colindu
Joined: 14 Nov 2006 Posts: 1 Location: Sydney - Australia
Posted: Thu Dec 07, 2006 9:49 pm Post subject: Tank Sloshing |
Hi Folks,
I'm about to fabric the wings on our KFIV, so before I do, I'd like to know what the latest reccomendation is for sloshing the tanks, especially with regard to the advent of ethanol. Non-ethanol fuel is standard here, but I'm sure it will develop into an issue sooner rather than later, so I really want to make the right choice now.
Any words of wisdom will be most welcome.
Colin Durey
Sydney
_________________ Colin Durey
Sydney
+61-418-677073 |
Posted: Thu Dec 07, 2006 10:31 pm Post subject: Tank Sloshing |
Hi Colin,
Answers vary and it seems all have a point of truth to
them. One thing I haven't heard on the list though is
that aluminum parts don't handle well the corrosion
caused by water held by ethenol. My alum carb pits
from it and I think aluminum fuel lines may develop
leaks too.
I know that if you use electrical tape to "protect" an
alum line, it will corrode under the tape. I suspect
we will hear of corroded lines in the future from this
new fuel too.
I used an alchohol resistant slosh for my tanks. So
far, so good.
Kurt S. S-5
--- colindu <colin(at)ptcsg.com> wrote:
| Quote: | Hi Folks,
Colin Durey
Sydney
Have a burning question?
Go to www.Answers.yahoo.com and get answers from real people who know.
lcfitt(at)sbcglobal.net Guest
Posted: Fri Dec 08, 2006 7:35 am Post subject: Tank Sloshing |
List
I have been running some tests on the alcohol issue. The result is
preliminary, as it has only been going on since October 1.
FYI, the purpose of the testing is to find a coating for a balsa wood float
used in a low fuel sensor.
The test consists of a series of test tubes with floats coated with various
coatings and separated from the glass walls of the test tubes with a guide
wire. The guide wire prevents surface tension - floats against the glass
from masking the floats
ability to sink in the event it loses buoyancy.
This is the set-up:
Two floats coated with vinyl ester resin.
Two floats coated with vinyl ester resin that had been mixed in a plastic
cup attacked by the resin to see if the cup somehow degraded the resin.
Two floats coated with Kreem
One float coated with a fuel tank sealer from JC Whitney
One of each float is submerged in our version of California pump fuel which
I have measured as containing 6-7% ethanol. One of each float is submerged
in 97% ethanol (denatured alcohol). The Lone JC Whitney coated float is in
mogas.
For the first two weeks, on a daily basis, I took the floats up to a virtual
14,000 ft in a
bell jar to simulate flying to altitude to see if the coatings were breaking
down and allowing the floats to de-gas. since then the altitude test has
been conducted about weekly.
The result of the tests so far is as follows.
Early on, one of the Kreem coated floats degassed under vacuum suggesting a
breach of the coating. The air bubble was large - 1/16" and was on the end
of the float. Past experience suggests that if the coating fails large
bubbles from
the float interior will appear on the surface.
After 30 days, I removed the vinyl ester coated floats from the 97% ethanol
and mogas for observation. The submersion had dulled the surface from it's
original shiny appearance on both floats. The surface looked etched. When
returned to the test tube, They resumed their normal floating
condition. When I took the floats to the 14,000 ft. altitude, both floats
began to degass with what seemed to be thousands of microscopic, very
difficult to see bubbles. I saw no difference in the two mixes of resin.
To date, all Kreem coated floats have retained their luster in both the
mogas and the alcohol.
Since the early bubble seen on one Kreem Float, no evidence of coating
breach has been seen on any of the floats when taken to the 14,000 ft.
pressure in the vacuum chamber.
Discussion:
When brushing on the coating, it is more difficult to get full coverage with
Kreem if there is any oughness or pitting as was sometimes found on the end
grain balsa. This may be due to the very rapid evaporation of the MEK
thinner.
Fuel tank coating, I suspect would be more effective as it is a closed
system and the
MEK would be in a saturated environment and evaporation would be minimal
until the tank is vented. The surface of the Kreem retained it's luster and
is intact
and with the exception of one faulty coating, Kreem seems to have worked
well
to date.
The "Gas Tank Sealant" from JC Whitney has reacted identically to the Kreem.
The only difference between the two so far is that Kreem is a little
yellower in color
out of the can while the JC Whitney product is snow white,
With the loss of surface luster, I concluded that the vinyl ester resin had
been attacked by the alcohol (fuel) in both solutions and portions had been
dissolved. I am not a chemist, but I think when the resin cures it does
not result in a homogeneous solid, but is more like a sponge with areas of
hard resin with interspersed pockets of a more vulnerable material. I think
the softer material dissolved out into the alcohol / fuel. Then when dried,
air diffused into the porous surface and degassed as the pressure in the
bell jar was reduced. Vinyl ester resins are mixed similarly to polyester
resins with the use of MEKP and proportioned to determine curing times.
Small areas of roughness from the brush application were present indicating
that the resin was not being dissolved en masse.
| Quote: | From this and past list discussions, my present conclusion is if you can get
the Kreem to stick and fill all the pinholes it is a good surface
preparation for alcohol resistence.
Lowell
Guy Buchanan
Posted: Fri Dec 08, 2006 8:45 am Post subject: Tank Sloshing |
At 07:34 AM 12/8/2006, you wrote:
| Quote: | I have been running some tests on the alcohol issue. The result is
Good work Lowell! Thanks for doing this. No help to me now, but it will be
in the archives when I want it. Thanks again.
Guy Buchanan
Deceased K-IV 1200
A glider pilot too. |
colind
Joined: 10 Jan 2006 Posts: 32 Location: Sydney, Australia
Posted: Sun Dec 10, 2006 4:18 am Post subject: Tank Sloshing |
Lowell,
Thank you very much for the detailed response. I'll go with either the
Kreem or the JC Whitnbey product. I'm not sure who handles these products
in Australia, but will investigate. Once again, thanks for your help.
Regads
Colin Durey
Sydney
Lowell Fitt said:
List
float
various
This is the set-up:
which
submerged
in
mogas.
virtual
14,000 ft in a
breaking
a
end
bubbles from
ethanol
it's
When
Discussion:
with
end
thinner.
system and the
and
is intact
well
to date.
Kreem.
yellower in color
had
been
think
dried,
indicating
> get
Lowell
Sydney
+61-418-677073 |
Michel
Posted: Sun Dec 10, 2006 6:50 am Post subject: Tank Sloshing |
On Dec 10, 2006, at 1:17 PM, Colin Durey wrote:
| Quote: | Thank you very much for the detailed response.
Isn't Lowell a great guy? You see, at this very moment, the Jabiru list
argue about all the stuff that should, or should not be done after the
last service bulletin concerning the flywheel. Everybody gives his
opinion and it's very confusing. Lowell doesn't give his opinion about
tank sloshing, he gets to work and come with some neat results. Facts!
That's great!
Cheers,
Michel
