Michel
Posted: Sun Dec 17, 2006 11:52 pm Post subject: Stall speed noise |
Hello everyone,
Saturday I wrote a question to the list. Unfortunately, trying to copy someone else's style, I wrote it in the "Dear Abby" style, something that wasn't appreciated by the list moderator. I apologized for that but my question still remains unanswered and it worries me because if none of you experience a certain noise when the plane starts a stall, then ... something could be wrong with my plane.
So, please, if any of you know the reason why I can hear a distinct sound that reminds of fabric tearing as my model 3 stalls, I'd appreciate it. Could it be that, as the air becomes turbulent around the wing, that a part of the fabric flaps like a whip on the fuel tank? Thanks in advance.
Michel
Lynn Matteson
Posted: Mon Dec 18, 2006 3:43 am Post subject: Stall speed noise |
I haven't experienced that, Michel. Mine just goes straight over at
stall. I have my fabric poly-brushed firmly to the tanks wherever it
happened to touch, which is probably 60-70% of the area.
Lynn
On Dec 18, 2006, at 2:52 AM, Michel Verheughe wrote:
| Quote: | Hello everyone,
plane.
Michel
www.aeroelectric.com">www.aeroelectric.com</a>
www.buildersbooks.com">www.buildersbooks.com</a>
www.kitlog.com">www.kitlog.com</a>
www.homebuilthelp.com">www.homebuilthelp.com</a>
www.matronics.com/contribution</a>
List">http://www.matronics.com/Navigator?Kitfox-List</a>
</b></font></pre>
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
experimental208nd(at)comc Guest
Posted: Mon Dec 18, 2006 1:47 pm Post subject: Stall speed noise |
Same here, I have the ribs and tank tops pollybrushed too, and rib stitched.
No sound on stall either,( except my heart beating !
jay
Michel
Posted: Mon Dec 18, 2006 2:02 pm Post subject: Stall speed noise |
On Dec 18, 2006, at 12:43 PM, Lynn Matteson wrote:
| Quote: | I haven't experienced that, Michel. Mine just goes straight over at
Thanks Lynn. It is the same with my plane and my guess was only ... a
guess. I can be anything else. You see, I remember, when I started
flying, that someone told me that I would know when I am about to stall
because the plane will give me a signal. I think someone even mentioned
something about the fabric. So, I never worried about it, thinking:
That's my signal.
But after a few touch and go, last Saturday, flying slow and "landing
in the sky" just to keep with the feeling of the plane - as I was told
I should do from time to time, I started wondering where the sound came
from.
Then I asked the question to the list, not in a worried but a humorous
way. But now, I understand that it is not as usual as I thought it was.
Never mind, I'll ask a passenger to fly with me and, without the
headset, to listen to find the direction of that sound. I am not even
sure at all it comes from the wings.
Cheers,
Michel
lcfitt(at)sbcglobal.net Guest
Posted: Mon Dec 18, 2006 4:21 pm Post subject: Stall speed noise |
Michel,
I didn't respond earlier because I didn't know exactly what to say. I did
go flying for a bit this afternoon - a severe clear day after almost three
weeks of rain. I did the deed and did some stalls. I didn't hear anything,
but do have noise cancelling headsets and turn my hearing aids to mode III
which connects them to the voice coils in the headsets electro magnetically
rather than through the microphones. Still, their was no noticable noise.
Lowell
MichaelGibbs(at)cox.net Guest
Posted: Mon Dec 18, 2006 5:47 pm Post subject: Stall speed noise |
Michel sez:
| Quote: | ...if any of you know the reason why I can hear a distinct sound
it.
I'm sorry Michel, I thought you were kidding around. I never heard
such a sound in my Model IV and I stalled and spun it many times. I
think you are probably right, a careful inspection of the fabric on
the wings is in order. I wouldn't limit the inspection to the fuel
tanks, though, check the entire upper and lower surfaces to be safe.
Mike G.
N728KF
henrysfork1(at)msn.com Guest
Posted: Mon Dec 18, 2006 7:23 pm Post subject: Stall speed noise |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Is it possible the fabric is separating from the cap stips on the ribs or the tubing on the air frame???
