rv73hl(at)comcast.net Guest
Posted: Fri Dec 29, 2006 7:16 am Post subject: Fuel Flw |
My Model IV 1200, has been feeding fuel from the right tank with gas in the left also. I finally deceided to run to see if the gas would transfer. Luckly for me, it stopped on final at our airport. The left tank had gas in it. It would not start, we added gas to the right tank, and after a few minutes on choke, it started.
Question...what would cause the tanks not to flow evenly. We had check the lines, and they all flowed. I would think the tanks would level up when sitting on the ground, but they do not seem to cross flow.
Suggestions please.
Howard
kerrjohna(at)comcast.net Guest
Posted: Fri Dec 29, 2006 9:25 am Post subject: Fuel Flw |
a similar experience was found to be caused by an undiscovered kink in the left hose when the wing was swung forward into flight position. we did not make it back to the airport but landed in a nearby hayfield
[quote]-------------- Original message --------------
Suggestions please.
Howard
torgemor(at)online.no Guest
Posted: Fri Dec 29, 2006 6:57 pm Post subject: Fuel Flw |
Hi Howard,
this is an interesting situation, I've been thinking a little about this
one. I'll say this is the first issue after the mandatory main tank "fuel
shutoff valve" removal.
Well, the removal of these two valves was a big mistake that Skystar did,
IMO. Do you have those installed??
There is three good reasons (at last) to keep this valves installed.
Lets first talk about your "possible" problem.
By some reason the pressure is higher in the right tank vs. the left side.
This explain the fuel transfere, it also explain your engine stoppage,
well how.
I'm assuming that you have the feeder went line connected to the left hand
main tank, right?
As we assume that the head pressure is lower in left tank, the transfere
take place -and fuel will be transferred by both the left feeder line and
the vent line. As the feeder is "pressurized" fuel transfere will use both
lines, that's why this go so fast.
As the left tank go dry, air start entering the feeder, the remaining fuel
is trapped in the left tank by the air pressure, the engine is using the
remaining fuel that’s below both feeding lines inside the feeder. Soon
your engine loose power.
Ok., it's right that some fuel will leak into the feeder from the left
tank due to gravity, when feeder fuel level go below the feeder pipe
outlet. However, this leakage will be far to low for your engine demand.
Then to the cause of the low pressure in the left tank, the traditional is
an old leaky gasket at the main filler, but your plane is not that old so..
Next, could it be a leaky head tube? Or could it be a leaky left fuel tank
at some high spot? All of these three is hard to spot/verify without a
tank shut off valve.
So number one reason for having main fuel tank shut off valves, is to
avoid unwanted fuel tranfere and loss of endurance.
In your case fuel would still be able to tranfere even if you had the shut
off valve installed. This time via the vent line.
I've many times talked about a cross vent line, such arrangement would
prevent transfere, but will lower the total head pressure if one of the
tank is leaking.
Number two is a safety issue, well both tank outlet enter cockpit via a
rubber housing - if one of those rubber housing start leaking, to stop
such a leakage you'll need to shut both tank valves, but you'll still have
the header for landing..
Number three. When I'm parking, even for long term, one of the main is
open the other is closed. For maintenance this valve is a must.
OK.
The last thing you've mentioned, is the lack of transfere from left to
right via the feeder when on ground.
This is hard to explain, unless you have a rubber flap valve somewhere(one
way valve), mentioned in one of the old the Rotax Service Information
Letter, that prevent fuel to go toward the right tank.
Well lets see what happen now..
There is still something to ask, how much fuel was left in the left tank?
Was the fuel level above the venline tube where it is entering the left
tank?
Good Luck
Torgeir.
On Fri, 29 Dec 2006 16:15:36 +0100, howard <rv73hl(at)comcast.net> wrote:
| Quote: | My Model IV 1200, has been feeding fuel from the right tank with gas in
Suggestions please.
Howard
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Float Flyr
Posted: Sat Dec 30, 2006 6:20 am Post subject: Fuel Flw |
Torgeir:
I followed your post with some interest. I do have a question... How do you
calculate the right tank to have a higher head of fuel than the right tank?
They are both at the same distance over the header tank.
My plane has forward facing vent tubes (on the caps) on both tanks. The
only way I can see a difference in the head of fuel from each tank is when
both tanks are at different pressures because of differences in the cap
vents.
