renewhall2(at)yahoo.com Guest
Posted: Fri Dec 08, 2006 9:08 am Post subject: Colorado CFI for RV7 available |
I would like to offer my CFI services (and airplane)
to the list for RV7 transition training in Colorado.
I am located at Longmont, CO (KLMO). My airplane is
an RV7 with an O360 Lycoming with a constant speed
prop. The rate is $140 per hour Hobbs (includes the
airplane, fuel, instructor, and any ground
instruction).
Bob Newhall, CFI, Airplane & Glider
303-819-1482 cell
Cheap talk?
skydive80020(at)yahoo.com Guest
Posted: Fri Dec 08, 2006 10:34 am Post subject: Colorado CFI for RV7 available |
Having done recurrency with Bob in his aircraft I can vouch for his capabilities, he does a great job and you will be well prepared to fly your RV.
Mark Phipps, N242RP, Gypsy Spirit
"Robert E. Newhall II" <renewhall2(at)yahoo.com> wrote:
[quote]--> RV-List message posted by: "Robert E. Newhall II"
instruction).
303-819-1482 cell
Cheap [quote][b]
dan(at)rvproject.com Guest
Posted: Sat Dec 09, 2006 2:06 am Post subject: Colorado CFI for RV7 available |
I almost hesitate to mention this, but I'm curious how you get around the "No person may operate this aircraft for carrying persons or property for compensation or hire" clause in the operating limitations?
)_( Dan
RV-7 N714D
http://www.rvproject.com
cjensen(at)dts9000.com Guest
Posted: Sat Dec 09, 2006 5:09 am Post subject: Colorado CFI for RV7 available |
He charges $10/hr to split the gas and $130/hr for his CFI time? He is for hire, not the plane? There're a lot more tortured machinations that occur with regulations than that interpretation. But the arrangement seems like a safe, effective and reasonably economical way to encourage and enhance pilot training so, I would have to think the FAA would be against it.
Chuck Jensen
ronlee(at)pcisys.net Guest
Posted: Sat Dec 09, 2006 7:35 am Post subject: Colorado CFI for RV7 available |
| Quote: | | I almost hesitate to mention this, but I'm curious how you get around the "No person may operate this aircraft for carrying persons or property for compensation or hire" clause in the operating limitations? |
Does the FAA care about SAFETY? If so, what is safer than getting someone
proficient in an aircraft before they make a first flight? Given that safety is
#1, any rule that works against it is not worth complying with.
Ron Lee [quote][b]
billshook2000(at)yahoo.co Guest
Posted: Sat Dec 09, 2006 7:49 am Post subject: Colorado CFI for RV7 available |
Nothing is ever a legal problem until something goes wrong. Say the engine fails and
the paying customer gets hurt in the crash landing....a lawyer would have a field day
with the CFI in court. If you ever see a lawyer walk into a courtroom smiling from ear
to ear..chances are there is someone at the other table using this type of logic. I
hope he is very well insured. That being said, thank god for the CFI's willing to do
this.
Bill
| Quote: | He charges $10/hr to split the gas and $130/hr for his CFI time? He is
against it.
Chuck Jensen
khorton01(at)rogers.com Guest
Posted: Sat Dec 09, 2006 8:12 am Post subject: Colorado CFI for RV7 available |
The EAA, Small Aircraft Manufacturers Association and the National
Association of Flight Instructors petitioned the FAA for an exemption
to the FARs to allow flight training in experimental aircraft. Their
request was granted via exemption 7162, which is currently at
revision 7162D. There are numerous conditions which must be complied
with:
1. The aircraft must-
(a) Have been granted an experimental certificate
under Section 21.191(c), (d), (g), or (h);
(b) Be inspected in accordance with the provisions of
Section 91.409(b) for a 100-hour condition
inspection, or, for turbine-powered aircraft, in
accordance with an FAA-approved inspection program
that meets the scope and detail of the
requirements of Section 91.409(e), (f)(4), and
(g);
(c) Be operated and maintained, including a yearly
condition inspection, in accordance with the
FAA-approved operating limitations; and
(d) Have completed phase I flight testing and be
operating in phase II in accordance with the
operating limitations made a part of the
airworthiness certificate issued for the aircraft.
