N1BZRich(at)AOL.COM Guest
Posted: Sun Mar 04, 2007 7:29 pm Post subject: A trip to "Lightning Operations" |
Hello to all Lightning pilots, builders, and fans,
Hopefully this "rather long" trip report will generate some more message traffic about the Lightning. I hope so. Feel free to inject your thoughts, ideas, suggestions, or questions. Someone on the list will probably have the answers. Here goes:
I just spent another ten days with the Lightning guys in Tennessee and thought I would post a few thoughts and observations. The purpose of my trip from Virginia to Shelbyville was twofold. First, my Jabiru 3300 powered Esqual LS (Lightning Stuff) now has 250 hours on it (in the last 14 months) and I needed to do some time phased preventative engine maintenance. More on that later. The second reason for the trip was to help Joe and Linda Mathias (good friends from Virginia) with the initial test flights on their Lightning and also help them with some of the detail things like gear leg fairings and wheel pants.
The trip out here Friday a week ago was one of the roughest rides I have had in a light airplane. I bumped all the way across Virginia and the eastern half of Tennessee and at times saw winds as high as 80 mph (about 30 degrees off the nose) and an effective head wind of almost 50 mph. Luckily, the winds changed to mostly cross winds as I got further into Tennessee, so I was able make up some time and get my average speed up some. As I usually do, I made the trip non stop, but it took 4.2 hours due to the head winds. I still managed to average 130 mph block to block, but I normally can make the trip in 3.3 hours with a block to block speed close to 170. Fuel burn for this trip was about 6 gph - slightly higher that I normally burn, but I kept trying different altitudes with hopes of finding less head winds and smoother air. No luck.
Saturday morning (24 Feb) the Lightning and Jabiru aircraft guys attended an EAA fly-in here at Shelbyville. Yes, we took off from here and then "flew-in". Nick in the prototype Lightning, Pete in a new Special Light Sport Jabiru, and me in 31BZ, flew some formation before landing for another great EAA breakfast. The ramp was full and the food was great, so it was a good fly-in.
Saturday afternoon Pete helped me do yet another head torque and valve adjustment (not a requirement for those of you that have the new hydraulic lifter engines). We also replaced the distributor caps and rotors, put on new plug wires, and set the gap between the flywheel magnets and ignition coils. Note: the distributor caps and rotors are time replacement items which I should have done at 200 hours. One other thing we did was to check my engine serial number against the Jabiru Service Bulletin having to do with the flywheel bolts. Luckily my engine serial number (843) did not require the procedures called out in the SB.
Sunday was spent doing a few other maintenance and clean up items on 31BZ while Pete flew some more time off another SLA Jabiru. Believe it or not, Pete and Ben (with family members) went to a Circus here in Shelbyville Sunday afternoon. You would think they would have had their fill of dealing with us "Clowns" on a daily basis.
Monday was a big event as Nick made a first flight in Rick Bowen's Lightning which flew beautifully with no airframe corrections required. I happened to be airborne flying some demo flights at the time and was able to get a close up view of Rick's "jet" in flight. Unfortunately, I did not have a camera with me, but it is another beautiful Lightning.
Tuesday's big event was Linda and Joe's airworthiness inspection by the local FAA DAR. The inspection went well - as do all of the inspections in Shelbyville because the Lightning and Jabiru guys know their stuff and have a great reputation with the FAA. I am always impressed as to how "on top of things" the Tennessee gang is. If you have any kind of "tool skills" and will listen to their guidance, you will end up with a fantastic airplane.
Wednesday was probably a first for the Arion Aircraft group as two Lightnings made their first flights on the same day. Linda and Joe trusted me enough to give me the honor of making the first flight in their "Lightning Bug" (N59JL) and it flew beautifully. Linda will take over the test flying duties soon. Shortly after that flight Nick made the first flight in Joe Cooper's Lightning and Joe was on hand to witness the event. I had flown earlier that day with Joe in the left seat of 31BZ and he is anxious to climb in his own cockpit to see how much better the Lightning really is. Another neat thing about Wednesday was that two Lightnings that had previously "flown the coop" returned to "home plate". Earl Ferguson and John Davis both flew back to SYI for a visit. Earl flew some demo flights in his soon to be "record setter" (ask Earl what that means). And John's "red, white, and blue patriotic Lightning" is absolutely beautiful, but I have to ask John where he got that short "dorky looking" prop; in a box of Cracker Jacks maybe?
