Balancing control surfaces
shirleyh
PostPosted: Wed Apr 11, 2007 1:52 am    Post subject: Balancing control surfaces Reply with quote
Listers, some advice please from those with more experience than me. Having
flown my RV6 for a year now, I've finally got round to having her painted.
(Bright red - looks fabulous!). I know that I need to rebalance the
elevators, and I think I know how to do that - the Vans manual does cover
that. However, my plastic plane colleagues are adamant that I must do the
same with the ailerons. The Vans manual is, as far as I can find, silent on
that topic. It only refers to the galvanised water pipe being the
counterweight. Other RV builders I've spoken to have not balanced the
ailerons and no-one has had any flutter problems that I know of. Any
comments or advice much appreciated.
Shirley
Perth
khorton01(at)rogers.com
PostPosted: Wed Apr 11, 2007 3:42 am    Post subject: Balancing control surfaces Reply with quote
<ShirleyH(at)oceanbroadband.net>
me. Having
painted.
cover
do the
silent on
The elevators are 100% balanced - i.e. the balance weight is adjusted
so it balances 100% of the moment around the hinge line. Some
aircraft have aileron balances that are required to be 100% balanced,
or some specific lower percentage. But, the short wing RVs have very
stiff wings, thus Van did not need to be so particular about aileron
balance weights. The specified water pipe is heavy enough. No need
to add weight to the aileron balance, and no need to worry about
aileron flutter.
Kevin Horton
RV-8 (Finishing Kit)
Ottawa, Canada
http://www.kilohotel.com/rv8
me. Having
painted.
cover
do the
silent on
Shirley
Perth
shirleyh
PostPosted: Wed Apr 11, 2007 3:51 am    Post subject: Re: Balancing control surfaces Reply with quote
Thanks for the explanation!
Shirley
