nuckollsr(at)cox.net Guest
Posted: Mon Mar 26, 2007 3:46 pm Post subject: Low Voltage Warning/Aux Battery Management Module |
At 08:12 AM 3/24/2007 -0500, you wrote:
<bbradburry(at)allvantage.com>
I purchased the board from Bob's site and the components from Digikey. I
then tried to assemble the module as per the instructions here...
http://www.aeroelectric.com/articles/lvwarn/LVWarn-ABMM.pdf
It looks like a simple board, so I thought that I could do it even with my
skills??? Well, DUH!!
When I turn on the master, the 3 amp fuse immediately blows! I have
absolutely no idea how to go about trying to troubleshoot this board.
Can some of you guys give me some leadership here? Please don't talk
about testers more than a cheap volt/ohm meter and be pretty specific
about how to use even that..:>)
Thanks for your help.
Bill B
Drop it to me in the mail and I'll trouble shoot
it, fix it and tell you what I found and how I
found it.
I've built a couple hundred of these critters
and can probably find it pretty quick.
On the other hand, if it's blowing fuses, it sounds
like a hard short. Check for solder splashes on the
connector pins. I can't think of any component placement
error that would draw that much current.
( IF one aspires to be "world class", )
( what ever you do must be exercised )
( EVERY day . . . )
( R. L. Nuckolls III )
Posted: Tue Mar 27, 2007 3:41 pm Post subject: Low Voltage Warning/Aux Battery Management Module |
At 09:11 AM 3/27/2007 -0500, you wrote:
Thanks, Bob! My buddy at the airport has offered to look at the
board. He has it now. If he comes up empty handed...(not likely :>))
I will take you up on the offer.
Very well. Holler if we can help!
( EVERY day . . . )
