1planeguy(at)kilocharlie. Guest
Posted: Mon Jan 08, 2007 5:58 am Post subject: What am I Here after/wiring question... |
Its ok ... really. The Bible talks about flying, so I think it's a
<snip>
And the hereafter? Well, I don't know about you, but many of us are
getting
older and do start thinking more about the hereafter. Like you walk
into
your shop (working on your Kolb, of course) and when you get there you
ask
your self, now what am I here after?
Dennis
<snip>
Now that walk into the shop and wonder "WHAT AM I HERE AFTER" hits close
to home...funny thing is I'm 33...I don't have a chance
On a different note, as some of you know I'm building a little
"Superfly" Kolb based plane. (Firestar KXP cage, 22' wings like a
Slingshot or Firefly...have 5" spars like a Firefly except more ribs and
a single lift strut (Slingshot sized) and a 503. I'm modifying the cage
to add a throw-over canopy similar to the slingshot and have added the
Firefly flaperon mechanism to help slow it down. I am intending to keep
it light and thinking about pulling the GPL starter off the 503 that I
have and putting on the pull starter to save some pounds, but I will
need a radio. I understand it can be done, but while building and
flying these little planes has always been fun and "educational" my
knowledge of electricity is limited to "if you let the smoke out it
quits working!" Can anyone explain how you power a radio without the
battery that would normally be there for the starter? I guess the
thinking is if I have to carry a battery for the radio then the starter
is just a few more pounds and I'll keep it.
Jeremy Casey
rlaird
Posted: Mon Jan 08, 2007 7:01 am Post subject: What am I Here after/wiring question... |
Jeremy --
A good ICOM or Vertex handheld radio should be more than adequate for your needs... they have their own battery pack and you can put it in a jacket pocket, and you can plug your headset into them, thus adding 0 lbs 0 oz to your aircraft. The rubber ducky antenna -- assuming you don't have any ignition noise leaks on your plane -- is quite good for airport and plane-to-plane communication.
-- Robert
On 1/8/07, Jeremy Casey <1planeguy(at)kilocharlie.us (1planeguy(at)kilocharlie.us)> wrote:
Jeremy Casey
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com |
Richard Pike
Posted: Mon Jan 08, 2007 7:34 am Post subject: What am I Here after/wiring question... |
Years ago on the Hummer, (Rotax 277) I had no aircraft battery, but did
have a BIG capacitor inline from the generic cheapo regulator/rectifier to
the radio, (Terra 720 with internal batteries) and it worked really well.
The Hummer also had nav lights on the wingtips and tail just to provide a
load for the regulator/rectifier. You can probably get the right capacitors
at a car stereo shop or maybe even Kmart.
Richard Pike
MKIII N420P (420ldPoops)
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Denny Rowe
Joined: 10 Jan 2006 Posts: 89 Location: Leechburg, PA
Posted: Mon Jan 08, 2007 10:13 pm Post subject: What am I Here after/wiring question... |
Quote: | battery that would normally be there for the starter? I guess the
Jeremy Casey
Jeremy,
Call Dick Kuntzleman and order a Radio power supply, they are only a few
ounces, I have one in my Loehle powered by a 503.
Denny Rowe
robbie.robertson(at)mail. Guest
Posted: Tue Jan 09, 2007 2:38 am Post subject: What am I Here after/wiring question... |
Jeremy, you may have already done this, but have you looked at the Rotax Installation manual (assuming your Rotax powered that is) under wiring (see http://www.rotax-aircraft-engines.com/ under documentation), as it shows both battery and no battery configurations, but you would need a regulator...
Regards, Robbie (G-MYXS)
