n616tb(at)btsapps.com Guest
Posted: Wed Nov 29, 2006 7:49 pm Post subject: Auto Pilot adjustment |
Hi Listers,
When I installed the servo for my auto pilot (trio), I thought I had
neutralized the stick and the servo. When I activate the unit during flight
the stick is moved to the left more than I would let it go. I realize now
that I need to adjust the rod, but how does one get the stick in a neutral
(as in flight) position? Is this going to be a trial and error situation?
For those that have done this, how is the best way to get the servo
connected. I would like to think I can engage it in level flight with the
heading set to my current heading and it will not try to turn me right away?
I at least think it should not more bank me more than a degree or two for
variation in the heading.
Thanks for any help
ronlee(at)pcisys.net Guest
Posted: Wed Nov 29, 2006 8:09 pm Post subject: Auto Pilot adjustment |
ON THE GROUND.... secure the ailerons in the neutral position.
Make any non-powered adjustments and follow the Trio instructions.
Verify proper sensing of the servo (reverse or normal). See the
instructions. I know that it is genetically hard to do but sometimes
overcoming milenia of not reading instructions can be helpful.
Ron Lee
Posted: Wed Nov 29, 2006 8:24 pm Post subject: Auto Pilot adjustment |
The main part of the question Ron was about where is neutral to a degree
accurate enough to set it in this position. I know where neutral is when
flying, but don't know how to mark that for after I land.
Thanks for your comments; I did read the manual however. Maybe a reread is
in order.
[quote] --
Posted: Wed Nov 29, 2006 8:43 pm Post subject: Auto Pilot adjustment |
OK, I admit after re reading the trio instructions, all the info is there.
Thanks for setting me straight.
[quote] --
seiders(at)bellsouth.net Guest
Posted: Thu Nov 30, 2006 6:11 am Post subject: Auto Pilot adjustment |
Tim, as I recall if you set the servo arm to the desired position it
will be stick neutral. What I found is that my trio does not work
well with a Bendix GPS (89B). Trio told me there might be a problem
with that gps so took their advice and use the course setting vs. gps.
GPS , in my case causes ap to hunt for the signal which creates a
wandering from left to right, and back. Course setting works
perfectly, and you can adjust 1 degree at a time to allow for wind
diection effect. I have used course settings on 200 mile legs and
made only several adjustments depending on winds.
Dick RV6A
At 10:48 PM 11/29/2006, you wrote:
Hi Listers,
Thanks for any help
