rvbuilder(at)sausen.net Guest
Posted: Tue Apr 24, 2007 6:24 pm Post subject: Easy question? |
I have a device that lives quite happily between around 11vdc to around 13.9vdc and then promptly stops working above that number. Problem is most charging systems are above 14vdc. It uses milliamps at best so I'm looking for the easiest way to drop a volt.
Michael Sausen
RV-10 #352 Limbo
echristley(at)nc.rr.com Guest
Posted: Tue Apr 24, 2007 7:22 pm Post subject: Easy question? |
RV Builder (Michael Sausen) wrote:
A couple of diodes in series will give you between 1 and 1.5 volt drop.
Posted: Wed Apr 25, 2007 7:20 am Post subject: Easy question? |
See, I knew it was easy. I completely forgot about the drop from a diode. Thanks!
