nuckollsr(at)cox.net Guest
Posted: Thu Feb 15, 2007 8:18 am Post subject: Electronics Intl MVP-50 Dsub 37's connectors |
At 09:08 PM 2/14/2007 -0500, you wrote:
<rtitsworth(at)mindspring.com>
Bob, etal
I have an ElecIntl MVP-50 engine monitor. The various probes connect to
three Dsub 37 connectors on the box (via a user created harness).
To get the engine prob wires through the firewall I have a few options:
1. Drill a hole, and use a flange and a piece of fire sleeve and a couple
wire ties (quick and cheep)
2. Get a few large Amp/mil-spec bayonet style multi-pin round plugs
(expensive and heavy)
3. Fabricate/find three Dsub 37 bulkhead connectors and use the provided
cable components and a standard Dsub 37-to-37 straight thru cable. Thus:
connect the probes to the provided Dsum37 connectors, connect those to the
dsub37 bulkhead connectors, connect the back side of those to the
dsub37-to-37 straight through cables, connect the other end of the cables to
the engine monitor box (dsub 37). i.e. Seems it would be "clean" to just
use the same style connectors throughout.
Have you ever see a thing such as Dsub37 bulkhead socket?
Not one that's fire-rated . . .
| Quote: | i.e. like a
normal one with bigger flanges. Have you ever seen one that had male pins
on one side and female plugs on the other (straight through)? Ideally it
would be > 1/2" depth in the center to get through the firewall. Or perhaps
a similar gender changer and then I'd find/make a mating cable?
What's your design goal? If ease of installation an maintenance
supercedes concerns for fire wall integrity, then panel mounted
d-subs to take wires through the fire wall are a consideration.
If it were my airplane, I'd take the bundle through fittings
not unlike these . .
http://aeroelectric.com/articles/Firewall_Penetration/firewall.html
These are techniques used on some present production TC aircraft.
There are no doubt equivalent and perhaps more attractive
techniques. I've not had time to research them.
( IF one aspires to be "world class", )
( what ever you do must be exercised )
( EVERY day . . . )
( R. L. Nuckolls III )
echristley(at)nc.rr.com Guest
Posted: Thu Feb 15, 2007 9:41 am Post subject: Electronics Intl MVP-50 Dsub 37's connectors |
I've either have, or have had, some D-subs that had a ceramic material
in the center that held the pins. I have no technical data at all about
what the filler material was, but it looked more robust than the typical
plastic center sections. I don't know where I got the old connectors
from, and a quick Google search didn't turn up anything useful. If I
still have them in my toolbox, I'll post a picture before and after I
put a torch to them.
,|"|"|, Ernest Christley |
----===<{{(oQo)}}>===---- Dyke Delta Builder |
o| d |o http://ernest.isa-geek.org |
N6030X(at)DaveMorris.com Guest
Posted: Thu Feb 15, 2007 9:56 am Post subject: Electronics Intl MVP-50 Dsub 37's connectors |
Is there any problem with breaking a thermocouple wire at the
firewall with a bulkhead connector?
Dave Morris
At 08:08 PM 2/14/2007, you wrote:
Bob, etal
Have you ever see a thing such as Dsub37 bulkhead socket? i.e. like a
Rick
