Mike Hoffman
Posted: Fri Feb 23, 2007 5:06 pm Post subject: 701 Jury Struts |
I have my struts installed and now I am working on the jury struts. Using the dimension on the prints, the jury strut lower horizontal (500 mm long piece) does not work out if placed 1200 mm up from the center of the lower strut mounting hole (it is to long). In addition, if I used the given location, the jury strut angel brackets that are attached to the bottom of the wing would not intersect. It looks like I have a couple of options. One would be to shorten the lower horizontal piece and install it at the given location. I would have to remove and change the bend in jury strut angle. The other option (more favorable) would be to raise the location by about 40 to 60 mm and cut down the vertical and diagonal pieces of the remaining jury strut pieces.
Has anyone else encountered this problem and if so, what changes did you make? It would be nice if there were a n assembly guide for this operation.
Thanks in advance
Mike H
Mike Hoffman
