Paul Petty
Posted: Fri Mar 30, 2007 2:21 pm Post subject: Weight and Balance |
Hey Gang,
I am about ready to record the W&B of Ms Dixie. So I am asking questions from others and gathering as much info as possible about the correct proccedre for this. John W was so kind to send me a spread sheet on his results as well as Mark G. on how he did his. Thanks guys! I have learned one thing for sure, one cant ask to many questions from to many people to learn how to do a task. You only need to be smart enough to do whats right for you so that you understand the task at hand. In this case I also asked a good friend to help explain this to me and thought I might share his thoughts with the list and future builders.
"Just wanted to send this after we talked.
The datum is any point on the airplane where all measurements will be
taken from, in your case the nose with a plumb bob to the floor.
An arm is simply a distance from the datum to another point where you
are taking a weight, ie, center of the main wheel axles and the center
of the tailwheel with the plane in the level flight position.
The moment is the multiplication of the weight at any point times the
distance aft of the datum to that point,ie, distance X weight = moment
add the total weight and the total moments then divide the total
weight into the total moment the resultant number is the CG or where
the airplane will balance if you put the fuse across a bar or
2x4.expressed in inches aft of the datum.
when you know the empty balance point you can do some weight and
balance calculations for different loadings using the same formula.
You will need to know the distance in inches of the center of the
front seat aft of the datum,center of the rear seat,center of the
fuel tank and any other place you might add or take off weight at some
time. like a cargo compartment.
Then make up a maximum weight you might ever put there, or use your
weight if you wish. do the weight aft of the datum x the distance to
the seat and the other two measuerments you did already using the
wheels. add all together and divide and you have the new CG with this
configeration. do it with full fuel (at) 6 pounds per gallon for a full
tank and one with almost empty. if you stay in the envelope you r
gold.then do it for someone in the rear seat and do it the same way.
You will have to watch the useful load so you dont load over gross.
Please send $500,000.00 for this advice
Tom"
Hope this may help someone and if any see any holes in this as you can tell very expensive advice have at it!
_________________ Paul Petty
Kolbra #12
Ms Dixie
912 UL 70" warp |
Posted: Sat Mar 31, 2007 9:14 pm Post subject: Weight and Balance |
Paul Petty wrote:
Hey Gang,
Tom"
Paul Petty
Kolbra #12
Ms Dixie
Final assembly!
A few quick thoughts.
Datum needs to be a known distance from the wing. Is the nose
pre-drilled to the frame? If not, you could move the datum quite a bit
meaning the CG might not fall where you expect on the chord of the wing.
(It would be like using the tip of the spinner on a tractor type plane
but not specifying the spinner length.)
Do the Kolb plans specify attitude when you do the W&B? Most planes are
weighed in flight attitude & perfectly level from side to side. Tail
weight can vary a *lot* depending on whether the plane is level. Using
one scale would mean a platform the height of the scale for the other
main wheel. Most procedures specify ramps to get the mains on the
scales. That's 'cause if you pick up the plane & lower it on the scales,
the side load as the mains try to spread out again can affect the
scale readings.
Weighing should be inside with doors shut, no wind, fans, etc (affects
scale readings).
The Kolb might fly fine without these details, but it's SOP on homebuilts.
FWIW,
Charlie
Fly it up to Slobovia when you get your A/W cert.
Arty Trost
Joined: 25 May 2006 Posts: 206 Location: Sandy, Oregon
Posted: Sun Apr 01, 2007 6:19 am Post subject: Weight and Balance |
Following up on Charlie's remarks:
The type of scales you use will also make a
difference. I used two bathroom scales - semi-good
ones that cost about $40 each. I raised the tail for a
level attitude. (My Drifter is a taildragger.) I
discovered that the placement of the wheel on the
scales made a different - unless the tire was exactly
in the middle of the scale, the weight could vary by
5-8 lbs./wheel. So I noted the weight on each side,
then swapped the scales, weighed again, and took an
average of the two for each side.
Our club is going to be discussing weight and balance
this Tuesday, and we'll also discuss buying calibrated
scales for club members' use.
