rexjan(at)bigpond.com Guest
Posted: Thu Nov 30, 2006 9:08 pm Post subject: Failure Point |
Where did it fail ?
The carry throguh tube would be one of the weakest links.
Rod ends would be the next weakest link I think. If you look at the Avids
they do not use rod ends.
Dave
Dave,
I'm only going on memory here so please no one take it for gospel but I seem to remember the weakest link is the rod end but also here in Australia anyway we have Skyfox's that are rough copies of Kitfox's. These are apparently failing at the carry through tube and there is an AD out for that. I understand they have a weaker tube, maybe wall thickness not sure !
Also took my interest to read the Avid does not use rod ends. What do they do ? I assume just a bolt ! Is it in shear ?
I think that loading the wing to failure point is on a video copied by Grant Fluent on this list. I guess anyone that wants a copy could first check with Grant that this is on the Video then buy a copy from him. I remember his price was extremely reasonable and there was a lot of interesting stuff on the DVD copy like loops and rolls in a Kitfox.
Rex.
dave
Posted: Fri Dec 01, 2006 3:23 am Post subject: Failure Point |
Hi Rex,
I have a Model IV with rods ends, I have seen earlier Kitfox models without rod ends and the end of strut just like the avid strut. I would guess that the rod end was used to make accommodate for wing adjustment to allow to a less precision wing build ?
I found this on the carry through tube issue on the Skyfox http://www.auf.asn.au/airworthiness/an956issue3x.doc
I have yet to see the same on Kitfoxes. Has there been any reported rod end or carry through failures ?
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
wliles(at)bayou.com Guest
Posted: Sat Dec 02, 2006 11:29 am Post subject: Failure Point |
Avid's, at least from the B model on, use one large size rod end on the
rear strut of the left wing to allow trimming. No other rod ends are
used in the wing or tail struts. Bolts in shear take the loads. Kitfox
had some problems with rod ends failing in tail struts and finally went
to beefier rod ends or simple struts for the tail. Using straight
struts in the Avid left little room for error but resulted in a stronger
wing and tail.
Jerry Liles
Rex Shaw wrote:
| Quote: | Where did it fail ?
Avids
Dave
Dave,
Rex.
lcfitt(at)sbcglobal.net Guest
Posted: Sat Dec 02, 2006 2:34 pm Post subject: Failure Point |
Jerry,
Interesting.
I still have the 3/16 rod ends on the foreward horizontal stab strut and it
is part of my preflight check.
Regarding stronger wings. I wonder if this is a plus, as the Kifox design
with more "room for error" is a proven design as there have been no
structural failures. If after about 15 years of uneventful use, would there
be a reason to change the design?
Lowell
dave
Posted: Sat Dec 02, 2006 2:48 pm Post subject: Failure Point |
Lowell,
I agree on the horiz stab rod ends being ok. I think alot of the problem
might have been from the pilot pulling on it rather than the grab handle ?
As far as the wings, I agree they seem strong but the idea for 2 rod ends
on the strut if probably to make up for builing errors if any as well as
adjustment. . I have not heard of them coming apart but I have broken them
on other applications. They are tiny compared to GA aircraft. That being
said, has ther ever been an in flight breakup of a Kitfox ?
Dave
Lynn Matteson
Posted: Sat Dec 02, 2006 2:58 pm Post subject: Failure Point |
I bought the 1/4" threaded stud inserts to fit those forward hort. stab
struts, and welded them in, fitted the 1/4" rod ends and have had no
problems in over 200 hrs of flight, and like Lowell, check them prior
to, and after each day of flying.
Lynn
On Saturday, December 2, 2006, at 05:33 PM, Lowell Fitt wrote:
Jerry,
Interesting.
and it is part of my preflight check.
design with more "room for error" is a proven design as there have
been no structural failures. If after about 15 years of uneventful
use, would there be a reason to change the design?
Lowell
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
pwmac(at)sisna.com Guest
Posted: Sat Dec 02, 2006 4:30 pm Post subject: Failure Point |
Yes there have been failure on teh horizontal strut. Don't know how
many but the archives had the info.
The construction Skystar used was a #10x32 socket head cap screw
welded in the end of the 3/8"x0.020" tube. Not an aircraft method but
a short cut to avoid buying the correct AN490(?) tube end
fitting. As shocking as it is surprisingly only a few failed.
probably due to excess heat on the hardened cap screw.
BTW, there is no way improper handling could break a #10x30 cap screw
-For sure.
Most of us that did the mod to the AN part used 1/4x28 AN part and
plug welded it as well as seam welded it to the end of the tube. The
cost to do the upgrade is minimal - just the AN tube end and the
appropriate rod end. My welder charged me $10 after I prepped the
parts. Shortening the rod is required to get the same length as before.
Its very wise to keep checking for the failure.
Regards, Paul
At 02:33 PM 12/2/2006, you wrote:
Jerry,
Interesting.
