		beachyjeff(at)juno.com Guest
				 Posted: Thu Feb 22, 2007 12:57 pm    Post subject: Evans Coolant and Rotax Airbox |
				I am planning on running Evans coolant in my new 912ULS. I noticed that
 some slight residue was in the coolant system, presumably from a factory
 test run. Is it necessary to flush a brand new engine before using Evans,
 or is it okay to simply use Evans from the first fill?
 Also, on my Rotax airbox, I have the small bottom end holes attached to
 hoses which I have run down to the slipstream. Is this correct? I know
 not to extend the carb lines down due to the pressure compensating
 feature, but is this a non-factor when using the Rotax airbox?
 Thanks!
 Jeff Beachy
 Zenith CH701
  |  | - The Matronics RotaxEngines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Roger Lee
				 Posted: Thu Feb 22, 2007 5:32 pm    Post subject: Re: Evans Coolant and Rotax Airbox |
				Hi Jeff,
 If all the water is out except for a few spoon fulls which you coudn't get out anyway the just go with the Evans. I have used Evans in my last plane and my new one and I have been happy.
 I'm not sure about the airbox. Look online under Rotax/Kodiak and look under their installation manual.
  _________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Home 520-574-1080  TRY HOME FIRST
Cell 520-349-7056 |
