pwatsonfnp(at)comcast.net Guest
Posted: Thu Apr 12, 2007 3:01 pm Post subject: antenna questions |
Hi my name is Paul Watson and I’m new to the RV7 list. I have been building my 7 for the past 2 ½ years and just now finding out about this resource. I just don’t get out of my shop much but glad I found you all better late than never...
I nearing completion of my project and needing to install antennas and wanted to avoid the wing tip antennas if possible but realize there is not much choice for a VOR/LOC/GS antenna except the “cat whiskers” mounted on the vertical stabilizer.
CI-158C Dipole was recommended by one of my avionics sources. The base of the antenna is considerably larger then the width of the top of the VS and other issues of installation I don’t have figured out.
Are there any builders out there with experience mounting this type of antenna on an RV7? Other suggestions? I am open to your experienced input.
Paul Watson
Vancouver, WA
360-936-9316
| - The Matronics RV7-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV7-List |
andrew.phillips(at)sympat Guest
Posted: Thu Apr 12, 2007 3:27 pm Post subject: antenna questions |
I can't answer that question but I'm sure if you check www.vansairforce.com you will probably find the answer there!
Paul Watson wrote:
[quote] st1\:*{behavior:url(#default#ieooui) } <![endif]-->
Paul Watson
Vancouver, WA
360-936-9316
sfarner(at)gmail.com Guest
Posted: Thu Apr 12, 2007 3:51 pm Post subject: antenna questions |
Paul,
I used the OMNI VOR Nav antenna AV-532L
(http://www.aircraftspruce.com/catalog/avpages/av532.php). It's about
$100 cheaper than the Comant antenna. I mounted it on the belly skin
just in front of the HS (between F-708 and F-709 I think). It's held
in place with two AN3 bolts with doublers on the belly skin. Reception
is great (even from inside the hangar!).
Scott
RV-7A N653S
92 hours
On 4/12/07, andrew phillips <andrew.phillips(at)sympatico.ca> wrote:
Quote: | I can't answer that question but I'm sure if you check www.vansairforce.com
Paul Watson wrote:
Hi my name is Paul Watson and I'm new to the RV7 list. I have been building
just don't get out of my shop much but glad I found you all better late than
never...
much choice for a VOR/LOC/GS antenna except the "cat whiskers" mounted on
other issues of installation I don't have figured out.
Paul Watson
Vancouver, WA
360-936-9316
mimartin(at)wyoming.com Guest
Posted: Thu Apr 12, 2007 4:03 pm Post subject: antenna questions |
Paul i mounted my vor antenna on the bottom of the tail section under the horizontal stabilizer
John Brunke
Posted: Thu Apr 12, 2007 5:59 pm Post subject: antenna questions |
Scott,
Would you happen to have picture of the antenna mounted in that location?
Do you have to keep cleaning the antenna from exhaust residue?
John Brunke
RV7 tip-up, tail and wings done
Posted: Thu Apr 12, 2007 7:15 pm Post subject: antenna questions |
Thanks for your reply. Did you angle the antenna up toward HS for better
ground clearance or is it an issue?
Paul
Posted: Thu Apr 12, 2007 8:27 pm Post subject: antenna questions |
I mounted the antenna flat on bottom of tail section on rv6 good ground
clearance
Posted: Fri Apr 13, 2007 12:48 am Post subject: antenna questions |
I'll shoot a picture of it when I'm at the airport tomorrow.
The front of the "puck" gets most of the gunk. Haven't really thought
about cleaning it yet.
Scott
On 4/12/07, J. Brunke <jdoody727(at)comcast.net> wrote:
Scott,
John Brunke
frank.hinde(at)hp.com Guest
Posted: Fri Apr 13, 2007 5:56 am Post subject: antenna questions |
You can also make a little fairing for the front/rear of the puck too.
Frank
