Vanremog(at)aol.com Guest
Posted: Sun Feb 25, 2007 9:03 am Post subject: Oil Cooler Door |
Over the years there has been much discussion here regarding oil cooler blocking to elevate oil temps in cold climes. It seems that most attempts to block off a baffle-mounted cooler at the rear of the cooler exhibited marginal improvements at best, and those that covered the front of the cooler much more effective.
You know I've heard this argument for years and it just isn't so. The attached photo shows one that works quite well and is simple to execute.
GV (RV-6A N1GV O-360-A1A, C/S, Flying 833hrs, Silicon Valley, CA)
AOL now offers free email to everyone. Find out more about what's free from AOL at AOL.com.
61.02 KB |
370 Time(s) |
Dale Ensing
Joined: 11 Jan 2006 Posts: 571 Location: Aero Plantation Weddington NC
Posted: Sun Feb 25, 2007 9:45 am Post subject: Oil Cooler Door |
I would like to know your secret. My oil cooler door is exactly like yours and I detect very little oil temperature rise when the door is closed.
Dale Ensing
[quote] You know I've heard this argument for years and it just isn't so. The attached photo shows one that works quite well and is simple to execute.
_________________ Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
klwerner(at)comcast.net Guest
Posted: Sun Feb 25, 2007 9:57 am Post subject: Oil Cooler Door |
Did you seal all the potential leaks with RTV around the fins of the plates, like GV did?
bertrv6(at)highstream.net Guest
Posted: Sun Feb 25, 2007 12:29 pm Post subject: Oil Cooler Door |
Quoting Dale Ensing <densing(at)carolina.rr.com>:
| Quote: | I would like to know your secret. My oil cooler door is exactly like yours
Dale Ensing
Dale:
Common... you logic alone destroys that argument no?
Example, my Carb heat, does not show any drop in rpms, when checking
mags before take off, etc...but I know that when that little door is
closed, the inside temperature of that Carb. area, is going to got up./
That is law of PHysics...
My 2 cents..
Happy flying
Bert
rv6a
rocketbob(at)gmail.com Guest
Posted: Sun Feb 25, 2007 6:20 pm Post subject: Oil Cooler Door |
Looks like you have some foam rubber on the door and sealed up around it pretty well... what's the coldest temp you've flown in and what was your oil temp?
Bob Japundza
RV-6 flying F1 under const.
On 2/25/07, Vanremog(at)aol.com (Vanremog(at)aol.com) <Vanremog(at)aol.com (Vanremog(at)aol.com)> wrote:[quote] Over the years there has been much discussion here regarding oil cooler blocking to elevate oil temps in cold climes. It seems that most attempts to block off a baffle-mounted cooler at the rear of the cooler exhibited marginal improvements at best, and those that covered the front of the cooler much more effective.
