Bill Schlatterer
Posted: Sun Apr 22, 2007 2:07 pm Post subject: Torque Values for Sensors and other not nuts and bolts stuf |
Where or how would you find what to torque something like a Oil Temp Sensor? Big brass fitting, 7/8 socket size into the case just above the oil filter. Easy enough to get to with a crows foot and extension but how much do you tighten it? I'm thinking something like 100-125 inch pounds which feels like enough to flatten the copper gasket?
How about carb and fuel pump fittings ? ( I did find the AN values in the AC43 but nothing on the "banjo" part,…. Why do they call it a banjo fitting ? )
Is there any kind of rule of thumb for things which don't fall into the nut and bolt category? How about the synthetic Oil filler tube on an O-360 ? Takes a 1 1/8 wrench but it would look like you could twist it off if you're not careful? (Snug, then a little more, and wire it ??
All help appreciated, thanks
Bill S
7a Ark
Wired, cowled, canopied and "engining"
But nowhere near done ;-(
Do not archive [quote][b]
| - The Matronics RV7-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV7-List |
frank.hinde(at)hp.com Guest
Posted: Mon Apr 23, 2007 6:33 am Post subject: Torque Values for Sensors and other not nuts and bolts stuf |
My personal take is leave the torque wrench on the bench and do it by feel...You'll spend a surprising amount of time torquing everything this way.
Frank
From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Bill Schlatterer
Sent: Sunday, April 22, 2007 3:08 PM
To: rv7-list(at)matronics.com; rv-list(at)matronics.com; RV7A(at)yahoogroups.com
Subject: Torque Values for Sensors and other not nuts and bolts stuff ?
Bill S
7a Ark
href="http://www.matronics.com/Navigator?RV7-List">http://www.matronics.com/Navigator?RV7-List
jimpercy(at)mindspring.co Guest
Posted: Tue Apr 24, 2007 5:10 am Post subject: Torque Values for Sensors and other not nuts and bolts stuf |
Those values can be found in a Lycoming overhaul manual, except maybe the oil filler spout.
The crush type gaskets are not torqued. They are tightened until there is contact (finger tight) then further tightened a specified number of degrees. I don't have my manual handy so I don't know the actual values. The seam on the gasket goes on the engine side.
For the non-specified hardware like carb nuts, etc, there is a chart of torque values based on diameter and thread pitch of the fastener. Again, I don't have the numbers available right now. That overhaul manual is probably a good investment if you don't have it.
Jim Percy