Saturday (3 March) was another EAA fly-in breakfast, this time at Winchester, Tennessee. Three aircraft made the hop to BGF from SYI. Pete flew the Jabiru 170 with Joe Mathias flying as co-pilot, Ben was in the Jab 250 with Linda Mathias, and I took Joe and Linda's (N59JL) on it's first cross country. The winds were forecast to be high all day in this part of Tennessee, and the weather guessers were right. When we got back to SYI we had a direct cross wind of 17 knots with gusts close to 30. I must admit I was concerned, being in a new airplane, but the Lightning handled the cross wind with no problem. The afternoon was spent fitting gear leg fairings and wheel pants to N59JL since the winds prevented effective test flying.
Sunday morning I put another 1.2 hours on Linda and Joe's Lightning in order to reach a total of 5 hours so that we could do the initial head torque. After that Linda and I flew one last flight in my Esqual with her in the left seat and doing all the flying. She handled the cross wind well and felt ready to fly her Lightning so she did just that, flying for an hour. While Linda was airborne, Mark and I took 31BZ up for more transition training for him. Mark flew some loose formation with Linda for a while in order to check her airspeed indications. Overall a full, fun day. Linda's landing was superb, so congratulations are in order for her initial solo in an airplane she built. And it is a beautiful example of the Lightning.
A few other observations:
-The new Lightning Demonstrator is back from the paint shop and it is going to be a super aircraft. It will have a great panel layout with an impressive dual screen Grand Rapids EFIS set up. It should fly in a few weeks. Look for this new Demonstrator Lightning at Sun-N-Fun where it will be doing triple duty - in the display booth, in the fly-by pattern, and flying demo rides for potential customers. Speaking of SNF, so far it looks like at least five Lightnings will be there (plus 31BZ). I am sure we will have some sort of get together while there, so make your plans now to attend. Lets make it a real "Lightning Storm".
-The Prototype Lightning will be testing a new prop to try in the near future. Nick has been running it with a ground adjustable carbon fiber Sensenich set to a pitch of 56 inches and the engine will still turn up at least 3400 RPM. Nick mounted a new Sensenich wooden 64ZK58 on Saturday and will be trying it out this Monday if winds and weather allow. Stand by for a "sonic boom" as Nick starts testing the Lightning with this prop. Nick will provide actual test results when available.
-The Jabiru hangar (next to Lightning) is full of Jabiru aircraft in various stages of completion. If you want a "turn key" Special Light Sport Aircraft that will run circles around a Cessna 172, a Piper Cherokee, or certainly any LSA, take a look at the Jabiru 250. I am lucky enough to have flown the Jabiru 170, 250 and 400, and all are impressive. Talk to Ben about a test flight in one of these unique airplanes, but do it soon - they build one a week and they are sold out until sometime in June.
-Final thoughts: It never ceases to amaze me at the overall value and capability that the Lightning represents. If you want a truly beautiful kit built aircraft that is relatively inexpensive (compared to other aircraft with similar performance), quick to build, and has amazing performance while being extremely economical to operate, you absolutely have to seriously consider the Lightning. You will not be disappointed. And remember, it can also be built to meet the Light Sport requirements. Also, if you are in a real hurry to get in the air, sign up for their builder's assist program. With their expert help and guidance, you will soon be flying an aircraft of your own creation. That is certainly a rewarding experience. Another observation is that the quality of the finished product when using the builders assist program, is absolutely superb. All of the Lightnings built here that I have seen (and I think I have seen them all) could easily be called "show quality". They will get lots of attention at any EAA fly-in. If you don't win a trophy it may be because the Judges asked you "How long did it take you to build your airplane?" They may not believe you.
