airvair601(at)yahoo.com Guest
Posted: Sat Apr 14, 2007 7:49 am Post subject: fuel system suggestions |
| Quote: | Ok guys I have a questions for the group about fuel systems that my <?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />EAA technical advisor (TA) asked us. First some background. Our advisor has built and flown behind many aircraft. He has restored several classic aircraft, is a retired airline captain and currently spends his
days flying corporate and running an airport. He is the kind of guy who has, or will, fly behind everything he suggests.. Our project is a Zenith 601 HDS that has 2 ten gallon leading edge wing tanks. It currently calls for a plain vanilla corvair engine and an MA3 carb. TA has
warmed to the idea of Corvair, although he is not crazy about it. He has helped people in the past with other auto-conversion and was helpful, EAA technical advisor (TA) asked us. First some background. Our | 0 | Quote: | | EAA technical advisor (TA) asked us. First some background. Our | 1 | Quote: | | EAA technical advisor (TA) asked us. First some background. Our | 2 | Quote: | | EAA technical advisor (TA) asked us. First some background. Our | 3 | Quote: | | EAA technical advisor (TA) asked us. First some background. Our | 4 | Quote: | | EAA technical advisor (TA) asked us. First some background. Our | 5 | Quote: | | EAA technical advisor (TA) asked us. First some background. Our | 6 | Quote: | | EAA technical advisor (TA) asked us. First some background. Our | 7 | Quote: | | EAA technical advisor (TA) asked us. First some background. Our | 8 | Quote: | | EAA technical advisor (TA) asked us. First some background. Our | 9 | Quote: | | advisor has built and flown behind many aircraft. He has restored several | 0 | Quote: | | advisor has built and flown behind many aircraft. He has restored several | 1 | Quote: | | advisor has built and flown behind many aircraft. He has restored several | 2 | Quote: | | advisor has built and flown behind many aircraft. He has restored several | 3 | Quote: | | advisor has built and flown behind many aircraft. He has restored several | 4 | Quote: | | advisor has built and flown behind many aircraft. He has restored several | 5 | Quote: | | advisor has built and flown behind many aircraft. He has restored several | 6
Ahhh...imagining that irresistible "new car" smell?
Check out [url=http://us.rd.yahoo.com/evt=48245/*http://autos.yahoo.com/new_cars.html;_ylc=X3oDMTE1YW1jcXJ2BF9TAzk3MTA3MDc2BHNlYwNtYWlsdGFncwRzbGsDbmV3LWNhcnM-]new cars at Yahoo! Autos.[/url] [quote][b]
gboothe5(at)comcast.net Guest
Posted: Sat Apr 14, 2007 8:12 am Post subject: fuel system suggestions |
Phill,
I would never question the wisdom of a TA, but not all TA’s look at things the same. Yours suggests the wisdom of a complicated fuel delivery system which exceeds the design of the manufacturer. That’s your choice.
There is a common feeling that simplicity is the best answer. The most simple fuel delivery is with a header tank, gravity feeding to the carb. The classic Taylorcraft BC12-D had two 6 gallon wing tanks that gravity fed into the 12 gallon header tank. When the header tank got low you open the valve and drain from a wing tank. When the header tank was full, you closed the valve.
The 601 HDS is similar as it is designed to use either an 8 or 18 gallon header tank. The only difference, obviously, is that you need the fuel pumps to deliver to it. Most 601 drivers that have planes with header tanks feel that the header tank is the only insurance they need to get to a safe place if the fuel pumps fail. The key factor being: Keep your header tank full.
The MA3 carb likes gravity pressure best. This is described in length by William Wynne. I am hoping that you plan on using a header tank. Whatever means of delivering to that tank is up to you.
