cdewey6969(at)yahoo.com Guest
Posted: Sat Jan 20, 2007 8:43 pm Post subject: Wheel pants |
"pressure recovery wheelpants" can you explain how
these differ from regular wheelpants?
--- Brian Whittingham <dashvii(at)hotmail.com> wrote:
Whittingham" <dashvii(at)hotmail.com>
Charles,
The parachute on the Lightning is behind the
seats. Mr. Davis whose
airplane just flew a day or two ago is going to add
an autopilot after he
flies the time off and gets it back home. So he
should be able to tell you
how the install was. Can't be too hard though if he
decided to wait until
after the build and fly-off. The best guess that I
have about how the
Lightning can be faster without retracts than the
WT-9 would be that it's
almost like comparing apples and oranges. THe
lightning paid attention to
lessons learned from experience building Esquals.
The section of the
fuselage aft of the wing remains wide continuing
back from the fuselage
further. This shape is better for lower drag. The
cowling on the Lightning
is probably a lot less draggy than the WT-9, but
that's just a guess. The
wings are a huge part of the total drag of the
airplane. I believe this
figure is around 75% if I remember correctly. The
Lightning wing is a
wonderful performer for manuevering flight, cruise,
speed, and climb. Have
no idea what airfoil the WT-9 uses, but probably a
less exotic and copy of
the old Clark Y or something.
Now there's been some interesting discussion about
landing gear drag. I can
tell you that wheels and gear legs unfaired create a
lot more drag than
faired ones. Buz had a huge speed increase just by
putting on the fairings
and wheelpants. We never got a chance to test an
Esqual fairing against a
Lightning one though. Cirrus and Diamond aircraft
had considered making a
retract for their single engine planes, but found
that with "pressure
recovery" wheelpants the drag was negligible. The
insurance, weight, and
complexity increases with retracts. The Lightning
has pressure recovery
wheelpants that are similar to the ones you'll find
on the Van series of
aircraft. They minimize drag moreso than just a
normal faired wheelpant
because the airflow stays attached to the unit
further aft. I've not flown
the fixed gear or retractable WT-9, but I bet the
speed difference isn't
over 2-5 knots total. It is an interesting debate,
but if I was going to
design a high speed single I think that I'd make it
fixed gear to help with
insurance and as a pilot it's just less to go wrong
and have to maintain.
(although I do kind of like the old Mooney's with
the all manual Johnson Bar
gear, emergency and normal gear extension is the
same procedure!) Brian W.
Finding fabulous fares is fun.
Let Yahoo! FareChase search your favorite travel sites to find flight and hotel bargains.
http://farechase.yahoo.com/promo-generic-14795097
| | - The Matronics Lightning-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
dashvii(at)hotmail.com Guest
Posted: Sat Jan 20, 2007 8:59 pm Post subject: Wheel pants |
Charles,
I have some pics somewhere of the differences in the wheelpants. I
believe the idea originally came from a NACA report and was first used by
the Cessna company. If you look down from above it is very much a teardrop
shape. The design has been windtunel tested and proven to produce less drag
than simply putting a minimal area fairing around the wheels. The term
pressure recovery comes from the shape producing a low pressure area in the
spot where the boundary layer would normally seperate from the standard
fairing. This helps to "suck" the layer back down, reattaching it to the
surface of the fairing and keeping it attached longer. This helps to reduce
the amount of drag.
The same idea is used on the wing section. It is a highly laminar flow
wing. (I'd love to do some oilflow or tuft testing on this wing!) It uses
the same idea to help the boundary layer stay attached to the wing further
back. This helps to reduce the amount of parasite drag and therefore the
total drag on the plane. If you read my earlier pirep you'll see references
to dive testing the Esqual as compared with a Lightning. The Esqual wing is
a dragier planform.
Buz's Esqual tested the Lightning wheelpants and gear leg fairings. Between
this and a Lightning cowling (modified because the noselengths are
different) he saw almost 50mph over a stock Esqual. So there's definately
drag reduction there. What we don't know is how much more speed he got than
if he had a non-pressure recovery wheelpant, like on the Esqual. I can't
remember but I believe that Buz also has the same wheel that is found on the
Lightning which is wider than the Esqual, but I can't confirm that. Brian
W.
Search for grocery stores. Find gratitude. Turn a simple search into
something more.
http://click4thecause.live.com/search/charity/default.aspx?source=hmemtagline_gratitude&FORM=WLMTAG
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
