rexjan(at)bigpond.com Guest
Posted: Wed Dec 06, 2006 4:57 pm Post subject: Rotax 582 plugs |
Subject: Spark Plug Gap
Can anyone tell me the proper spark plug for a Rotax 582?
Frank
Hi ! Frank,
The Rotax recomended plug is NGK B8ES for the grey head and BR8ES for the Blue head. The "R" is for resistor. Really you should not use resistor plugs with resistor caps although I think Rotax did it with the blue head 582. Generally use resistor either in the plug or the cap but not both to help with ignition noise in the radio. A resistor plug and resistor cap have been used together for persistent cases of interference and if you really need both I guess you can use both but personally I wouldn't. The high [ typically 5K + 5K = 10K ] resistance increases the voltage build up before the plug fires. This might have a slight advantage re firing under some conditions although offset by the lower firing current, however the higher voltage is more likely to lead to a CDI [ Capacitive Discharge Ignition ] failure. Generally you will get a better spark the lower the resistance.
Sometimes you will see Rotax distributors listing the plug as a number rather than B8ES etc. This is mainly to just get you to buy from them, however there is another suttle difference. The little screw on cap. This can be brass, aluminium, fixed or with the right caps you just use the thread. My choice out of all this is the resistor plug with a non resistor cap with just the thread being used. My reasoning is using just the thread makes it more secure and you don't have issues with the aluminium caps or the caps coming lose. I also prefer the resistor in the plug rather than the cap because it can and does fail. If it's in the plug you are changing it when you change plugs and the extra cost of a resistor plug is minimal.
To complicate it a bit though I'm now going to tell you that I use NGK BR8EIX plugs. These are Iridium and used in inverted motors. The reason being is they stand up to the harder conditions like fouling etc. As you can see the BR8E part is the same the IX is for "I" fine Iridium centre electrode. "X" Booster gap [ "S" standard centre electrode.] Now I haven't checked but I'm not sure if you can get this plug with the screw on cap so you can use just the thread. I am using fixed cap plugs at the moment but will change if I can shortly. These plugs are working really well for me with non resistor caps. You can get whatever caps you need from an auto parts store.
Rotax recommended gap setting is 16 to 20 thou. I set mine to 20 thou. This raises another point if you use the Iridium plugs. The packet says not to adjust the gap and from memory it's set about 30 thou. Not a good idea for our application. However you can adjust the gap just be very carefull not to stress the very fine iridium centre electrode especially by pulling a feeler gauge across it and putting side pressure one it that's all.
Rex.
dave
Posted: Wed Dec 06, 2006 5:21 pm Post subject: Rotax 582 plugs |
Rex,
I have a few things to add. when you buy BR8ES or B8ES from a Rotax dealer they will most likely have solid tips and not screw on tips. Screw on tips are bad news as they are softer than the llittle clip inside those 5k ohm cap which is steel.
Also they come pre gapped about .016 to 020 so adjust will be minimal wheras bought form other place I have seen them .030 or larger gap. That take a good bend to adjust gap.
I have asked several Rotax dealers about the iridiums and they say no gain to be had but a owners choice. I have just shy of 100 hours on my plugs now in my Blue head since July and still running fine and I checked about 5 hours ago and they had minimal deposits on them and looked good. I use only regular gas and bombardier XPS mineral oil.
Now the gray head uses ducati igntion as well but the older ones had points and in that case you are correct to use B8ES and 5k resistor caps but not resistor plugs and caps on point ignition. I have had Blue heads and gray heads and performance wise they about the same.
I would suggest that Solid tip plugs from rotax is the best choice. The plug caps can and will fall off other wise. Some will safety wire , tiewrap etc but why not just use the proper plug ?
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
dosmythe(at)cox.net Guest
Posted: Wed Dec 06, 2006 6:01 pm Post subject: Rotax 582 plugs |
I was not aware that the NGK BR/B8 plugs came with anything other than the standard screw on top. These are standard out of the box plugs for many applications. Are you saying that Rotax modifies these standard plugs for Rotax use or does NGK produce a plug that is modified for aircraft use? I'm confused? I've always used the standard (auto parts store) NGK plugs however, I perform a minor adjustment to the screw on top. I "stake" the cap lightly with a cold chisel to secure it to the threads. I also use a different little method to close the .030 gap to .016.