Dee Young
N345DY
Posted: Mon Dec 18, 2006 7:43 pm Post subject: Stall speed noise |
Hi Michel,
I agree with Mike G. You need to do a careful
inspection and look for fabric seperating from a rib
or tank surface on the top. I expect that this is
hard to find since the fabric tension will hold it
down until you get enough lift on the spot.
Any inspection ideas for this from the list?
Michel, is your fabric stitched to the ribs?
Do take someone up with you and do the stall as
quietly as you can, power wise and headsets off, to
find it. Then stop doing stalls!
A very famous pilot named Steve Whitman lost his life
when his fabric seperated enough to cause flutter in
his wing. You don't want it to come loose!
Than again, sound testing in flight, you may find that
it is not in the wing and something else is bothering
you for attention. The baggage sack or other velcroed
part?
The normal indications for stall are shuttering in the
flight controls or entire plane, a flapping sound from
the wind seperating, control response way down (except
in a Fox) the rear window shuttering, that sudden
feeling that the bottom is just about to drop out.....
probably some others I am forgetting. But there
should be no tearing sound.
Our planes will tell us when they are hurting. We
just need to learn to listen and know what they are
saying.
Kurt S. S-5
--- Michael Gibbs <MichaelGibbs(at)cox.net> wrote:
| Quote: | Michel sez:
distinct sound
>it.
I never heard
it many times. I
of the fabric on
Mike G.
N728KF
kitfox(at)ida.net Guest
Posted: Mon Dec 18, 2006 8:52 pm Post subject: Stall speed noise |
You could use a suction cup of the right strength to pull up on the fabric.
Could it be air coming in a place not normally in the stream except just at
stall?
Albert Smith
temco(at)telusplanet.net Guest
Posted: Mon Dec 18, 2006 11:13 pm Post subject: Stall speed noise |
Michel
Are your wings rib stitched?? If not then perhaps you have fabric separation
at some location. Just a thought
Ted
Do NOT ARCHIVR
Michel
Posted: Tue Dec 19, 2006 2:50 am Post subject: Stall speed noise |
Thank you guys, it looks like this is not normal, after all.
I don't know if my wings are rib stiched. How can I check? My plane was built between 1991 and 1993 by a excellent builder - it was his second Kitfox - and according to the specifications of that time.
The first time I heard that sound was the first time I stalled the plane, nearly three years ago. I assumed it was "the signal" people were talking about. Now I understand it needs further investigation. I'll keep you informed, of course. Thanks for your answers.
Cheers,
Michel
Michel
Posted: Tue Dec 19, 2006 3:11 am Post subject: Stall speed noise |
| Quote: | From: kurt schrader [smokey_bear_40220(at)yahoo.com]
the wind seperating
That might be it, Kurt. How do you describe "a flapping sound from the wind separating?" Here is a description of what I hear:
I once had the tail of my seat belt hanging outside the door (I am rather skinny and the belt is long). As soon as I started the engine, I could hear the belt flapping on the fuselage.
Now, what I hear when stalling is about the same noise but only one flap. And I am not even sure it happens at every stall. I haven't been thinking much about it before now.
In fact, as I flew alone last Saturday, I was thinking: Whenever I fly with a friend, I can explain that an aircraft doesn't fall out of the sky like a brick if the engine stops or we go in a gentle stall. The intention then was to say: "Whenever you hear this warning sound, push the stick forward and you'll stay in control." Then I came to think that I should ask the list what is the physical cause of the sound.
Cheers,
Michel
PS: I suppose we all experience the same thing but when I ask passengers if he/she wants to steer the plane, they have usually no problem holding the stick. It is when I ask them to coordinate a turn with the pedals that things get ugly!
dosmythe(at)cox.net Guest
Posted: Tue Dec 19, 2006 3:48 am Post subject: Stall speed noise |
Michel,
You should easily be able to see the small lump of each rib lace under
the 2" tapes. Should be about 3 or so inches apart.
