RandyTa(at)comcast.net Guest
Posted: Sat Apr 14, 2007 10:05 am Post subject: Model 5 STC |
A question for you technical guys. Is there an STC that allows you to increase the gross weight on a model 5 from the early 1,400 pound gross to 1,550 which was in the later model?
Randy
rdmac(at)swbell.net Guest
Posted: Sat Apr 14, 2007 5:28 pm Post subject: Model 5 STC |
Not sure but I think STC’s only applied to certified aircraft. Jon McBean maybe able to answer your question on increasing the gross weight, if it’s even possible.
Roger Mac
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Randy Tavishati
Sent: Saturday, April 14, 2007 1:04 PM
Subject: Model 5 STC
Randy
| Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 01234
dcsfoto
Posted: Sat Apr 14, 2007 5:30 pm Post subject: Re: Model 5 STC |
you do not need an STC. STCs only apply to aircraft that have type certificates
talk to john at Kitfox he will tell you what you need to have a safe airplane
Guy Buchanan
Posted: Sat Apr 14, 2007 9:48 pm Post subject: Model 5 STC |
At 11:04 AM 4/14/2007, you wrote:
| Quote: | | A question for you technical guys. Is there an STC that allows you to increase the gross weight on a model 5 from the early 1,400 pound gross to 1,550 which was in the later model? |
The other posters are right. STC's only apply to certified aircraft. You can, as the builder, specify any gross weight you want. Now as to the structural mods required to go from Skystar's 1400 pound gross to 1550 pound gross you're asking a questing hashed out several times this year with, as I recall, no definitive answer. I certainly wish someone could find definitive design information for these aircraft. It would be a shame if it all just disappeared.
John, did you get Skystar's and Denney's design information when you purchased the assets? Is such information available? Can we put together definitive information regarding the design changes to go from 1050 to 1200 for the IV, and from 1400 to 1550 for the V?
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 100% done, thanks mostly to Bob Ducar. [quote][b]
Deceased K-IV 1200
A glider pilot too. |
Float Flyr
Posted: Sun Apr 15, 2007 6:23 am Post subject: Model 5 STC |
The item of STCs depends on which part of the earth you happen to be. I know a bit about Canada and precious little about the U.S. regs. In Canada and the U.S. STCs only apply to certified aircraft. No amateur built is certified.
In Canada you may make major modifications to your plane but you may have to be inspected and/or do a test flight program and the normal 26 hr of flying within 26nm of the designated aerodrome(s).
Also in Canada if you have a BULA (Basic Ultra Light Aircraft) you are open to do pretty anything you want with the plane and fly it. ( Square wheels while not practical are legal ) If your plane is AULA ( Advanced Ultra Light Aircraft ) then the plane meets a conformity standard and no modifications are allowed. that leaves us with amateur built discussed above.
Clear as Mud?.....thought so.
Noel [quote]
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
JJProbasco(at)cs.com Guest
Posted: Sun Apr 15, 2007 8:30 am Post subject: Model 5 STC |
My Model 5 kit (1/95) came with .058" wall wing spars. When I later inquired of Sky Star what is needed for the 1550 gross, they told me only needed to switch to the .065" spars and use a NASA grade bolt for the lower wing strut to fuse connection. They indicated some of the earlier Vixen based Model 5s had slightly lighter carry through tubes that would not be adequate; but, based on my kit serial number my fuse was adequate. Of course, Unfortunately, I don't have this in writing from Sky Star.
At the time SkyStar was having difficulty getting the .058 wall spars for the Kitfox light, so they were more than happy to exchange my spars for the .065 wall ones.
smokey_bear_40220(at)yaho Guest
Posted: Sun Apr 15, 2007 1:12 pm Post subject: Model 5 STC |
When I went to the FAA to set up my inspection for my
S-5, the lead inspector asked what gross weight I was
going to put on it. I told him it was designed for
1550 and I wanted to increase to 1650 for the floats.
He said, "No, make it for a weight I will never
exceed, test it and insure it for that weight.
Protects your insurance and license."
Mine is now set at 1750, a weight I will never fly to
again unless someone is shooting at me. But I might
see 1600 or so on floats and be covered. So far
though I haven't even been to 1550 after testing.
I had to recalculate the max allowable G load for the
new weight and put it in the logbook. I think it came
to 3.5+ G's and I forget the minus G's. That was also
a loading I do not want to fly anywhere near when I am
heavy.
Kurt S. s-5/NSI turbo
--- Guy Buchanan <bnn(at)nethere.com> wrote:
that allows you
early 1,400 pound
jdmcbean(at)kitfoxaircraf Guest
Posted: Mon Apr 16, 2007 7:22 pm Post subject: Model 5 STC |
Guy,
We do have a FAQ page on the web although we have not had a chance to get info up on the page... As for the design changes.. I'll contact you off list.. but for the record there is not an upgrade for the Model IV 1050 to increase to 1200.. with one exception and that was specifically for float operations and that change was not encouraged.
[quote] --
