PFolbrecht(at)starkinvest Guest
Posted: Wed Feb 01, 2006 5:35 pm Post subject: Gaps again - HS rear-spar-to-skin |
I clecoed on the rear spar of the HS and noticed a bit of gap between the skin and the spar, even at the clecos, with clecos in every other hole. I figured I had countersunk enough and so took it apart and went a bit deeper. (I tested the cage on a peice of scrap again and it seemed very good, with a dimple on another scrap peice the same thickness as the skin fitting nicely.)
Clecod it back together and in most places there is really no gap, but not quite everywhere. I was careful to countersink the full depth on each hole - so that no more metal was coming off. I test drove a couple rivets at the places with the gaps and found that it remained. It's enough to insert a peice of paper about 1/8", but no more.
The thing is, I'm afraid to really go any deeper with the cage because it was very near the point where the hole would be enlarged.
I took a look at my QB wings and noticed that the TE skin has no gap - except near the edges, where I *can* get a piece of paper in there a bit.
Again, the paper goes in about 1/8" - maybe halfway to where the rivet is. I think the irregularities (some areas tigher than others) are due more to small variations in alignment than differences in the countersinking.
Is this normal, or Ok? If you've built a HS lately, did you notice this? Am I being a bit anal or am I right to wonder about this? Should I risk countersinking a bit deeper, on the areas with a bit of gap?
Paul
9A QB #1176
P.S. I *did* end up completely drilling out and bending one of those problem ribs of earlier in the week. I'm much happier with the
| - The Matronics RV-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
dsvs(at)comcast.net Guest
Posted: Wed Feb 01, 2006 5:56 pm Post subject: Gaps again - HS rear-spar-to-skin |
You should not be using a counter-sink on the rear spar. These parts are
thin enough to dimple.
Don
RV7
Wiring Instrument Panel
Posted: Thu Feb 02, 2006 7:28 am Post subject: Gaps again - HS rear-spar-to-skin |
I don't know the thickness, but it's pretty thick, and the manual does
specify countersinking...
Posted: Thu Feb 02, 2006 7:58 am Post subject: Gaps again - HS rear-spar-to-skin |
OK. Sorry about that . On thye 7 the manual says dimple.
-------------- Original message ----------------------
From: "Folbrecht, Paul" <PFolbrecht(at)starkinvestments.com>