Arty Trost
Sandy, Oregon
--- Charlie England <ceengland(at)bellsouth.net> wrote:
| Quote: | Do the Kolb plans specify attitude when you do the
side to side. Tail
scale for the other
mains on the
can affect the
scale readings.
fans, etc (affects
scale readings).
FWIW,
Charlie
browse
Subscriptions page,
FAQ,
Web Forums!
www.LessonsFromTheEdge.com
"Life's a daring adventure or nothing"
Helen Keller
"I refuse to tip toe through life just to arrive safely at death."
Posted: Sun Apr 01, 2007 7:00 am Post subject: Weight and Balance |
The type of scales you use will also make a difference. I used two bathroom
scales >>
Hi,
When I weighed my Challenger I took the bathroom scales I used to a
department of the local Council which was responsible for ensuring that
tradesmen and shopkeepers used `approved` weights and measuring devices and
they checked my scales against `certified` weights. At least then I had an
`approved` starting point.
The `level` of everything is important too. The floor, the plane, the scales
and if you are only using one scale you must trig the wheels up level . If
using more than one scale they should be swapped around and averaged out.
Here in the UK the use of bathroom scales etc is beginning to be frowned on
by the authorities and the use of `proper` measuring devices is being
pushed. Not too serious yet but it is coming.
In the UK the weight of the plane is the main factor in deciding if the
plane is an ultralight or not so although getting the weight and balance
wrong could kill you using a little imaginative weighing technique could
keep you in the ultrlight category.
Cheers
Pat
John Williamson
Joined: 10 Jan 2006 Posts: 146 Location: Arlington, TX
Posted: Sun Apr 01, 2007 8:05 am Post subject: Re: Weight and Balance |
Hi Paul, Arty and All,
I have only been dioing weight and balance for the last 37 years and still am able to find something new every time.
You normally can't go wrong by using the FAA guidance. Here is the link to the 2007 version on the "Weight and Balance Handbook":
http://www.faa.gov/library/manuals/aircraft/media/FAA-H-8083-1A.pdf
If you use a set of bathroom scales, it will work better if you place a 3/4" board between the tire and the scale to spread the weight across the scale.
I use two scales under each main wheel and one under the tail wheel, all at the same time so the airplane stays level. On the main wheels, I put the scales very close together but not touching. I lay a 2"X'6"X18" board across them that has some small chocks attached to it. I zero the scales with the lumber on them and proceed to do the weighing.
Good luck.
_________________ John Williamson
Arlington, TX
Kolbra, 912ULS, 1640 hours
http://home.tx.rr.com/kolbrapilot |
Russ Kinne
Posted: Sun Apr 01, 2007 11:28 am Post subject: Weight and Balance |
Some time ago a Kolb pilot's wife gave birth to a daughtger at a
fairly remote fishi g camp. They had to use the same scales they
weighed the freshly-caught fish on. The little girl weighed 47 pounds.
Talk about fat ultralights!
On Apr 1, 2007, at 10:59 AM, pat ladd wrote:
bathroom scales >>
Hi,
that tradesmen and shopkeepers used `approved` weights and
measuring devices and they checked my scales against `certified`
weights. At least then I had an `approved` starting point.
the scales and if you are only using one scale you must trig the
wheels up level . If using more than one scale they should be
frowned on by the authorities and the use of `proper` measuring
devices is being pushed. Not too serious yet but it is coming.
the plane is an ultralight or not so although getting the weight
and balance wrong could kill you using a little imaginative
weighing technique could keep you in the ultrlight category.
Cheers
Pat
Arty Trost
Posted: Sun Apr 01, 2007 9:15 pm Post subject: Weight and Balance |
Thanks, John.
I'm swapping out my two 5-gal. gas tanks for two
30-liter (7.92 gal.) gas tanks, so will be doing a new
weight and balance. I've used a board across the two
scales for the main wheels, but never used two scales
for each main. I'll try it.
See you at MV -
Arty Trost
Sandy, Oregon
--- John Williamson <kolbrapilot1(at)tx.rr.com> wrote:
new every time.
snip
Helen Keller
