tinnemaha(at)hotmail.com Guest
Posted: Sun Dec 17, 2006 7:41 am Post subject: Trim Mount Bolt - Rudder Cable Interference |
I just completed a series 5 taildragger with Lycoming. The DAR who
inspected my airplane the other day (I have my airworthiness certificate
now!) made what I consider to be a very good catch. May or may not apply to
others here. The right rudder cable was rubbing against the nut end of the
bolt that mounts the trim motor to the fuselage. He told me to turn the
bolt around to eliminate the interference. I did what he said & the
interference is now gone. THANK YOU, Mr D.A.R.!
Although I'm very glad he caught that, I don't really know what to make of
this. On the one hand, I feel like he might have saved my life, but on the
other hand there are probably hundreds of Kitfoxes that have been flying for
years with this same condition [I checked the plans & the way it was
originally (cable rubbing on bolt) was per the skystar instructions for both
Series 5 & Series 6.]
Did I miss a service bulletin, or is this a non-issue?
Sorry if this is a worn out topic: I couldn't find anything in the archives,
but maybe I didn't use the right search string.
Grant Krueger
Stay up-to-date with your friends through the Windows Live Spaces friends
list.
lcfitt(at)sbcglobal.net Guest
Posted: Sun Dec 17, 2006 8:30 am Post subject: Trim Mount Bolt - Rudder Cable Interference |
Grant,
Congratulations on the Certificate and the good eyes of the DAR.
This brings to mind the data base I have collected on the flying Kitfoxes.
I will add you to the list and anyone else out there not on the list yet,
drop a note. Other data on the list is exact engine designation, third
wheel configuration, location and anything else particular to your airplane.
Also I would suggest that anyone building drop a note also as there is
plenty of room in the spreadsheet. It's just nice to see what we all are
doing.
Lowell
smokey_bear_40220(at)yaho Guest
Posted: Tue Dec 19, 2006 11:15 am Post subject: Trim Mount Bolt - Rudder Cable Interference |
There actually are a lot of those little got-shus on
the KitFox. The plans catch most, but not all and you
can miss one and just put a bolt in backwards and have
a problem. It could take years to show up or show up
quickly.
The flight control linkage under the seat is an
example. Bolts are supposed to be installed pointing
down in case the nut falls off. But there is one that
will hit the structure if not installed pointing up.
In fact, it has to have a thin head to clear.
Another is in the elevator push tube in back of the
seat. Needs to be installed so it doesn't hit an
upright tube.
I was once, and only once, yelled at for writing up a
bolt installed backwards on a DC-8 nose gear link.
Delayed the flight and cost over $100,000. The plane
had flown that way before, so I was wrong.... until
the maintenance manager returned with the pages that
described that it would break off the "down and
locked" switch, if it was in backwards. Just hadn't
broken the switch before I caught it.
I put pipe clamp bands on 4 of my engine hoses to keep
them from wearing against other parts. Just things
you have to look for and "what if" as you build.
So you are not alone and it is not just our Fox's.
Kurt S.
--- Tinne maha <tinnemaha(at)hotmail.com> wrote:
| Quote: | Hi Lowell,
I don't know whether to rate this as a major or
minor concern. At first I
thought it was major & I guess it still could be.
However, as I haven't
found any evidence of there being a previous
discussion on the topic, I
would deduce most kitfoxes are flying this way (&
have been for years), so
it obviously isn't a problem. Did you deal with
this on your airplane?
Grant
