berkut13(at)berkut13.com Guest
Posted: Wed Feb 14, 2007 8:09 pm Post subject: Radio audio troubles |
Hi Gurus,
It's been awhile, but I hope all is well with you all.
I'm having audio issues with my new Becker 4201 #2 com and was wondering if
you could help.
The issue is the output audio from the radio whenever there is another radio
switched into the same output. As soon as any other input is selected on
the audio panel at the same time, the com#2 volume goes very very low and is
overpowered. Sidetone during transmit seems un-affected as does the audio of
the other sources selected - only the Com2 audio drops down. By
itself...the radio sounds fine, and operates properly.
The #1 com (iCom A200) works fine and is nice and loud with any number of
inputs selected on the audio panel (KA-134). Adding additional inputs has
little to no affect on com1 volume. It works great - as it should.
According to the KA-134 schematics, the only thing it's doing with the phone
outputs from the radios is mechanically switching them (no electronics)
together to a single output line to the intercom. Because of this, I was
wondering if the impedance differences of the radios are a problem.
However, I have no real understanding of the magic involved here.
They are as follows according to the respective docs:
Com1 iCom - 500 ohms
Com2 Becker - 600 ohms
Eng mon - 560 ohms
Nav KN-53 - 500 ohms
RST Marker Receiver - unknown
I am still puzzled why Com1 has no issues with any number of other inputs,
and
Com2 does....impedance differences and all.
Any ideas? I have schematics for the KA-134 if you want to see it...but for
this, it's just mechanical switches.
Thanks for any help!
James Redmon
Berkut13 N97TX
nuckollsr(at)cox.net Guest
Posted: Thu Feb 15, 2007 6:17 am Post subject: Radio audio troubles |
At 10:08 PM 2/14/2007 -0600, you wrote:
Hi Gurus,
you could help.
Eng mon - 560 ohms
Actually, those "output impedance" values are completely
bogus. See:
http://aeroelectric.com/articles/Rev11/18Audio_R11.pdf
The true output impedance of any of these devices
is considerably lower than the values stated. What
they really mean to say is, "This product will produce
rated output performance when presented with xxx ohms
of LOAD.
If the mental image I have from reading your words is
coincident with your own, then it appears that something
may be amiss in the audio isolation amplifier. The whole
idea of such a device is ISOLATION. This means that adding,
deleting or suffering a failure in any of the audio sources
should have no effect on performance of remaining sources.
Try swapping affected radios to different inputs to
the amplifier and see if the symptoms swap with the radios
or stay common to the switches on the amplifier.
( IF one aspires to be "world class", )
( what ever you do must be exercised )
( EVERY day . . . )
( R. L. Nuckolls III )
Posted: Thu Feb 15, 2007 3:49 pm Post subject: Radio audio troubles |
Yup...switches with "ganged" inputs. See below link for the schematic.
(300K .jpg)
http://www.berkut13.com/dloads/ka-134.jpg
I'm glad you attached Dan's reply, I never received it. I guess I can
perform surgery on the input lines and install a 220-ohm resistor on each.
Yeah, it's a hunk of junk King! I wish I had never installed it...but it's
far worse to try to extract it and start over now. Anyone know if the VAL
(same size) AP-100 has a isolation circuit built in? It might become a
"throw
money at it" solution if the resistors don't help.
What I don't understand is why Com1 (iCom) can be "switched" in with all the
other inputs with no adverse affects. But, the com2 (Becker) can't - ANY
input source that's switches in takes the Becker to almost zero and, of
course, when the volume is turned all the way up it's all distorted. Add
all you want to the iCom and the blend in just fine. Is that what John is
suggesting might be cause by the iCom possibly having a significantly lower
impedance than the other radios?
I can also tell you that the iCom's output is very robust compared to the
other radios. It's quite loud, deep and clear with very little turn of the
volume knob - very sensitive. Not sure that says anything other that it's
got a good amp on it, but I'll put that out there too.
Again, thanks for all the help!
James