Don Smythe
dave
Posted: Wed Dec 06, 2006 6:34 pm Post subject: Rotax 582 plugs |
Ok Don, I did a quick search on Google and found some info here
http://www.rotaxservice.com/rotax_tips/rotax_feed2.htm
Hope this helps , Dave
Spark Plugs
The recommended spark plugs are the NGK B8ES or BR8ES. The "R" denotes a resistance which helps suppress radio interference. The use of spark plugs with a solid tip, rather than the screwed-on tip, is mandatory. The latter can unscrew itself in flight and dislodge the spark plug connector cap, creating an ignition failure.
Spark plug gap - Allowable range: 0.4-0.5mm / .016-.020"
- Optimal: 0.45mm / .018"
- The gap can be reduced to its allowable minimum to help starting in very cold conditions
To be avoided: - Other spark plug models and other manufacturers' equivalents
- Screwed-on tips
- Unverified spark plug gaps
More here . scroll to bottom http://www.ultralightnews.ca/articles/resistorcapsandplugs.htm
Also here
http://www.auf.asn.au/airworthiness/rotax_447_plugs.pdf
dave
Guy Buchanan
Posted: Wed Dec 06, 2006 9:16 pm Post subject: Rotax 582 plugs |
At 11:25 AM 12/7/2006, you wrote:
| Quote: | Generally use resistor either in the plug or the cap but not both to help
How do I check whether I have resistor caps or not? Is it simply 5k ohms
between the plug and wire contacts? I guess I therefore have to remove the
caps from the wires. Is there anything special I should do to put them back
together, such as conductive grease, etc.?
Guy Buchanan
Deceased K-IV 1200
A glider pilot too. |
dave
Posted: Thu Dec 07, 2006 3:38 am Post subject: Rotax 582 plugs |
Guy, Yes, just unscrew the cap and check with ohm meter.
Dave
Posted: Thu Dec 07, 2006 4:44 am Post subject: Rotax 582 plugs |
Ok, I read it and it seems to contradict itself because I have to go back to my original question. Where can you purchase an NGK BR8ES spark plug that has a solid tip. I just went quickly to the NGK site and can't find a reference to a solid tip plug The author of the article said basically, you "MUST" use NGK BR8ES/B8ES plugs and you must NOT use screw on tips. Where did he buy them?
The other article you sent allowed screw on tips but said to crimp/peen/glue the screw on caps.
Don Smythe
dave
Posted: Thu Dec 07, 2006 5:43 am Post subject: Rotax 582 plugs |
Don, I buy all plugs from Rotax distributor. I am not exactly sure why it is like this
I would suggest Bob Robertson as I have used him with excellent service.
Down south any Rotax shop will have them I am sure.
I found this picon this site http://www.ngksparkplugs.com/images/profile/Ngk104-0.jpg
Shows a solid tip.
Now if you like i can go out to shop and take some pics for you later ? Let me know . I might have some screw tips that have damage tips worn as I have decribed. ?
Dave
Also the first one is from a another quality Rotax Shop in Canada and he says same
- Screwed-on tips
- Unverified spark plug gaps <<
eskflyer(at)lvcisp.com Guest
Posted: Thu Dec 07, 2006 6:27 am Post subject: Rotax 582 plugs |
Don the NGK stock # B8ES solid cap plugs is #3683
#BR8ES solid cap #3961
These are NGK'S stock number give it to any parts store and they will be able to order them then .
John Perry
Posted: Thu Dec 07, 2006 6:42 am Post subject: Rotax 582 plugs |
Dave,
I guess we are never too old to learn something new. I've done some web searching and do find references to "aviation" type (solid tip) NGK plugs (even a statement from NGK). Another interesting thing I ran across was a statement by NGK that stated "NONE" of their plugs are recommended for aviation use. About half of what you read on things like this are "liability" statements from different manufactures.
When I was building, I went into a business that sold nylon webbing. I had an idea of fabricating my own seat belts. When I mentioned airplane, the store salesman "actually" refused to sell me the webbing.
I've always used the standard auto store NGK's but do crimp the caps to the threads. Another thing that I discussed with a Rotax Center (name unmentioned) was proper gapping of the plugs out of the box. If you bend an electrode from .030" to .018" you don't get a good parallel gap. I started placing the plug in a vice and very gently tapping the electrode at a 45 degree angle. This helped the gapping to give a better parallel fit. As I said, I discussed this with a very well know Rotax Center and we agreed it was a possible good approach?????
Don Smythe
Posted: Thu Dec 07, 2006 7:12 am Post subject: Rotax 582 plugs |
John,
Thanks, that clears this up for me. I went to the NGK web site and sure enough, your numbers pulled up a plug that said "SOLID" behind the plug number. Good information. Learn something new every day. Who said this list didn't produce good information. Sorry Dave, I was about to doubt you.
