Eric_Kallio
Joined: 29 Jan 2006 Posts: 149 Location: Baton Rouge, LA
Posted: Fri Feb 23, 2007 6:53 am Post subject: Aileron and flap actuation |
When attaching the ailerons and flaps I am finding that both peices, on both wings, rub the top skin. The flaps contact just prior to the neutral position and the ailerons at about 20 degrees trailing edge down. I don't have pics handy, but I can get some if needed. Is this common, or do I get to re-work my wings? Don't want to get to far into the aileron actuation section unitl I clarify this. Thanks.
Eric Kallio
40518 starting the fuel tanks that were put off til last...the joys of proseal.
flysrv10(at)gmail.com Guest
Posted: Fri Feb 23, 2007 7:33 am Post subject: Aileron and flap actuation |
My QB wings had the same problem with the flaps slightly rubbing at
their up position. I have seen another 10 with the flaps rubbing also.
My solution was to put vans control surface tape on the flaps. My
ailerons are OK so I can't really comment about them.
this. Thanks.
Eric Kallio
of proseal.
http://forums.matronics.com/viewtopic.php?p=96844#96844
Tim Olson
Posted: Fri Feb 23, 2007 3:32 pm Post subject: Aileron and flap actuation |
Mine rub of course too. I think most will. I put the tape though on
the underside of the wing skin instead of the flap, so you don't have
the tape visible. No scratches that I'm aware of yet.
> Eric Kallio
> proseal.
Posted: Fri Feb 23, 2007 3:53 pm Post subject: Aileron and flap actuation |
As the other post stated, using UHVM tape or something like that on the Flap
will keep it from scratching the paint. It is good to have a tight fit
there.
On the aileron, if you have not connected the two ailerons together yet,
then you probably won't have to worry, because they don't travel as much
when they are hooked up. If they are already hooked up, then you may have a
problem.
Hope this helps.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
www.saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
