Posted: Wed Mar 28, 2007 5:23 pm Post subject: Props and engine mount/propeller selection |
Date: Wed, 28 Mar 2007 12:21:11 -0700
| Quote: | I've wanted a 4 blade prop for some time, I think it probably gives better
thrust effect (I don't want to start up the old debate of how many blades
are better). I mostly want to do it for my own gratification and to validate
my theory. That is why I figure a 68" would be fine.
Ron,
In making propeller decisions look at:
http://www.gylesaero.com/freeware/propcalc.shtml
Using this software I input for a 63 mphi, 2,222 propeller rpm, and 68 inch
diameter propeller for the FireFly. Then I changed the pitch for a two
blade propeller until the engine was putting out 38 hp. This produced a
thrust of 166.5 pounds with a propeller efficiency of 73.6%.
Leaving all other inputs constant I changed from a two to a three blade
propeller and adjusted the pitch until three blade propeller produced the
same thrust. Propeller efficiency fell to 69.6% and the engine power to
produce the same thrust went up to 40.2 hp. Adding another blade to
propeller produced an efficiency of 64.3% and an engine hp requirement of
43.5 hp.
Then I changed tactics. I kept the initial conditions, thrust and
efficiencies constant as I added blades. To do this you have to shorten the
blade length and adjust pitch. What I found was that to maintain 73.6% at
166.5 pounds of thrust the three blade propeller diameter turned out to be
57.6 inches and the four blade came out at 52 inches.
To go the constant 68 inch diameter route, it indicates a 4.1 to 9.3%
increase in fuel burn. To go with constant efficiency with no increase in
fuel burn, one must be prepared to shorten the blades. If length can absorb
max engine hp, it is difficult to beat a two blade propeller. The inertia
is lower, weighs less, and in most cases is less expensive.
Try the program for your intended setup and see how it comes out.
For what it is worth.
Jack B. Hart FF004
Winchester, IN
captainron1(at)cox.net Guest
Posted: Wed Mar 28, 2007 6:50 pm Post subject: Props and engine mount/propeller selection |
I have no doubt that Induced drag and Parasitic drag on a 4 blader will be higher, however I also think that I will get more thrust out of it with my set up. It is obvious to me and I measured again today that my max prop can be 68 inches. So working with that, and all the turbulation that a pusher prop experiences I want as much air grabbing, thrust sucking, as I can garner out of that 105 hp in back there. I don't mind being proven wrong on this, I think its fun.
Ron (Arizona)
---- "Jack B. Hart" <jbhart(at)onlyinternet.net> wrote:
--> Kolb-List message posted by: "Jack B. Hart" <jbhart(at)onlyinternet.net>
Ron,
43.5 hp.
For
jb92563
Joined: 23 Mar 2007 Posts: 314 Location: Southern California
Posted: Thu Mar 29, 2007 9:59 am Post subject: Re: Props and engine mount/propeller selection |
Note: When using that "Prop Selector" program the fields "Output Power" + "Absorbed Power" must be less than or equal to the max HP your engine puts out at the selected RPM.
If they tally up to more then that, it means in reality your engine can not spin the prop as fast as you selected and/or have over proped the engine.
Try lower pitch/Diameter or RPM until you get the HP your engine is capable of for that RPM.
I designed my own prop selector program as well that automatically reduces the Dia or Pitch for the HP of your engine.
Unfortunately it does not go past 40" diameter. I may have to haul it out and revise it for bigger diameters.
Ray
_________________ Ray
Moni MotorGlider
Schreder HP-11 Glider
Grob 109 Motorglider
Do Not Archive |
