		dashvii(at)hotmail.com Guest
				 Posted: Sat Apr 14, 2007 4:56 pm    Post subject: gap seal experiment |
				To all,
     The proposed gap seal experiment that I am going to be doing flight
 testing for is finally at hand.  As soon as the guys get back from Sun-N-Fun
 I'll begin with the baseline tests, and then do a retest after the
 modifications are done.  I can't tell you how much of an increase in
 anything that we'll get from doing this without the testing.  My thesis
 states that we'll see an increase in top speed, an increase in
 endurance/range, an increase in roll rate and climb performance.  Some
 negative things that I expect to have are an increase in stall speed and an
 increase in landing distances though.  I don't expect that the stall speed
 increase will be more than a couple of knots.  With such a short landing
 distance I don't expect that even 10% would matter.
 The things that I really want to focus on are stall speed and max speed.
 Secondarily will concentrate on climb and glide performances.  All data will
 be converted back to ISA conditions for a reasonable comparison.  The looks
 of the aircraft will change very slightly as most of the gaps to seal are on
 the underside of the aircraft, with only an aileron gap seal for the top.
 We will explore the entire envelope to make sure that it is safe and will
 investigate the performance gains.  My basic results will be posted on this
 site in probably 2 months time.
 This will most likely be some of the last flying that I do with Arion since
 I am relocating to Houston.  It has been a privelage and I am going to miss
 flying the Lightning's in particular.  After flying Rick's plane and the
 test plane I will leave with about 60 some odd hours in Lightning aircraft.
 Now I plan to finish up my CFI and get some students to start teaching.
 Hopefully I can make it back to SYI again at some point to check on how
 things are going with the Arion team.  Brian Whittingham
 Interest Rates Fall Again! $430,000 Mortgage for $1,399/mo - Calculate new
 payment
  |  | - The Matronics Lightning-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?Lightning-List |
		lbmathias(at)verizon.net Guest
				 Posted: Sun Apr 15, 2007 3:44 am    Post subject: gap seal experiment |
				Brian,
     Good luck with the testing and the completion of your thesis.   Thanks
 for all your efforts and also your very informative reports and insights on
 happenings at the Arion hangar.
     I'll watch for the results of your experiments.
                                                 Best wishes, Linda Mathias
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