-Heck, I want a Lightning. Anyone want to buy a fast Esqual?
Blue Skies,
Buz Rich
AOL now offers free email to everyone. Find out mo615326657x4311227241x4298082137/aol?redir=http://www.aol.com" href="http://pr.atwola.com/promoclk/1615326657x4311227241x4298082137/aol?redir=http%3A%2F%2Fwww%2Eaol%2Ecom" target="_blank">AOL.com.
| | - The Matronics Lightning-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
davemcc
Posted: Mon Mar 05, 2007 4:57 am Post subject: A trip to "Lightning Operations" |
Buz
I believe the flywheel bolt applies to all engines under serial 856. If I read it right your flywheel bolts would not have the new torque of 24 lbs. I will be replacing mine on serial 751 with 219 hrs. Please let me know if I am incorrect.
More stuff-- don't know if you were lucky enough to install a Becker com, if not and have a Micro 760, I had to send mine in because of a factory circuit board problem and internal ground strapping problems. I had to call Australia to figure this one out. You can receive, but sends garbled.
Auto pilot is almost done, excited to give it a try.
Dave McC
pete(at)flylightning.net Guest
Posted: Mon Mar 05, 2007 5:43 am Post subject: A trip to "Lightning Operations" |
Dave,
From the service bulletin itself:
4.7 2200 Engines S/No. 2058 and Above. 3300 Engines S/No. 837 and Above.
a) Maintain the engine as detailed in Modified Maintenance Schedule B in Section 6.2
below.
As you can see engines serial number 33A837 and above only need to comply with the revised maintenance schedule.
Pete Krotje
Jabiru USA Sport Aircraft, LLC
From: owner-lightning-list-server(at)matronics.com [mailto:owner-lightning-list-server(at)matronics.com] On Behalf Of Dave
Sent: Monday, March 05, 2007 6:56 AM
To: lightning-list(at)matronics.com
Subject: Re: A trip to "Lightning Operations"
Buz
Dave McC
n1bzrich(at)AOL.COM Guest
Posted: Mon Mar 05, 2007 5:49 am Post subject: A trip to "Lightning Operations" |
Hi Dave,
Pete and Ben looked up the SB for me and said my engine serial number was higher than the ones specified, so I took that as the final word, but I will ask again. Yes, at Pete's recommendation I used Becker equipment - small, light, and dependable. I have been pleased with how the com and xponder work. Good luck with the auto pilot. There is some adjusting to be done while in the air depending on the airplane and how aggressively you want the auto pilot to react, but the results are great.
You going to make SNF and/or OSH?
Blue Skies,
Buz
Rick
Joined: 24 Jul 2006 Posts: 113 Location: Colonial Beach, Virginia
Posted: Mon Mar 05, 2007 1:08 pm Post subject: A trip to "Lightning Operations" |
Buz,
As usual, a excellent read from you.
Appreciate all your comments and thoughts....good job!
Look forward to more "reporting" from you.
Rick
The average US Credit Score is 675. The cost to see yours: $0 by Experian.
http://www.freecreditreport.com/pm/default.aspx?sc=660600&bcd=EMAILFOOTERAVERAGE
cdewey6969(at)yahoo.com Guest
Posted: Mon Mar 05, 2007 4:07 pm Post subject: A trip to "Lightning Operations" |
Has anyone on the Lightning list checked out the
Maverick light jet called SoloJET? They claim a cruise
speed of Mach 0.8, which is about 540 mph. I know this
has nothing to do with the Lightning but it is kind of
like our close cousin in that the Maverick team, like
the Lightning team, has managed to create a design and
clean it up and tweak it to make it much faster than
one would expect. The price difference is 1.25 million
for a Maverick or under 75K for a Lightning. None of
the light jets like the PiperJet or the DJet by
Diamond can even come close to the speed of the
SoloJET. Who wouldn't want to do a fly-by at Mach
0.8!?!?! Just joking. Also- FYI- There is a Velocity
(canard plane) with a 600 HP turbine in it. I want to
speak to that man to see how fast he is going and just
how crazy he is. Just floating these facts out there
to the fellow Lightning crowd to get everyone focused
on SPEED. I love flying but it sure is nice to get to
your destination in a jiffy. Charles Dewey
--- Rick Bowen <rollnloop(at)hotmail.com> wrote:
Buz,
job!
