Nick(at)Scholtes1.com Guest
Posted: Mon Feb 26, 2007 8:15 am Post subject: Speedster Wheel Pants and Tires |
KitFoxers,
I recently purchased a Model IV Speedster. The kit came with wheel
pants, but the builder never installed them, opting for large tundra
tires instead.
I would like to install the wheel pants. I've read somewhere that the
tires that go under the pants are a different size than the stock
tires. But I've never seen it written anywhere as to what that size
is. So, some questions:
-- What is the "standard" Kitfox tire size?
--What size tire goes under the wheel pants?
-- What pressures does everybody typically run in their tires?
The builder included the wheel pants. In reading the installation
instructions, there is a spindle that is used to support the outboard
end of the pants.
-- Does anybody have a pair of wheel pant spindles that they would be
willing to sell?
Thanks very much!
Nick Scholtes
Lynn Matteson
Posted: Mon Feb 26, 2007 10:43 am Post subject: Speedster Wheel Pants and Tires |
Hi Nick-
I run 14-15 psi in my 16 x 7 x 8 Cheng-Shin tires under/in wheel
pants...Grove landing gear. The wheel pant kit should include the
outboard "spindles." The standard axle gets drilled to accept these
spindles...out to 1/2", as I recall. The spindles are merely a large
washer and internal nut welded to the end of a length of 1/2" (I
believe) chrome-moly tubing. I had decided on going to the smaller
tires so they would readily fit within the pants, and so as to not
cut the pants to fit the tundra tires (which I had on at the time)
and then find later that the smaller tires would leave huge gaps
between the tires and pants. John McBean probably has the spindles. I
hope you've got the mounting brackets for the inside of the wheel
pants, as I had to build mine...lotsa work.
Lynn
On Feb 26, 2007, at 11:14 AM, Nick Scholtes wrote:
KitFoxers,
tundra tires instead.
the tires that go under the pants are a different size than the
stock tires. But I've never seen it written anywhere as to what
that size is. So, some questions:
outboard end of the pants.
be willing to sell?
Thanks very much!
Nick Scholtes
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