Lowell
jimcarriere
Posted: Sat Dec 02, 2006 4:31 pm Post subject: Re: Failure Point |
My 7 uses 3/8" rod ends at each end of the wing struts. That is, the long threaded part of the rod is 3/8x24 (UNF), that attaches to the strut. The ball has a 1/4" hole, a 1/4" bolt attaches that to a bracket (and the bracket is attached to the wing spar).
Those rod ends are pretty substantial...
Jim in NW FL
Series 7 in progress
_________________ Jim in NW FL
Kitfox Series 7 in progress
Rotec R2800 |
dosmythe(at)cox.net Guest
Posted: Sat Dec 02, 2006 4:59 pm Post subject: Failure Point |
Just a thought, once the horizontal stabilizers are adjusted for proper
flight why not replace the horizontal struts with "fixed" units. That is,
replace with tubing with crimped ends and no rod ends to break.
Don Smythe
dave
Posted: Sat Dec 02, 2006 5:29 pm Post subject: Failure Point |
Never!
And the horizontal strut faillures were discovered post flight.
I dare say that if we went through the design we could find lots of stuff
that just doesn't "look" right. I think of the Rans with their construction
methods, a take off from the ultralight design. Lots of brackets and bolts
holding things together and their new stamped aluminum wing ribs - flimsy
compared to the Kitfox design. Maybe the Kitfox is overdesigned and heavy
as a reslult, but I like the history. I have been in some pretty heavy
stuff, once in a flight of six flying over the Sawtooth Mountains of Idaho
on our way to Smiley Creek - elev 7200 ft. - we did a quick 180 because we
got tired of our heads banging on the skylight. Once in the middle of Nevada
one of the guys inadvertently flew through a dust devil - no visible dust -
and had a real ride, but other than having his headset knocked off his head
and a good case of the shakes, no harm done.
Lowell
dave
Posted: Sat Dec 02, 2006 6:23 pm Post subject: Failure Point |
Good to know Lowell. I too like the design of the Kitfox and have found it
a easy adaptable airplane to fly.
What happened on the horiz stab issue ? Were they broken from tugging on
them ?
As far as heavy , I think that any plane can get heavy in a hurry from all
the add on as well as engine choices.
In my opinion the Kitfox is one of the best on the market if not the best.
Not to mention best bang for the buck on the used market. I am lost to
understand whatd folks like about Challenger, Beavers and Chinnook planes
but they are very popular and some really hold the mkt value for some reason
that I will never understand.
I think if a guy bought up 1 mil $ worth of used Kitfoxes that he could see
at least 50% return over the next few years and if not he would have a nice
collection of toys.
Dave
Posted: Sat Dec 02, 2006 6:27 pm Post subject: Failure Point |
While it never caused a crash that I'm aware of there were just too many
incidents of failure of the horizontal stab rod ends to call it ok. I
recall one incident a few years ago related by a member of the Kitfox
list of having to wrestle his airplane back home as it suddenly wanted
to descend and turn and he could not figure out why until someone on the
list suggested he inspect the horizontal stab. If the forces had been a
bit greater the stab might have twisted or fluttered and made the plane
uncontrollable or stressed the rear rod end to failure. That might have
hurt. As for the rod ends on the wings they seem to be trouble free and
adequately strong and make it easier to correct any minor
misalignments, certainly more so than on an Avid, though I had no
problem with mine.
dave wrote:
Lowell,
problem might have been from the pilot pulling on it rather than the
grab handle ?
ends on the strut if probably to make up for builing errors if any as
well as adjustment. . I have not heard of them coming apart but I
have broken them on other applications. They are tiny compared to GA
aircraft. That being said, has ther ever been an in flight breakup of
a Kitfox ?
Dave
Float Flyr
Posted: Sat Dec 02, 2006 8:10 pm Post subject: Failure Point |
Dave:
Not hard to see the interest in the Challenger and its clones. Lots of
unobstructed view and a very light engine. Capable on floats. Very fast to
build. Just watch their video on low and slow flying.... You can do the
same in the 'Fox but they won't tell you that. The easily removable doors
are great for aerial photography.
I looked at the Challenger quite closely. What I liked was above. What I
didn't like was the blind riveted cluster fish plate joints. I don't think
they even used Cherry max rivets on them. (I could be wrong as those joints
are made at the factory) I feel safer with 4130 in the frame than extruded
aluminium where I can easily see it. I also didn't like the idea of being
stuck with tricycle only landing gear. In the kitfox there is still the
tricycle option.
The real selling point for me was the wing folding feature of the Kitfox.
I can unfold mine in less time than it takes to tell you how to do it. The
plane goes back into my garage after every flight. I fly floats so I like
the idea of the bologna slicer being out front as far away from the spray as
possible. I also like the idea of a 4130 welded frame! Side by side
seating to me is another plus but I also liked flying the Super Cub that has
tandem seating. I find pre-flight and post-flight inspections are easy to
do on the Kitfox as the whole front cowl is quickly removed and access even
to the back of the instrument panel is easy.
