XLR connectors
fvalarm(at)rapidnet.net
PostPosted: Wed Mar 21, 2007 9:58 am    Post subject: XLR connectors Reply with quote
Somewhere you had mentioned the use of XLR connectors as good parts to use as an external power port for charging aircraft batteries. These are made for audio applications and commonly found at radio Shack and other sound outlets. I would like to install one or two in my RV7A for maintaining the batteries whenever not flying (electrically dependant engine) to keep the batteries in full charge at all times and to supply power when "hangar flying" the EFIS and GPS as I learn how to use/program them. Now, several questions:
Since these are audio products and not necessarily intended for sustained large current carrying capacity, max current are not likely published by the manufacturer. I have no specs here. Do you know the max DC current rating for these devices or have you tested one to destruction?
If not, I could send you one for destructive testing. I could too for that matter, but my power supply only goes up to 25 amps at 12V. Maybe, I could use a car battery to supply more current. Any comments here?
Would you recommend using the XLR port for ONLY "maintaining" battery levels and fused at some low value (if so what value would you recommend) or could these ports be used to "charge up" a depleted battery without current restrictions?
Considering a dual battery system (probably Z-19) I assume two XLR ports would be required?
I like these ports as they are small, lightweight, utilize chassis mount format, and have positive locking mechanism. A down side is they do not come with a cover to keep the weather out. I'm considering hiding them behind a small door near the aft mounted batteries. Any comments here?
Bevan
RV7A
Finishing canopy
Planning electrical install
nuckollsr(at)cox.net
PostPosted: Wed Mar 21, 2007 10:35 am    Post subject: XLR connectors Reply with quote
At 10:56 AM 3/21/2007 -0700, you wrote:
questions:
The BEST application for these connectors is
as cockpit power outlets for portable accessories.
Yes . . . These can be used for a charger connection
for a Battery Tender or Battery Minder. Perhaps even
a small Schumacher smart charger rated at no more than 5A.
would be required?
Yeah . . . but you COULD use a single maintainer to do this
through a single connector. The XLR connectors have 3 terminals.
Use one for ground. Use the other two as feeders off the battery
bus with 5A fuses. Then short these two pins together in the
CHARGER side of the connection. This parallels the batteries
only during the maintenance mode when the charger is plugged in.
Sounds like a plan. There are some flip-cover versions out
there in the wild but they can be mounted in some handy
but covered spot like on a bracket you can reach through
the oil-check door. The only caveat is to limit total
current through this connection to 5A or less.
trigo(at)mail.telepac.pt
PostPosted: Wed Mar 21, 2007 11:05 am    Post subject: XLR connectors Reply with quote
Bevan
Another electrically dependant Subbie guy here.
I used a good "cigarrette lighter" socket in my panel, which will have dual function. One outlet, to power any handheld device, and the other as an inlet port to charge my 2 batteries.
If you want to consider this solution, I will send you my schematic.
Carlos
RV-9A
dsvs(at)ca.rr.com
PostPosted: Wed Mar 21, 2007 11:57 am    Post subject: XLR connectors Reply with quote
These connectors are rated to higher current values and work in the cockpit as well as in the wild (the fully sealed units only)
See www.powerletproducts.com/products/plugs_sockets.php
Tim Olson
PostPosted: Wed Mar 21, 2007 12:38 pm    Post subject: XLR connectors Reply with quote
I've been preparing to add a ground charging connector myself
and did a bit of thinking about this. I'm not interested in
a jump-starting connector, which completely changes the
picture and opens opportunities.
The one that I'm most considering right now is a 7-pin RV
trailer connector:
http://www.etrailer.com/faq/wiring.aspx
The connectors have a receptacle that can be mounted in the
baggage bulkhead easy enough (not for outside the airplane),
and depending on your current needs (battery tender, or
full charger) you can choose from smaller or larger connectors.
The 7-pin connector has way more pins than I'd need, but they
have a couple of them that use 10ga and 12ga wires as standard.
So if you wan to parallel charge your main and aux battery,
you could put power in on 2 pins and use the heavy ground for
the other.
It has the drawback of being non-standard, so you won't be
able to use it in the field really easy unless you make
and carry some sort of adapter, and it can't be used for
starting, but if you're just trying to keep your batteries
all charged up in the hanger during extended downtimes,
this should work, and the price is good. Still open
to other good suggestions for up to 20A, but this one
seems to be an easy route right now.
Robert L. Nuckolls, III wrote:
<nuckollsr(at)cox.net>
> Bob,
> destruction?
> here?
rvbuilder(at)sausen.net
PostPosted: Wed Mar 21, 2007 1:38 pm    Post subject: XLR connectors Reply with quote
So why not just go with a Piper style ground power. It's pretty similar to a trailer plug and you can use it for jump starting and have a chance of getting a FBO GPU that can plug in.
http://www.aircraftspruce.com/catalog/elpages/piperplugsock.php
Michael Sausen
-10 #352 Limbo
Tim Olson
PostPosted: Wed Mar 21, 2007 2:19 pm    Post subject: XLR connectors Reply with quote
A couple reasons: 1, costs more. 2, can't charge both my aux and
main batteries without tying them together or using huge diodes,
3, I can buy this one locally for a good price, 4,the wires are
protected by the backshell, so there's less exposed terminals to
worry about. It's pretty light, too. I had considered the
piper and normal type, but as I mentioned, I'm not at all
looking for a jump start connector and I don't want to use
huge fat wires, and I do want to charge both batteries.
Michael Sausen
-10 #352 Limbo
ceengland(at)bellsouth.ne
PostPosted: Wed Mar 21, 2007 4:29 pm    Post subject: XLR connectors Reply with quote
snipped
The XLR connectors are great; very rugged & reliable. You might alienate
yourself from the crimp camp, though. Smile You might want to rethink the
locking feature. What happens when you kick the wire? If I were using it
strictly as an aux power jack, I'd file off the lock tang to minimize
damage to the wire (& possibly myself) if I trip on it.
If you're building an RV with the batteries on the firewall, I'd at
least take a look through the oil filler door & see if you can reach the
batteries' positive terminals with charger clamps. Any engine part will
work for the ground. I found that I can reach the positive terminal with
the clamp that comes on a typical small battery charger. No extra wire,
no connector, no extra weight, no extra things to break.
'Simplicate & add lightness.' One of my favorite aviation quotes. (Wish
I could remember who said it first.)
jetboy
PostPosted: Thu Mar 22, 2007 1:14 am    Post subject: Re: XLR connectors Reply with quote
Yes the XLR connector would be fine. There is also a 4 pin version used in the video industry extensively for 12V DC power on camera / recorder equipment. The pins are slightlly smaller dia. than the more common 3 pin audio connector, so the audio one may in fact have better current capability. both versions are very robust, cameramen and sound techs do not appreciate loosing their footage - as you will using the most horrid connector of all - the cigar lighter plug. these things are more likely to start a fire than the lighter itself - no disrespect to those that use them- please be wary of leaving them unattended and dont use for mission critical applications. A friend found the one in his Cherokee was not enough for all his gadgets so bought a 4 outlet box and slung it up behind the panel.... thereafter had to wiggle the plugs about to keep all his stuff online. It would be safer to cut all the plugs off and use a wire joiner - but can't do that in a cert. A/C
Ralph
Ralph - CH701 / 2200a
