gerf(at)gerf.com Guest
Posted: Thu Nov 30, 2006 11:04 am Post subject: Torqueing AN-818 flare fittings |
I've found the torque limits table in AC43.13 for setting the
torque on AN818 flare nuts. There are 2 section one for
aluminum tubing and one for steel.
Lets take the example of the oil lines from the oil cooler to
the engine in the RV-9 firewall forward kit. They supply
aluminum 45 degree pipe-to-flare fittings for the oil cooler
and what I think are steel hoses to connect to the engine.
Where the hose connects to the 45 degree fitting on the oil
cooler should I use the chart for aluminum or steel ?
Similarly my firewall bulkhead fittings for the fuel lines are
aluminum, but the ends of the Stratoflex hoses are steel -
which torque chart governs - the alum or steel ?
(I just know someone is going to say "Change all the alum
fittings for steel ones and use the steel table" :-/)
__g__
Gerry Filby gerf(at)gerf.com
brianpublic2(at)starband. Guest
Posted: Thu Nov 30, 2006 11:58 am Post subject: Torqueing AN-818 flare fittings |
In my opinion (and practice) you want to torque to the lower of the 2
possible values when you have mixed steel and aluminum. This is because one
of the 2 halves of the nut/fitting has aluminum threads, and you don't want
to overstress them by using steel torque values
Example - steel nuts on Teflon oil lines, aluminum oil cooler thermostat:
http://brian76.mystarband.net/engineOct06.htm#oct31
brian
RV-7A working on Eggenfellner engine & related components
http://brian76.mystarband.net/RV-7Ahome.htm