Weather here is rarely hot so I installed a gas shock on my door to hold it
up during flight.....effect is fabulas. Landing on floats with the door
open is at this stage beyond my ability to adequately describe. That one
you will have to try for your self. It's a bit like your first solo.
The end result is personal preference. Both are good planes (the Challenger
by reputation). I think the Kitfox and Avid (which one is the clone?) are
stronger and better in the harsh environment I live. If there is a fault
with the Kitfox it has to be I get nervous when someone who has never been
around a plane before offers me help launching or retrieving the plane. It
would be much worse with the Challenger.
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Posted: Sun Dec 03, 2006 4:29 am Post subject: Failure Point |
I have this mod on my list of things to do. Just remove one rod (with rod
end) at a time. pre-drill the fuselage end and attach new rod. Put a tick
mark down through the hole in the stab where you want the new rod drilled.
I think that should be as close as you need it.
Don Smythe.
dave
Posted: Sun Dec 03, 2006 5:17 am Post subject: Failure Point |
Don, I would like it keep the option for adjustment and the Rod ends seem to
serve well.
Would your modification be considered a airframe modification?
Dave
Posted: Sun Dec 03, 2006 6:11 am Post subject: Failure Point |
I would think that once they are set to length, they should not ever need
changing. However, I believe you mention changing to floats and this might
require a seasonal change?? If I remember correctly, the rod ends on the
stabs are 3/16" where every other rod end on my Fox is 1/4" or bigger. I
also seem to remember that Fox's sold overseas required the stab rod ends to
be upgraded to 1/4". There has been a couple cases where the rod ends were
found broken after a flight. Regardless whether they broke due to flight or
rough ground handling, I think a good field fix might be in order.
I don't know if this type mod would be considered an airframe mod or not
but probably would. So, that is another question. I'd say, you can do the
mod, log it and forget it??? If you have a case where winter/summer lengths
are different, make two sets. This is probably not a major concern but is
always on my preflight check list to wiggle all four rods. I've had my
plane moved many times by other hanger mates and you never know what they
might do in moving your plane.
Don Smythe
Posted: Sun Dec 03, 2006 9:32 am Post subject: Failure Point |
Jerry,
Apples and oranges here. The failure with wrestle had to do with the jack
screw in the larger models that trimmed the horizontal stabilizer. That is
what failed. It had nothing to do with the struts, though it is agreed that
the larger models the struts had been beefed up and possibly with the use of
accepted AN fittings.
I remember two - maybe more of the rod ends - rather the stud going into the
rod ends - failing and it was discovered on the ground after a flight. I
don't recall if there was a "feeling" in flight, but it definitely was not a
wrestle. There was an upgrade offered, but I couldn't find a Service Letter
or Bulletin on the issue.
Lowell
Posted: Sun Dec 03, 2006 4:48 pm Post subject: Failure Point |
Testing my memory but didn't they offer the aero tubing and 1/4x28
rod ends. The
up grade was very expensive.
Paul
At 09:29 AM 12/3/2006, you wrote:
Jerry,
the jack screw in the larger models that trimmed the horizontal
stabilizer. That is what failed. It had nothing to do with the
struts, though it is agreed that the larger models the struts had
been beefed up and possibly with the use of accepted AN fittings.
into the rod ends - failing and it was discovered on the ground
after a flight. I don't recall if there was a "feeling" in flight,
but it definitely was not a wrestle. There was an upgrade offered,
but I couldn't find a Service Letter or Bulletin on the issue.
Lowell
Posted: Sun Dec 03, 2006 5:01 pm Post subject: Failure Point |
Lowell
There was an incident of tail strut failure in flight with difficulty
maintaining steady level flight that was reported to this list. This was
a Model 4, not a Model 5 with the jackscrew trim system. The
correspondent couldn't figure out what had happened until someone (might
have been me) asked him to inspect the tail lift struts. My point is
failures have occurred for whatever reason and may well occur again.
This is a type of failure that is survivable but is potentially
disasterous. Kitfox (Skystar) finally upgraded the struts to larger
rodend fittings. My feeling is the small rod end fittings on Model 4
are a known point of failure,whether from improper ground handling,
improper assembly, or stress of flight, with potential for disaster and
I would replace them.
Back then the list manager had a reguarly updated message called "Kitfox
Safe" where all the problems and potential problems and how to handle
them were listed. Unfortunately I have a relatively new computer and I
do not have a copy of Kitfox Safe. Perhaps someone else saved a copy?
Jerry Liles
Lowell Fitt wrote:
Jerry,
struts, though it is agreed that the larger models the struts had been
into the rod ends - failing and it was discovered on the ground after
a flight. I don't recall if there was a "feeling" in flight, but it
definitely was not a wrestle. There was an upgrade offered, but I
Lowell
