jose_m_toro(at)yahoo.com Guest
Posted: Wed Apr 04, 2007 4:19 pm Post subject: Battery box for Odyssey PC625 battery |
Hi All:
Where can I buy a battery box for a Odyssey PC625 battery?
Thanks!
Jose
No need to miss a message. [url=http://us.rd.yahoo.com/evt=43910/*http://mobile.yahoo.com/mail ]Get email on-the-go [/url]
with Yahoo! Mail for Mobile. [url=http://us.rd.yahoo.com/evt=43910/*http://mobile.yahoo.com/mail ]Get started.[/url] [quote][b]
dosmythe(at)cox.net Guest
Posted: Wed Apr 04, 2007 4:27 pm Post subject: Battery box for Odyssey PC625 battery |
Jose,
I have the Odyssey 680 and I understand it does not require a battery box. This may be the case of your PC625. Just fabricate a tray and securing method for the battery to sit on.
Don Smythe
Lynn Matteson
Posted: Thu Apr 05, 2007 5:46 am Post subject: Battery box for Odyssey PC625 battery |
Jose-
You might try the battery box that Aircraft Spruce sells for the 680,
and shim it to fit your 625.
Lynn
On Apr 4, 2007, at 8:18 PM, Jose M. Toro wrote:
| Quote: | Hi All:
Thanks!
Jose
No need to miss a message. Get email on-the-go
with Yahoo! Mail for Mobile. Get started._-
============================================================ _-
http://www.matronics.com/Navigator?Kitfox-List_-
forums.matronics.com_-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Posted: Thu Apr 05, 2007 10:32 am Post subject: Battery box for Odyssey PC625 battery |
Lynn:
680 is longer than 625 (7.27" vs 6.70"), but is narrower (3.11" vs 3.90"). Have you seen a box modified before? Seems like it will be too narrow for the 6257
Thanks!
José
lcfitt(at)sbcglobal.net Guest
Posted: Thu Apr 05, 2007 12:05 pm Post subject: Battery box for Odyssey PC625 battery |
Jose,
I bent a piece of SS into a "J" shape that cradles the battery and slotted
top and bottom for nylon strapping with velcro as a fastener. Adel clamps
fasten it to the framework. If the battery doesn't need a box to conatain
possible seepage of electrolyte, a simple fixture like this will work. The
Lancair guy did this on his, mounting two 12 v. batteries side-by-side in
series for his 24v. system, but he was comfortable with aluminum for the
tray.
Lowell
marin
Posted: Thu Apr 05, 2007 1:12 pm Post subject: Battery box for Odyssey PC625 battery |
Jose
Try this site
http://www.rvwoody.com/battbox.html
Marin Streeter
_________________ Marin |
Lynn Matteson
Posted: Fri Apr 06, 2007 3:13 am Post subject: Battery box for Odyssey PC625 battery |
Sorry, Jose, but I have not seen the box modified. I just assumed
that the 625, being smaller, would fit with shimming. Because the box
that I have (Spruce's box for the 680) is a 3-sided box...both sides,
and a front...with flanges for mounting against the firewall, I would
think that you could place shims under the flanges when bolting to
the firewall (or whatever you are mounting to. As far as length is
concerned, the extra space...the .570" difference in length...could
be taken up with balsa wood or some other light-weight shim.
The box that I got from Spruce is powder-coated black, aluminum, has
the aforementioned 3 surfaces, flanges for mounting, and has a lip at
the top that prevents the battery from sliding up, and for the life
of me, I can't recall if there is a full bottom, or if that is also
just a lip. But the top is readily accessible, and fits the 680 like
a glove. I don't know why they (Spruce) don't show the 625 battery or
a box to fit.
But I'm sure the 680 box could be easily modified to fit.
Lynn
On Apr 5, 2007, at 2:31 PM, Jose M. Toro wrote:
<jose_m_toro(at)yahoo.com>
Lynn:
Thanks!
José
N369LM |
Posted: Fri Apr 06, 2007 5:42 am Post subject: Battery box for Odyssey PC625 battery |
Thanks for the details Lynn!
