CJohnston(at)popsound.com Guest
Posted: Sun Dec 10, 2006 10:39 am Post subject: tough or impossible floor pan rivets? |
hey all -
how has anyone handled the forward most outboard rivet on the F-1016C L/R floors? i'm installing them, and i can't for the life of me see how to get either a pop rivet or a driven rivet in there. very curious. help!
cj
#40410
fuse
www.perfectlygoodairplane.net
ron.mcgann(at)baesystems. Guest
Posted: Sun Dec 10, 2006 1:40 pm Post subject: tough or impossible floor pan rivets? |
G'day CJ,
I installed machine screws/nuts/washers in those locations.
cheers,
Ron
187 finishing
armywrights(at)adelphia.n Guest
Posted: Sun Dec 10, 2006 2:46 pm Post subject: tough or impossible floor pan rivets? |
Unless you're planning on some pretty heavy pressure on that specific point
it'll do just as well to leave it out as mangle the pan and structure to get
a hole in there. There seem to be enough rivets (and mechanical pressure)
holding the pan in place to worry on this one. It really just holds the pan
there, no load bearing and no structural integrity. As always Van's could
clue you in on the real engineering.
Rob
#392
Access Covers
LarryRosen
Posted: Mon Dec 11, 2006 1:39 am Post subject: tough or impossible floor pan rivets? |
Here is one from the archives.
Good Luck
Hope yours comes out better than my mangled pop rivets.
Larry #356
This is bit of an old issue, but I recently won the battle against the
"impossible rivets" on the rear seat pans and I thought I would share my
method.
The forward-most hole is the problem because the front seat support gets
in the way. I managed to set a solid rivet in these holes, but it took
some trial and error. I ended up using a 12" piece of steel angle, with
a hole drilled in one end to accept a 1/8" cupped set (I had to do some
grinding on the end of the steel piece to get it to work out). I placed
the cupped set on the rivet and blocked the aft end of the steel piece
from the side panel with a piece of wood. Then I used a mushroom set in
my rivet gun, placed it on the piece of steel as close to the rivet as
possible and hammered away. I cranked up the PSI on the gun a bit. I
used different pieces of wood to support the steel piece while I riveted
to keep from scratching the floor and side panel aluminum.
As a bucking bar for all the floor pan rivets along the left and right
sides of the fuselage, I used the long RV-10 bucking bar with a 2x4
block taped in the middle (this gives you leverage against the outside
skin for holding pressure on the back side of the rivets). It takes some
adjusting of the size of the block, but once you get it right you can
get through those rivets quickly. You might want to support the outside
skin with something to keep it from denting as you're pushing on it.
Send me an email if you want to see a picture of the rivet set up.
Jim McGrew
RV-10 #134 - Just starting to wire fuse
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
Posted: Mon Dec 11, 2006 9:02 am Post subject: tough or impossible floor pan rivets? |
Larry Rosen wrote:
Good Luck
Larry #356
my method.
Gives a new meaning to perseverance! I've not seen where the rivet(s)
are, so pardon the question. What's so important about this particular
hole that it HAS to be filled???? Just asking.
Linn
n223rv(at)wolflakeairport Guest
Posted: Mon Dec 11, 2006 11:21 am Post subject: tough or impossible floor pan rivets? |
I left mine open for better ventilation in the foot well area.....
-Mike
