Dennis.Kirby(at)kirtland. Guest
Posted: Tue Feb 20, 2007 2:36 pm Post subject: Limited Range |
Kolb Friends -
All the recent discussion on bigger fuel tanks for our Kolbs has just
hit home for me. In flight planning for my first REAL cross-country
trip, I am currently making plans for the upcoming Monument Valley trip
in May.
The cold, hard truth has suddenly become clear: ten gallons of fuel is
proving to be quite limiting for me, especially in northwest New Mexico
and the four-corners region, where we are hard-pressed to find airports
within 200 miles of each other!
Up to now, the stock 10 gallons of fuel in my Mark-III was adequate for
local flying, and the occasional round-robin flights (usually under 100
miles) that always begin and end at my home airport. But now I'm
finding that it's gonna take some real planning to hopscotch my way to
Goulding's without running dry en route.
At this point, I'm considering bringing an extra 5 gal gas can with me
(full, of course) as emergency backup. In case I encounter unforcast
headwinds that would cause me to burn up all my gas before reaching my
destination, I'm thinking it would be better to land on a lonely dirt
road and refill rather than land on that dirt road and be out of gas!
John H is right - I'm already thinking about options for more fuel
capacity.
Dennis Kirby
Mark-III, 912ul, and only 200 miles of range, in
Cedar Crest, NM
jim
Posted: Tue Feb 20, 2007 3:08 pm Post subject: Limited Range |
Can you land on a lonely dirt road next to a gas station?
Jim
N. Idaho
<Dennis.Kirby(at)kirtland.af.mil>
. . .I'm thinking it would be better to land on a lonely dirt
_________________ Jim
N. Idaho |
dhkey(at)msn.com Guest
Posted: Tue Feb 20, 2007 3:28 pm Post subject: Limited Range |
Dennis,
These look neat. I haven't used one or talked with anyone who has but I'm
trying to figure out a good excuse to try one.
http://www.imtra.com/downloadtypes/nauta_brochure.pdf
Maybe someone knows something about these.
planecrazzzy Guest
Posted: Tue Feb 20, 2007 5:09 pm Post subject: Re: Limited Range |
Hey Dennis,
A cheap facet pump would transfer the fuel "in Flight"
But then you have to figure if you need it in both tanks or one...
( I don't know your fuel system )
Gotta Fly...
Mike in MN ...FSII / N381PM ( needs more fuel too )
| Dennis.Kirby(at)kirtland. wrote: | I'm thinking it would be better to land on a lonely dirt
Dennis Kirby
Cedar Crest, NM |
kfackler(at)ameritech.net Guest
Posted: Tue Feb 20, 2007 7:57 pm Post subject: Limited Range |
| Quote: | Can you land on a lonely dirt road next to a gas station?
Let me share a story about that, if I may. I wasn't flying a Kolb at the
time, but anyone who flies anything might learn from this.
I found myself running short of fuel and happened to spot just what you
described, a gas station on a lonely road. And it had a large open area
right next to it. I mean, it looked so good that I could practically taxi to
the gas pump from that area, so down I went.
What I couldn't tell from altitude (and was too green a pilot to analyze)
was that this spot was an access point for heavy trucks going into and out
of a construction area nearby. There had been some rain a few days
previously and these big trucks had rutted the area badly. And I mean HUGE.
The landing nearly beat me to pieces, not fun. But I got down okay, got my
gas, and got ready to leave. By now, as is usual with these birds, I'd drawn
quite a crowd. After dispensing with the usual questions (how fast, how
high, do you need a license) I managed to get my bird cranked and turned to
depart.
This is when I made the biggest mistake of all up to this point. I failed to
walk the spanI planned to takeoff from. The ruts were unbelievable and I was
actually bounced into the air, VERY hard, before the plane was quite ready
to fly. I managed to get the nose down and caught it before smashing back
down and established my climb.
After a few minutes of letting the nerves settle, I thought, "Man, that was
one rough landing and takeoff. I sure hope this bird is holding together."
So I began a visual scan. Wings okay, tail okay, right main okay. Left main?
Left main? Gone! Yeah, that last bump literally ripped the main gear and
gear leg off the airplane.
I had the 'pleasure' then of completing the flight to my home field
wondering just how badly I was going to be mauled when I crashed this thing
on two wheels. I'd actually seen a two wheel landing done once, when a guy's
wheel just fell off as he rolled down the runway. (Rushed his pre-flight it
turned out and forgot the safety pin.) So I knew the technique, which is to
land real soft, wait for the wing on the damaged side to start to drop, then
give it all the opposite inputs you've got.
I had to buzz the runway several times to get the attention of my buddies
(no radios in use back then) and they cleared all the parked airplanes out
of my way. I got it down with no additional damage other than to my already
frazzled nerves, but it was probably way more luck than skill. I was even
able to drive back to the gas station and retrieve the gear assembly and
later put it back on the plane. Again, dumb (and I mean dumb) luck.
