite direction cable is pulled hard against the front of the rudder. Thank to all for the replies! chris [quote][b]
Tom Jones
Posted: Wed Nov 22, 2006 3:03 pm Post subject: Re: rudder horn-vixen |
Chris, here is a service bullitin about Vixen cable guides. Could your guides be in the wrong location causing the cable to rub?
Tom Jones
SERVICE LETTER #36
DATE: August 22, 1994
SUBJECT: Cable Guides
APPLICABILITY: Series 5 Aircraft through S/N S9407xxxx; Vixens through S/N V9407xxxx
COMPLIANCE: As required
FROM: SkyStar Aircraft Product Development Department
Some Series 5 fuselage weldments have been shipped that had the aft rudder cable guides welded to the inside of the fuselage tubing instead of the outside. Inspect your fuselage to ensure that your cable guides were properly positioned. If you find that your guides were mis-located, contact Customer Service at (Old defunct Skystar phone number). We have developed a simple retrofit kit that allows you to install cable guides in the correct location without having to do any welding; request P/N 10435.000.