Don Smythe
Posted: Tue Dec 19, 2006 5:35 am Post subject: Stall speed noise |
--- Michel Verheughe <michel(at)online.no> wrote:
| Quote: | That might be it, Kurt. How do you describe "a
Cheers,
Michel
Michel,
Mine sounds like a big flag flapping just once in the
wind. Not a fabric tearing sound, but a "FWOUMP" as
the air reattaches to the wing. When I hear it, the
plane is in recovery from already stalled. Too late
to stop the stall, but soon enough to recover in a few
feet. If I hold it in the stall, the sound happens
each time the plane rocks forward and is flying
again....FWOUMP....FWOUMP....FWOUMP seconds apart.
I am wondering about your turtledeck...... It could
make noise from the air behind the wing (top of
cockpit) where the air over the rest of the wing has
nothing behind it to feel the air. Make sure your
turtledeck is firmly attached and the window is too.
It could simply be the air beating the turtledeck,
since the center of the wing should stall first. That
would be a pre-stall, or partial stall warning and
more normal. Like I said, the rear window can rumble,
or make some noise as the stall starts in the center.
| Quote: | PS: I suppose we all experience the same thing but
You should try helicopters! Talk about ugly! Luckily
you can stop a helo and just get ugly in one place.
Like first week music lessons...
My first time hovering I was told to stay over a rock.
Wild ride! then I was told to stay in this large
field. Smooth as glass. Good lesson. Watch the
world and don't get bogged down in the details. Big
picture wins.
Kurt S. S-5 Strato-various (cloud buster)
kerrjohna(at)comcast.net Guest
Posted: Tue Dec 19, 2006 7:11 am Post subject: Stall speed noise |
Could one follow each rib cap strip with a shop vacuum to see if there was any latent separation with out it becoming destructive testing?
John Kerr
From: kurt schrader <smokey_bear_40220(at)yahoo.com>
| Quote: | --> Kitfox-List message posted by: kurt schrader
Hi Michel,
> ; when his fabric seperated enough to cause flutter in
| Quote: | his wing. You don't want it to come loose!
part?
saying.
Kurt S. S-5
--- Michael Gibbs wrote:
> ; > Your L
&g [quote][b]
Michel
Posted: Tue Dec 19, 2006 1:51 pm Post subject: Stall speed noise |
Thanks again everyone and from the photos Lynn has sent me privately, I
can definitively say that my wings are not rib laced. I don't know how
they are made, though, because there is an inspection hole in the wing
but it has never been cut out of the fabric, so I can't look inside.
But ... since my wings are of the old Avid type and undercambered,
there must be something holding the fabric in upward, isn't it? Yet I
can't see any stitch as in the wings of Lynn.
Anyway, I always do a very thorough pre-flight, inspecting carefully my
wings and polish them carefully about twice a year. If anything was
loose, I would have seen it.
The thing is, I assumed the "stall noise" was normal, so I never gave
it much attention. But I will, next time I fly. Maybe it's the turtle
deck, as Kurt says. The strange things is, if it was the stall itself,
I should hear it also when I land, wouldn't I? But, as far as I
remember, that has never happened. Weird! But I'll keep an eye on it
and let you informed. Thanks again, everyone.
Cheers,
Michel
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Tue Dec 19, 2006 6:38 pm Post subject: Re: Stall speed noise |
Michel,
If the wings were built according to the Skystar manual the fabric is attached to the wing ribs with Poly Tack (glue). The vacume on the top of the wing is strongest when lift is being generated. At a stall I would think the pull (vacume) on the fabric on the wing top would be minimal.
Those undercambered wings have quite a curve on the bottom rib cap strips. In my opinion the bottom of the wing would be more likely to be the place fabric might generate a sound during stall.
Don't focus entirely on looking at the fabric on the top rib cap strips. Be sure to check the bottoms too.
For what it is worth. I once removed the fabric from one of my wings. I found it was very securely attached to the ribs with poly tack. I had to pull really hard to peel it off.
Also, I heard that seat belt slapping sound when I started the stinson the other day. Yes, I'm skinny too and the tail end of the seat belt was hanging outside the door. I think for loose fabric to make that sound it would have to be very loose.
Tom Jones, Classic 4, Ellensburg, WA
Michel
Posted: Wed Dec 20, 2006 12:52 pm Post subject: Stall speed noise |
On Dec 20, 2006, at 3:38 AM, Tom Jones wrote:
| Quote: | Don't focus entirely on looking at the fabric on the top rib cap
WILCO. Thanks, Tom.
Michel