There may be a little difference in the level of the plane in flight as the
rounded cowl distorts to some extent a persons ability to tell straight and
level. In a case like that the upper tank will empty first.
As to having separate shut offs on each wing tank I heartily agree with you.
I check the rubber tube connections on the fuel system quite often because I
don't want a gas shower at 3000' ! Shutting off one tank will also allow
you to get a good top off for max fuel in both tanks.
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Guy Buchanan
Posted: Sat Dec 30, 2006 7:47 am Post subject: Fuel Flw |
At 07:15 AM 12/29/2006, you wrote:
| Quote: | Question...what would cause the tanks not to flow evenly. We had
Suggestions please.
Howard,
We need more information. How much fuel was in your left
tank? (%) Do you have a header tank? Better yet, what does your
entire fuel system look like, with sizes and locations of tanks and tubes.
Guy Buchanan
K-IV/1200 w/ 582 C-box & Warp 3 blade
Deceased K-IV 1200
A glider pilot too. |
lcfitt(at)sbcglobal.net Guest
Posted: Sat Dec 30, 2006 9:42 am Post subject: Fuel Flw |
Noel,
I know this was directed to Torgeir, but I have some thoughts on this.
Because of the round shape of the top of the instrument panel / cowl, the
Kitfox doesn't have the typical flat reference to the horizon that a Cessna
has. The forward carry through shoud be flat with the horizon, but is a
distance visually from the horizon in our aiprlanes. In the group I fly
with we once had a guy streaming fuel from his fuel cap area and a close fly
by confirmed he still had his cap on. When he leveled his wings the fuel
stream stopped. He was our highest hour pilot, but when on a long X country
we tend to settle in and watch the scenery letting the airplane find it's
confort zone. This especially if we are un-trimmed i.e., needing a little
bit of right rudder when in cruise. When watching Kitfoxes in flight, it is
not uncommon to see guys flying with a wing low.
I think this is a major part of the uneven fuel flow, as in this
configuration, you will have a higher head in the high tank. It is
interesting also that the high tank will indicate a higher level of fuel in
the sight gauge, giving the impression that the low wing has less fuel in
it's tank. For those that have the tank valves, the common response would
be to close the valve on the lower tank which would result in full flow from
only the higher wing tank which might already have less fuel than the other
tank.
When rigged properly, the system works and this is where I disagree with
Torgeirs comment regarding Skystar's elimination of the tank valves. I know
some that still have them, but, and someone else will have to remind me of
the exact reason, I believe Skystar eliminated them because of issues that
developed after the addition of the header tank vent to the system. As I
unserstand it, the early fuel system with the panel tank didn't vent the
panel tank independently from the fuel lines from the wing tanks.
This latter is from my understanding and am always welcome to comments from
those that were closer to the issues mentioned.
Lowell N96KL Mod IV-1200
Float Flyr
Posted: Sat Dec 30, 2006 11:55 am Post subject: Fuel Flw |
Great! I'm not alone. After a flight of a couple of hours last year I
found myself happily cruising along left wing low. I would have put it down
to my weight except I was carrying an additional 70 lb or so in the right
float. Funny how just before touchdown the plane seems to level itself
out..I have yet to land on one float although I've taken off on one float
may times.
This is not quite off topic but do not archive anyway.
Noel
[quote] --
Kitfox III-A
Posted: Sat Dec 30, 2006 12:17 pm Post subject: Fuel Flw |
Noel,
Let's take the questions one by one.
On Sat, 30 Dec 2006 15:20:17 +0100, Noel Loveys <noelloveys(at)yahoo.ca>
wrote:
Torgeir:
you
tank?
Sure, the head pressure is the same if; the height of the vent tube (or
more correct "head pressure tube" installed on the fuel cap), the airfoil
shape (the wing where the cap is located), and the relative "position
cordline vs.pitot tip" is equal.
The thing is, when we pre compress our main fuel tanks in this way, the
air pressure inside the tank will be equal to the head pressure. Equal
pressure in both main tanks is the normal condition during our flight.