But the lesson is, I hope, all too obvious. Landing where you don't know the
ground truth is risky. And always walk your takeoff run at a strange
location.
-Ken Fackler
Kolb Mark II / N722KM
Rochester MI
WillUribe(at)aol.com Guest
Posted: Tue Feb 20, 2007 8:14 pm Post subject: Limited Range |
--> Kolb-List message posted by: "Kirby Dennis Contr MDA/AL" <Dennis.Kirby(at)kirtland.af.mil>
| Quote: | Up to now, the stock 10 gallons of fuel in my Mark-III was adequate for
Goulding's without running dry en route. |
Hi Dennis,
This is how I would do it.
Take Albuquerque to Milan Grants airport following I-40 79.7 miles.
Milan Grants airport to Gallup 58.9 miles following I-40
Gallup west over I-40 to Chambers 36.8 miles then north via 191 to Chinle 83.1 miles. Fuel up at Chinle with the 5 gal tank I carry in the jump seat and head on into MV.
Simple
Will Uribe
El Paso, TX but working in Arlington, TX
FireStar II N4GU
http://www.members.aol.com/willuribe/mv/
[b]Check out free AOL[/b]. Most comprehensive set of free safety and security tools, millions of free high-quality videos from across the web, free AOL Mail and much more.
Roger Lee
Posted: Tue Feb 20, 2007 8:31 pm Post subject: Re: Limited Range |
I tried a 5 gal. can in the other seat with a facet pump. It was in the way and could not carry passengers or luggage.
The Imtra 6 gal. fuel bladder works very well. I had a seperate facet pump and fuel shut off to it and it pumped into my main tanks so I could read the level on my EIS. I mounted it jsut behind the main fuel tanks. I was very happy with it and I had 3.5 hours of run time. It wa easy to fill with airport fuel trucks, also. Some of the guys saw it last year at MV.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
Posted: Tue Feb 20, 2007 8:32 pm Post subject: Limited Range |
and
| head on into MV.
| Simple
| Will Uribe
Gang:
Will knows how to do that, even with an extreme headwind, like last
year.
Are you planning on flying the FS this year, Will?
DO NOT ARCHIVE
_________________ John Hauck
Titus, Alabama |
Posted: Tue Feb 20, 2007 9:25 pm Post subject: Limited Range |
In a message dated 2/20/2007 9:33:09 P.M. Mountain Standard Time, jhauck(at)elmore.rr.com writes:
| Quote: | | Quote: | --> Kolb-List message posted by: "John Hauck" <jhauck(at)elmore.rr.com>
and
| head on into MV.
| Simple
| Will Uribe
Gang:
year.
DO NOT ARCHIVE |
That is the plan, God willing and my work schedule permits it. Only this year I plan to talk some Challenger, Rans and X-Air drivers into flying with me. The problem is the Challenger driver keeps breaking his plane, the Rans may not be finished in time and the X-Air driver doesn't fly much.
If we can coordinate it, The Wondering Winch and Larry will also fly with us when they return from their odyssey to San Antonio. Dave Rains will be flying his Cessna 175 and our EAA chapter president will be flying his Piper Tripacer to take the Navajo Young Eagles for a ride.
Will Uribe
BTW; For those of you who know Dave Rains, his mother passed away last week, may she RIP.
[b]Check out free AOL [quote][b]
Posted: Tue Feb 20, 2007 9:45 pm Post subject: Limited Range |
Dennis
I have a aux fuel system that has served me well for a number of years in my
MKIIIc. I bought a cheap 6.5 gallon gas can that I attached a faucet pump
to. The pump has a cigarette lighter style plug wired to it. I have a self
sealing quick connect plug on the output line from the pump that I connect
to its mate which fills my two five gallon tanks when flying cross country.
When I get a few gallons down on my 5 gallon tanks I plug in the pump and
transfer fuel. I like to keep my main tanks near full so if there are any
problems with the fuel transfer process I can adjust my flight plan while I
still have fuel. So far no problems other than over filling and venting fuel
once or twice. This set up gives me almost four hours flying time with half
hour reserve. Most of my flying is close to home so the aux system works
best for me. If I had a larger main tank I would be carrying allot of extra
fuel and weight that I wouldn't use or would have to worry about
condensation from running with a half empty tank most of the time.
Someone mentioned that they couldn't put luggage in the passenger seat with
their set up but that hasn't been a problem for me. I pack a tent, cot,
folding chair, sleeping bag, tie downs, brief case sized flight bag and a
few other items in the passenger seat with my tank. The tent, cot, tie
downs, and the chair go behind the tank and then are all seat belted into
place.
Again the information is worth what you paid for it.
Rick Neilsen
Redrive VW powered MKIIIc
