pitot tube
slyck(at)frontiernet.net
PostPosted: Wed Feb 01, 2006 8:32 pm    Post subject: pitot tube Reply with quote
Don't know if you are speaking of the length of the probe
or the tubing going to the cabin instrument. The probe
can be any length. The tubing also. -within reason, not talking miles
here.
Pressure drop of a fluid in a pipe (air being also a fluid)
is a function of cross section times distance traveled.
The diff in a pitot static system is that there is no flow,
hence no pressure drop.
-BB
David.Lehman
PostPosted: Thu Feb 02, 2006 6:26 am    Post subject: pitot tube Reply with quote
Thanx Bob, it's the tube itself and I figured it didn't matter...
DVD
here.
-BB
ô¿ô
"Both optimists and pessimists contribute to the society. The optimist invents the aeroplane, the pessimist the parachute."
--- George Bernard Shaw
George Myers
PostPosted: Thu Feb 02, 2006 7:12 am    Post subject: pitot tube Reply with quote
They only say that to make us feel better...
David.Lehman
PostPosted: Thu Feb 02, 2006 5:23 pm    Post subject: Re: pitot tube Reply with quote
here.
-BB
Bob...
Here's a "duh"... Given what you wrote, I really don't need the "tube" because the bulkhead fitting is forward of the nose about 7/8" and should be in undisturbed air?...
Thanx...
DVD
ô¿ô
jhankin(at)planters.net
PostPosted: Mon Feb 06, 2006 5:09 am    Post subject: Pitot Tube Reply with quote
With my Firefly on the ground the pitot tube is almost level, with it in
flying attitude the tube is a good bit down. Will this affect the
performance of the air speed indicator. It is now in the middle of the nose
cone.
Jimmy Hankinson
912-863-7384
Firefly 035
JYL (Sylvania)
Pegasus Field (Home)
2000 Feet X 100 Feet- Grass
Rocky Ford, Georgia
Richard Pike
PostPosted: Mon Feb 06, 2006 7:41 am    Post subject: Pitot Tube Reply with quote
Mine is slightly pointing down while on the ground and it works OK. It
is below the nose bowl by several inches and slightly aft of the front end.
Richard Pike
MKIII N420P (420ldPoops)
cone.
Jimmy Hankinson
912-863-7384
Firefly 035
JYL (Sylvania)
Rocky Ford, Georgia
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