Rick
Don't pick lemons.
See all the new 2007 cars at Yahoo! Autos.
http://autos.yahoo.com/new_cars.html
davemcc
Posted: Mon Mar 05, 2007 8:15 pm Post subject: A trip to "Lightning Operations" |
Pete
I concur, my question related to paragraph 6.3, sub notes. I am sure I was reading into it about any engine below serial 856 having a lower flywheel bolt torque of 24 ft lbs.
Thanks again, Dave
davemcc
Posted: Mon Mar 05, 2007 8:34 pm Post subject: A trip to "Lightning Operations" |
Buz
I didn't get the autopilot done last weekend, we went snowmobiling all weekend- got 40 inches of snow. Should have it done tomorrow if push rods come in. Needed different lengths.Wiring is done.
We will be at S&F on Thurs. Last year when we went, we flew IFR to Shelbyville where we stopped for fuel. Hopefully this year we will see more than ice on the wings, like pretty countryside.
Dave
davemcc
Posted: Tue Mar 06, 2007 4:47 am Post subject: A trip to "Lightning Operations" |
ron.wullaert(at)telenet.b Guest
Posted: Tue Mar 06, 2007 11:33 am Post subject: A trip to "Lightning Operations" |
Buz
I'm a huge Lightning fan living in Belgium. I've been following the Lighting list for almost a year now and I must say, It's because of reports like yours that I get more and more attracted to this great flying machine. I will be traveling to the US for a business trip in April. I've made some changes to my plans to be a few days earlier in the US so that I can visit you guys at Sun-N-Fun. Looking forward to it already!
Ron
Posted: Tue Mar 06, 2007 12:55 pm Post subject: A trip to "Lightning Operations" |
AOL now offers free email to everyone. Find out more about what's free from AOL at AOL.com.
Posted: Tue Mar 06, 2007 1:05 pm Post subject: A trip to "Lightning Operations" |
Hi Ron,
Great to hear that you will be at Sun-N-Fun. I look forward to meeting you there. I will probably fly down a day or so early and be there for most, if not all, of the show.
You are right about the Lightning being a great flying machine. The Guys in Tennessee have come up with a great combination of airplane and engine. The Lightning and Jabiru 3300 together have the kind of a synergistic effect where the sum of the parts is more than the individual parts when taken separately. From the Lightnings beautiful lines, to it's fantastic performance on such a low fuel burn, it is hard to not love it. Add to that the economical kit cost and the quick build time and you have an unbeatable combination. Ask anyone that has flown one and you will probably get a big smile, then they will probably have a hard time coming up with the words to describe how much they enjoy the airplane. "Wow" seems to fit.
Blue Skies,
Buz Rich
AOL now offers free email to everyone. Find out more about what's free from AOL a26657x4311227241x4298082137/aol?redir=http%3A%2F%2Fwww%2Eaol%2Ecom" target="_blank">AOL.com.
Posted: Wed Mar 07, 2007 2:15 am Post subject: A trip to "Lightning Operations" |
Danny
Considered the Esqual... Yes, sure I did. Inspired by it like the Lightning... No, not really. All credit to the Esqual design, without it there would not be a Lightning. But the Esqual is still the Esqual of years ago, there is little or no evolution in it's design. The guys from Arion on the other hand, have worked hard to mature the aircrafts design and make it to something that exceeds the Esqual in many ways. Even now, they don't sit down and rest by what they have build. They are still improving their bird day after day. The spirit of what they build comes to life in the peoples who fly with Lightning and that's something I don't see in the Esqual community. Having that said, I'm sure the Esqual is also a far better choice than many of the other kits on the market today. I wish you lots of happy hours in your Esqual and sure would like to see it when it's finished.
Many happy landings!
Ron
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
