randy(at)romeolima.com Guest
Posted: Mon Jan 29, 2007 12:39 pm Post subject: RV-3 height and/or weight limitation |
Everyone's proportions are different, but yes, I've heard of guys that big fitting ok. The cockpit is 24" wide at the skins, but Van is probably 6'2" or so himself and he designed it for him originally. If your friend is ok with a tight fit he should make it but the best answer is to have him go to a flyk-in and politely ask an owner to sit in a cockpit, then he'll know for sure.
Randy
| - The Matronics RV3-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV3-List |
eric.sandifer(at)siemens. Guest
Posted: Mon Jan 29, 2007 12:45 pm Post subject: RV-3 height and/or weight limitation |
Rick,
I'm not sure if there's a difference in canopy height between the slider and tip-up, but I'm 6'-3 1/2", 200 lbs. and fit in my RV-3 tip-up...albeit with no extra head room. Vans site says the cockpit is big enough for pilots up to about 6'-3".
Eric Sandifer
N154AB
From: owner-rv3-list-server(at)matronics.com [mailto:owner-rv3-list-server(at)matronics.com] On Behalf Of Rick Fogerson
Sent: Monday, January 29, 2007 3:30 PM
To: "Undisclosed-Recipient:;"(at)siemens.com
Subject: RV-3 height and/or weight limitation
I had a guy who is 6'-2" and 220 lbs ask me "would he fit in an RV-3 slider cockpit". I have no idea. Do any of you know of someone who is close to this size that flies okay in this airplane.
Thanks, Rick Fogerson
Quote: |
="http://www.matronics.com/Navigator?RV3-List">http://www.matronics.com/Navigator?RV3-List
="http://forums.matronics.com">http://forums.matronics.com
This message and any included attachments are from Siemens Medical Solutions
and are intended only for the addressee(s).
The information contained herein may include trade secrets or privileged or
otherwise confidential information. Unauthorized review, forwarding, printing,
copying, distributing, or using such information is strictly prohibited and may
be unlawful. If you received this message in error, or have reason to believe
you are not authorized to receive it, please promptly delete this message and
notify the sender by e-mail with a copy to Central.SecurityOffice(at)siemens.com
Thank you
prhoads61(at)frontiernet. Guest
Posted: Mon Jan 29, 2007 12:56 pm Post subject: RV-3 height and/or weight limitation |
Rick,
I'm 6'2", 225lbs. and fit just fine in my RV-3. I even fit with a Strong chair type chute if I remove the main seat cushion.
The sliders are harder to get in and out of than the tip-overs. Once you're down in the seat, you have plenty of room.
Perry Rhoads
N96GW