Gary Boothe
Cool, CA
601 HDSTD, WW Conversion 90% done,
Tail done, wings done, working on c-section
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of 601corvair
Sent: Saturday, April 14, 2007 8:49 AM
To: Zenith list
Subject: fuel system suggestions
| Quote: | | Ok guys I have a questions for the group about fuel systems that my EAA technical advisor (TA) asked us. First some background. Our advisor has built and flown behind many aircraft. He has restored several classic aircraft, is a retired airline captain and currently spends his days flying corporate and running an airport. He is the kind of guy who has, or will, fly behind everything he suggests.. Our project is a Zenith 601 HDS that has 2 ten gallon leading edge wing tanks. It currently calls for a plain vanilla corvair engine and an MA3 carb. TA has warmed to the idea of Corvair, although he is not crazy about it. He has helped people in the past with other auto-conversion and was helpful, but not overly enthusiastic. All that being said, here is the issue. During a conversation on fuel system design we showed him the William Wynne (www.flycorvair.com) design for the Zenith XL, using the 2 in series electrical pumps and no mechanical pump. He recommended against it on the principle that we had placed all our eggs in the one basket, that being the electrical system. His suggestion was to use one electrical pump and the corvair mechanical pump and fly it like a Cherokee using the electrical pump as a boost pump and only during take off and landing. Alternatively, he suggested a header tank, pumping fuel to the header and gravity feeding the carb. This would probably require a return line to the wing tank. We discussed this for sometime and then he asked me this. Could I name a certificated aircraft, low wing, that only had one type of pump to move fuel to the carb? If not, why did I think that was? Interesting question as the FAA guys “fly behind” lots of airplanes. I would be interested in any help or suggestion I can get with fuel systems, especially flying airplanes and their different fuel systems. Thanks phill |
Check out [url=http://us.rd.yahoo.com/evt=48245/*http:/autos.yahoo.com/new_cars.html;_ylc=X3oDMTE1YW1jcXJ2BF9TAzk3MTA3MDc2BHNlYwNtYWlsdGFncwRzbGsDbmV3LWNhcnM-]new cars at Yahoo! Autos.[/url] | Quote: | | http://www.matronics.com/Navigator?Zenith-List | 012345
bryanmmartin
Posted: Sat Apr 14, 2007 10:05 am Post subject: fuel system suggestions |
Certificated aircraft use magneto ignition systems that don't rely on
the electrical system to operate. With a mechanical pump, these
engines can continue run if the entire electrical system fails.
That's why they have mechanical pumps. They have electric pumps to
push the air out of the lines and get fuel to the mechanical pump and
carb to allow the engine to start and continue to run in the nose
high attitude during climb.
I assume you have an automotive type ignition system that relies on
electrical power to drive it. In that case, it doesn't matter that
both of your pumps are electric. If you lose the electrical system,
and that's about the only way you could lose both pumps, you are a
glider pilot anyway.
Electric fuel pumps are more reliable than mechanical pumps. With
electric pumps, you can locate them so that you are always pushing
fuel up to the engine. Mechanical pumps must be mounted to the engine
where they will be sucking fuel up to the engine from the low-wing
mounted tanks. If you can avoid drawing a vacuum on the fuel lines,
you have a very low risk for vapor lock, especially with auto fuel.
You can always install a backup battery to run the pumps and ignition
if the main system fails.
Personally, I would put the pumps in parallel using a couple of Tees
just so you aren't pushing (or sucking) fuel through the inoperative
pump.
On Apr 14, 2007, at 11:48 AM, 601corvair wrote:
| Quote: | He recommended against it on the principle that we had placed all
_________________ --
Bryan Martin
do not archive. |
Posted: Sat Apr 14, 2007 10:50 am Post subject: fuel system suggestions |
Hi Phil,
Wing tanks are good in the HDS. The header tank does cause you to think
about current range as you use
and refill it from the wing tanks. You have to be comfortable with the
tank being in front of you and it should
be built of .040 or better. I prefer a smaller 9-1/2 gal header for
space behind the instrument panel.
Fuel pump issues are easily resolved with two pumps on the firewall in
parallel and using one during cruise.
A pump on each wing tank simplifies selective filling with a
left-right-both-off valve at the center console.
I wouldn't put a mechanical pump on the Corvair as I've replaced too
many mechanical pumps, but not
one electric pump. You shouldn't need a return line to the wing tanks
unless you're going high pressure
for fuel injection. I don't recommend it for the complexity it
represents. Carburetors are just simpler.
The Corvair is a good engine and won't let you down if you keep fuel
delivery simple and adhere to WWs
crank recommendations etc. Auto conversions can be extremely reliable if
you stay with current best practice.
I disagree on electrical pumps placed in series as one could either
starve or clog the second one. In parallel
they are each free to feed or not selectively. My HDS is set up this way
and has nearly 100 hours
running without problems. You'll find most of this is well covered in
the archives.
Good luck,
601corvair wrote:
| Quote: | Our project is a
fuel systems,