2. All inspections conducted under this exemption must be
recorded in an appropriate maintenance record with the
following statement:
"I certify that this aircraft has been inspected
on (insert date) in accordance with Condition
No. 1 of Exemption No. 7162, as amended, and found
to be in a condition for safe operation."
This entry must include the aircraft total time in
service and the name, signature, certificate number,
and type of certificate held by the person performing
the inspection. Only an FAA-certificated mechanic with
airframe and powerplant ratings or an FAA-certificated
repairman (provided the repairman is the original
builder of the aircraft) may perform this inspection
and make the entry in the maintenance record.
3. Aircraft-specific training under this exemption must be
provided by an authorized instructor as described in
Section 61.1(b)(2) or the holder of a Letter of
Operational Authority issued by the Administrator for
that particular type of aircraft.
4. An aircraft-specific flight and ground training
syllabus must be prepared by the instructor providing
the training for use during the training program and
must be made available to the Administrator upon
request. The instructor conducting the training
program must keep, for a period of 3 years, a record of
the training given.
5. The owners of aircraft operated under this exemption
must maintain a record that includes the name of the
person receiving training, the date of the training,
and the flight time. Such records must be kept for a
period of 3 years and be made available to the
Administrator upon request.
6. Persons receiving aircraft-specific flight instruction
must have the endorsements required by Section 61.31(e)
through (j), as appropriate, before beginning training
under this exemption.
7. A copy of this exemption must be carried onboard the
aircraft during aircraft-specific flight training
conducted under this exemption.
8. EAA, SAMA, and NAFI must maintain a list of the
authorized users of this exemption. This list must be
made available to the Administrator upon request, and
must contain the following information:
(a) The name, address, and pilot certificate number of
the user; and
(b) The make, model, and registration number of the
aircraft to be used.
You can find FAR exemptions at:
http://aes.faa.gov/
Kevin Horton
On 9 Dec 2006, at 08:07, Chuck Jensen wrote:
[quote] He charges $10/hr to split the gas and $130/hr for his CFI time?
Chuck Jensen
lamar(at)takeflighttexas. Guest
Posted: Sat Dec 09, 2006 5:02 pm Post subject: Colorado CFI for RV7 available |
thanks for answsering this question. There was an article in sport aviation
about a cfi in florida doing float and twin training in his experimental. I
hope to be able to provide transition training in my plane using this
exception. Im going to try to do instrument and preliminary commercial
training too. Im not sure if I can yet but when i get to that point, ill do
more research. If i recall correctly, the exemption is good for anything but
primary training. I really dont want to start a big long debate, so lets
leave it at that.
Lamar
N969LS
lm4(at)juno.com Guest
Posted: Sun Dec 10, 2006 7:36 am Post subject: Colorado CFI for RV7 available |
I could be wrong---,but, I believe I heard that the FAA had written papers to mitigate this regulation for one or a few CFI,s training in sixes.
Larry Mac Donald
lm4(at)juno.com (lm4(at)juno.com)
Rochester N.Y.
On Sat, 09 Dec 2006 08:32:43 -0700 Ron Lee <ronlee(at)pcisys.net (ronlee(at)pcisys.net)> writes:
[quote] | Quote: | | I almost hesitate to mention this, but I'm curious how you get around the "No person may operate this aircraft for carrying persons or property for compensation or hire" clause in the operating limitations? |
pcowper(at)webtv.net (Pet Guest
Posted: Sun Dec 10, 2006 1:58 pm Post subject: Colorado CFI for RV7 available |
". . . a lawyer would have a field day"
No, a greedy loved one who hired that lawyer to represent them. Lawyers
can't start lawsuits on their own, their clients are the ones who decide
to sue someone.
Pete Cowper
RV-8 #81139
Posted: Mon Dec 11, 2006 4:35 pm Post subject: Colorado CFI for RV7 available |
The FAA only allows rental of an experimental for
transition training and flight reviews. The CFI/owner
needs to apply for an exemption through EAA. You can
read about it and obtain the exemption here:
http://www.eaa.org/communications/eaanews/pr/010706_faaexemption.html
Bob
RV7, N829RV
303-819-1482 cell
