Jaybannist(at)cs.com Guest
Posted: Sun Feb 25, 2007 11:23 am Post subject: Registration |
Listers, a question:
It is my understanding that iIf a Zodiac 601XL is registered "Experimental," it can be flown as an LSA or as any other experimental airplane and the builder can do all the maintenance by filling out a form.
If it is registered "E-LSA," it can be flown only as an LSA and the builder must attend a course on maintenance to qualify to do maintenance.
Why would anyone register a 601XL as E-LSA?
Jay in Dallas
zodie(at)adelphia.net Guest
Posted: Sun Feb 25, 2007 11:37 am Post subject: Registration |
Posted: Sun Feb 25, 2007 12:07 pm Post subject: Registration |
Hi Jay,
As always, there are trade-offs.
The issue regarding maintenance is actually a little better than your
comments suggest. Anyone can work on any experimental aircraft no
matter whether it is E-LSA or E-AB. The regulations get involved
when it comes to signing off the annual condition inspection. This
can always be done by an A&P with appropriate license. In the case
of E-AB it can also be done by the builder if he has the repairman's
certificate that can only be issued to the builder. For E-LSA there
is a similar certificate that can be earned by attending a 2 day
class. In this case you don't have to be the builder, but I think
you need to be the owner.
There is no 51% rule for E-LSA certificate. The other difference I
know about is the number of hours needed to fly off the Phase 1
flight testing. This is 25 or 40 hours for E-AB certificated
planes. I have seen E-LSA get as little as 5 hours of Phase 1 flight
test requirement. This is the amount of flight testing you need to
do before carrying passengers or leaving the limited flight test area.
One last point. The question of flying "as LSA" doesn't need to
consider how the plane is certified. It only matters that the
performance and other qualities qualify the plane as meeting the LSA
requirements. A Sport Pilot or higher licensed pilot flying under
Sport Pilot privileges can fly any plane that meets the LSA
definition. Similarly, a plane with an E-LSA certificate can be
flown at night or IFR if properly equipped.
Have fun,
Paul
XL fuselage
filling out a form.
Jay in Dallas
bryanmmartin
Posted: Sun Feb 25, 2007 12:49 pm Post subject: Registration |
It might be a little bit easier to sell an E-LSA than an E-AB because
the new owner can obtain certification to perform the annual
inspections without having to be an A&P mechanic. The night and IFR
restrictions apply to the Sport Pilot not to the Sport Aircraft. A
sport pilot may not fly at night or IFR. A sport aircraft, if
properly equipped (and, for S-LSA, approved by the airframe and
engine manufacturers) can be flown at night or in IFR.
http://www.sportpilot.org/questions/afmviewfaq.asp?faqid 4
Question :
Who can perform maintenance and inspections on an E-LSA?
Answer :
Anyone can perform maintenance, repair, or modification on an
experimental light-sport aircraft. No certificate or rating of any
kind is required.
The annual condition inspection on E-LSA can be completed by:
a) A repairman (light-sport aircraft) with a maintenance rating; or
b) A repairman (light-sport aircraft) with a inspection rating on
aircraft owned by the repairman; or
c) An appropriately rated mechanic (A&P), or
d) An appropriately rated repair station.
http://www.sportpilot.org/questions/afmviewfaq.asp?faqid=540
Question :
i am building a kitplane which has been approved for the 51 % rule. i
would like to know what all the pros and cons are whether to finally
register it as e-ab or e-lsa.
Answer :
The only difference of any consequence in certification of the
aircraft as either experimental amateur-built or experimental LSA is
the issue of the repairman certificate. This certificate is necessary
if an individual wishes to perform the condition inspection each year
as required by the aircraft's operating limitations. (No certificate
of any kind is necessary in order to perform maintenance, repair, or
modification.)
Here's the deal:
For amateur-built aircraft, only the original primary builder is
eligible for the repairman certificate. There is no training
requirement. The individual simply needs to prove that he/she is the
original primary builder of the aircraft. No subsequent owners are
eligible, so they would have to have an A&P mechanic perform the
condition inspection each year.
For ELSA, the owner must attend a 16 hour course of instruction and
pass a test in order to be eligible for the repairman certificate.
This is true regardless of whether the person built the aircraft or
not. Even the original builder would have to take this course.
However, subsequent owners would be eligible for the repairman
certificate after passing the 16 hour course, even though they had
nothing to do with the building of the aircraft.
Yes, it is true that you must have the certification completed by 31
January 2008 in order to certificate the aircraft as ELSA. There is
no deadline for amateur-built certification, but you must be able to
prove that amateur-builders did the major portion of the fabrication
and assembly tasks.
Other than the repairman certificate issue, there is no operational
difference in ELSA as compared to amateur-built.
filling out a form.
maintenance.
Jay in Dallas
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
_________________ --
Bryan Martin
do not archive. |
Posted: Sun Feb 25, 2007 3:26 pm Post subject: Registration |
Listers,
Thanks to all who replied to my question about E-LSA vs Experimental. There were some aspects that I was not aware of; and others that I knew about, but hadn't thought through the implications.
You all came through again and proved the value of this list.
Thanks again!
Jay in Dallas