Don Smythe
dave
Posted: Thu Dec 07, 2006 8:27 am Post subject: Rotax 582 plugs |
Don, No problem.
I took a pic today , not the best but you can clearly see the flat side on alum screw tip here http://www.cfisher.com/ngk.html
Hope this helps you all and What site do you see the NGK number working at ? I just buy from Rotax with other orders.
Dave
aerocontrols(at)clearwave Guest
Posted: Thu Dec 07, 2006 8:29 am Post subject: Rotax 582 plugs |
Hi Don, Guy and Dave.
The solid core plugs listed on NGK's web site are strictly automotive plugs.
They are markey on each box "not for Aircraft use" via the standard icon.
They come from the factory gapped at .0035. they are very hard to re-gap to
.018 as the ground tab will extend well past the electrode when re-gapped to
.018-.020".
Plug ground tbs should be parallel to the electrode, not simply bent down so
that one side is gapped correctly.
We tried these plugs and found them to be really hard to gap properly.
The plugs you get from your Rotax Service Centers/Repair Stations are
pre-gapped to .018". The ground tab is a bit shorter on these than the
automotibe plugs so the eng of the ground tab
is adjacent to the edge of the electrode when it is set parallel and at
.018/.020"
Gosh, I hope this made sense..... The automotive plugs gapped by simply
tapping down the ground tab so it is only .018 away from the electrode will
not last near as long as the "aircraft plugs (897-055).
Just my two cents.
BTW....You can hit up your supplier for a better price if you order in bulk.
(Dave does...8^)
regards
Bob Robertson
Light Engine Services Ltd.
Aero Control Enterprises, Inc.
St. Albert, Ab. T8N 1M8
Ph: (Tech Support) 1-780-418-4164
Ph: (Order Line) 1-866-418-4164 (TOLL FREE)
www.rtx-av-engines.ca
www.aerocontrols.net
dave
Posted: Thu Dec 07, 2006 9:17 am Post subject: Rotax 582 plugs |
Bob, Take a peek at this pic i took this am
I have seen this time and time again with those screw top plugs.
I will be calling you soon for some Carb sockets for abunch of 582's here
Posted: Thu Dec 07, 2006 12:29 pm Post subject: Rotax 582 plugs |
Hello Bob,
OK, you're right, I'm confused. The above was posted this morning
giving the NGK plug numbers. I checked their web site and they are listed
as "solid" cap I guess. Are you saying the above are for auto use only and
not aircraft. Are you also saying that NGK sells a special aircraft plug
that is gapped at .018 and can be bought through Rotax Centers? I remember
talking to you years ago about tapping down those .030 plugs to .018. This
is the first time I've ever heard of an NGK plug that is for aircraft only.
Help me out here I need to get some plugs soon.
Don Smythe
dwight purdy
Posted: Thu Dec 07, 2006 2:20 pm Post subject: Rotax 582 plugs |
Don
I had them looked up at the local auto store. I will look and get the number off the box and get back with you. If your order your plugs from CPS , they will be the solid tips.
Dwight
At 07:43 AM 12/7/2006 -0500, you wrote:
[quote] Ok, I read it and it seems to contradict itself because I have to go back to my original question. Where can you purchase an NGK BR8ES spark plug that has a solid tip. I just went quickly to the NGK site and can't find a reference to a solid tip plug The author of the article said basically, you "MUST" use NGK BR8ES/B8ES plugs and you must NOT use screw on tips. Where did he buy them?
Don Smythe
_________________ dwight
model II |
Posted: Thu Dec 07, 2006 3:10 pm Post subject: Rotax 582 plugs |
Sorry, I'm still out to lunch on this subject. According to Bob Robertson the solid core plugs are automotive only. You say CPS will deliver solid tips. Solid tips/solid core plugs (same or different). This also doesn't address the plug gaps that are delivered with pre-set .018" or .030." The .030" are difficult to set properly. If there is an NGK BR8ES plug that comes with solid tips and pre-gapped to .018" then that's the plug I think I want.
I'll be happy when this confusion on my part is settled.
Don Smythe
dave
Posted: Thu Dec 07, 2006 3:26 pm Post subject: Rotax 582 plugs |
Don , I just read the postd from Bob again.
<Hi Don, Guy and Dave.
.018-.020".
I just order from Bob and he send what I need but surely any Rotax dealer would have them and he also gave you a part number ( rotax number)
And Like I said earlier I am almost at 100 hours on mine in 582 since July and it running fine. ( I am being stubborn here but it will make 100 easy )
Dave