The pressure can't (normally) be higher in the right tank, but if the
pressure is decreasing (going low) in the left tank, we can say that the
pressure is higher in the right as this must be the situation in this
case. You'll that an uncoordinated/banked attitude can be the factor to
transfer fuel, but our tube size limit this some, so such a transfer cant
go as fast as Howard experienced.
Lets see some possibilities for development of "reduced" "head pressure",
see- when this pressure is reduced a little we cant name it "head
pressure" any more..
Remember, the top of the wing hold the static low pressure that's created
at the same location as our "head pressure". "The product of static and
dynamic pressure is always constant". This is one of the most important
thing to remember about fluid mechanics.
Well, the thing is that the "filler cap" gasket not only need to hold the
head pressure it will also need to hold for the differential pressure over
the wing, the static pressure.
Now folks, you'll see this gasket is very important for our kind of fuel
setup. This become more clear when we know there is restricted a flow in
the "header tube", the tube that's attached to the fuel cap, try to blow
through it and you should feel the resistance (this is valid -at least for
the older model Kitfox).
This limitation is in some matter very good, but in our case very, very,
bad. Cause such a limited flow can be "overtaken" by a broken "fuel cap
gasket", I.E. our supposed "head pressure" can drop below our "true"
static pressure. In this situation fuel is sucked from the feeder tank due
to the low pressure in the left tank, on the other side fuel is pressed
into the header tank from the normally pressurized right tank.
We can also have air leakage in the upper outer part of the tank, in this
case not that much flow as it is just the header pressure that do the
transfer.
The latter one is indeed more dangerous..
when
vents.
This might be true if the limitation is to hi, It should be easy to blow
through the "cap vent" and both should be equal.
I use to check my main for leakage in this way; close main valves for both
tank, then install a tygon housing or anything similar that can fit the
"vent line". The fuel cap should be installed as normal, then blow into
the housing and see if the pressure will hold without leaking - should be
no leakage here..
the
and
Agree with you here, but it seems like Howard’s transfer go much faster
than possible in the above example.
you.
because I
Thank you Noel.
Torgeir.
[quote] Noel
Posted: Sat Dec 30, 2006 4:22 pm Post subject: Fuel Flw |
Hi Lowell, my respected Kitfox friend,
I'll agree in all what you say, except the thing about Skystars
elimination of the main tank valves.
This need an explanation, and this is hard to explain as well -fully
understand cause of the complexity.
Well, before I'll start, maybe the latter posting has enlighten my
concern?? Or maybe cleared up a little more the "real" (?) problem -or?
I have a fully respect for the intention that Skystar had when they made
the last modification to the fuel system. However, I could not see the
"basement" of their decision, and they never explained "exactly" the
problem and why this solution.
Over the years, I've been reading everything that I could find about a
Kitfox plane, cause I had to justify why I wanted to by a Kitfox!! Well,
I've not only checked the Kitfox, But I've also checked the Avid...
In 8 to 10 different setup (Kitfox and Avid - maybe you may find even more
out there), there is one common parts that's sill the same!!!
(I'll know one that's not having this setup, -but only one.)
Yes. this is the way we "boost" the fuel pressure a little!
I’ve spent quite a few hours in order to explain this physics, -but for
"death ears", maybe my explanation is not good enough -or maybe people
don't care.
Sometimes I'm just wonderin if it is not best to close my eyes and leave,
-you know.
The thing is, this part need some scheduled maintenance-, then we'll need
just more education about the system- and how to handle/operate it
correctly!
Or- maybe a redesign is in place, if we want a system like Cessna, we need
to go all the way -not somewhere in between, like Skystar did.
Sorry folks, -sometimes you'll need to go all the way!
Now Folks, I'd like to wish one and everyone
A Happy New Year and all the best
Cheers
Torgeir.
On Sat, 30 Dec 2006 18:41:04 +0100, Lowell Fitt <lcfitt(at)sbcglobal.net>
wrote:
Noel,
the Kitfox doesn't have the typical flat reference to the horizon that a
Cessna has. The forward carry through shoud be flat with the horizon,
but is a distance visually from the horizon in our aiprlanes. In the
group I fly with we once had a guy streaming fuel from his fuel cap area
and a close fly by confirmed he still had his cap on. When he leveled
his wings the fuel stream stopped. He was our highest hour pilot, but
when on a long X country we tend to settle in and watch the scenery
letting the airplane find it's confort zone. This especially if we are
un-trimmed i.e., needing a little bit of right rudder when in cruise.
