piavis(at)comcast.net Guest
Posted: Mon Dec 11, 2006 2:39 pm Post subject: Z-13 v. SD-8 distribution Diagrams |
I’m in the process of wiring up the SB005-1 (S704-1?) relay with the SD-8 volt regulator and the OVM. The SD-8 distribution diagram (Dwg 504-500 rev E, 9/29/04) seems to differ from the Z-13 diagram and I’m wondering which to follow. Dwg. 504-500 refers to the relay as SB005-1, and elsewhere, it looks like the part number is S704-1. I’m not sure if these are one in the same or not.
The photo at http://www.bandc.biz/S704-1_tips.html is even different and includes an additional diode installed where the OVM-14 should be installed.
Anyone have a good diagram or guidance on which drawing is correct? I’m thinking that Z-13 may be the correct drawing for the application.
Jim
-7 Wiring
nuckollsr(at)cox.net Guest
Posted: Wed Dec 13, 2006 10:16 am Post subject: Z-13 v. SD-8 distribution Diagrams |
At 02:38 PM 12/11/2006 -0800, you wrote:
Quote: | I m in the process of wiring up the SB005-1 (S704-1?) relay with the SD-8
E, 9/29/04) seems to differ from the Z-13 diagram and I m wondering which
looks like the part number is S704-1. I m not sure if these are one in the
same or not.
The photo at
<http://www.bandc.biz/S704-1_tips.html>http://www.bandc.biz/S704-1_tips.html
Anyone have a good diagram or guidance on which drawing is correct? I m
Both are.
The S704-1 and similar relays (like eggs, flour and milk)
are used in a variety of recipes and each recipe may treat
that ingredient in a manner that is not consistent elsewhere.
When you're baking a cake, you don't take a handful of recipes
from multiple sources and then attempt to resolve differences
between them. When someone publishes a recipe, you need
to know if it's from a credible source and if the recipe is
a demonstrated pathway to success. If those conditions are
satisfied, then run with it.