When watching Kitfoxes in flight, it is not uncommon to see guys flying
with a wing low.
in the sight gauge, giving the impression that the low wing has less
fuel in it's tank. For those that have the tank valves, the common
response would be to close the valve on the lower tank which would
result in full flow from only the higher wing tank which might already
have less fuel than the other tank.
know some that still have them, but, and someone else will have to
remind me of the exact reason, I believe Skystar eliminated them because
of issues that developed after the addition of the header tank vent to
the system. As I unserstand it, the early fuel system with the panel
tank didn't vent the panel tank independently from the fuel lines from
the wing tanks.
from those that were closer to the issues mentioned.
Float Flyr
Posted: Sat Dec 30, 2006 5:32 pm Post subject: Fuel Flw |
I expect the thing to do if any problems are encountered is to install wing
tank shut offs (2) and a crossover line left to right tank. The only time I
did have a problem was with fuel over flowing. What caused that was only
having one cap with a forward facing vent. I flew like that for a few hours
while trying to get another cap to fit and there was no doubt about it the
tank with the vented cap emptied long before the other one.
I have been playing with the idea of installing fuel shutoff cocks on my
wing tanks for quite some time now. I would want ball valves (1/4 turn on
and off) which have less chance of weeping fuel.
Noel
[quote] --
Kitfox III-A
Lynn Matteson
Posted: Sun Dec 31, 2006 3:37 am Post subject: Fuel Flw |
I followed Bill Willyard's idea and installed ball valves in my fuel
lines right in the cabin area, behind my seat, visible by turning my
head, and reachable while flying. They are in the Grainger catalog,
item #6GD45 for the 1/4" NPT size. I haven't had a bit of trouble
with them, and at about $4 each, they are cheap. I use one on each
drop from the tanks, and another as my main fuel line shutoff on my
console. I can turn these off to facilitate changing fuel lines,
filters, etc.
Lynn
Lynn
On Dec 30, 2006, at 8:32 PM, Noel Loveys wrote:
install wing
only time I
was only
few hours
it the
on my
turn on
Noel
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
dchuser2(at)comcast.net Guest
Posted: Sun Dec 31, 2006 8:06 am Post subject: Fuel Flw |
The most likely reason one wing tank flows more or less than another is that the ball is not centered in the turn-and-bank indicator. The Kitfox, with its tapered nose, can easily be flown in a slight crab without realizing it - especially if you're an old Cessna or Piper driver having flown with straight sided cowls.
Dennis-in-Michigan
Posted: Sun Dec 31, 2006 12:15 pm Post subject: Fuel Flw |
Hi Lowell and Kitfox flyers/Builders,
Sorry for being a little "hot" here, but this topics do interest me more
than most.
Thank you Lowel, for triggering me. I'll know I've to do better, so
I'm going to draw the whole Kitfox fuel system, but, next year.
So again.
To All and everyone of you.
A Happy New Year.
Torgeir.
On Sun, 31 Dec 2006 01:22:18 +0100, Torgeir Mortensen <torgemor(at)online.no>
wrote:
more out there), there is one common parts that's sill the same!!!
don't care.
leave, -you know.
need just more education about the system- and how to handle/operate it
correctly!
need to go all the way -not somewhere in between, like Skystar did.
Cheers
Torgeir.
Float Flyr
Posted: Sun Dec 31, 2006 12:42 pm Post subject: Fuel Flw |
Almost 6 P.M. here now so it's time to wish every one here a Happy and
Prosperous New Year!!
Noel
[quote] --
Kitfox III-A
kitfoxmike
Posted: Sun Dec 31, 2006 2:21 pm Post subject: Re: Fuel Flw |
Just to let everybody know, I have a very simple system, one vent line from the right tank to the header tank, and one line from each of the tanks to the header. I have a 1/4 inch ball valve on each wing tank and currently I have the left tank in operation. I to have a problem with the right tank going into the left tank when both are open, but will stop after a bit, I just watch the levels on the tanks and only open one at a time. Never had a problem doing so. On airplanes that are low wing you can only operate on one tank at a time so I have no problems doing it with the fox.
