carlbell(at)gforcecable.c Guest
Posted: Sun Apr 22, 2007 6:41 am Post subject: RV Advice, one leg flyer |
Hello all,
I am new to the list and starting the journey to build an RV but could use some advice before I get going. I have a bit of a dilemma which I need to work out before I order more than the RV empennage kit. I am a left leg above the knee amputee and I believe I need to work with an instructor to figure out the plane for me to build and modify as appropriate. I can fly standard Cherokee’s, Arrow’s, etc by using my good leg for either the left or right rudder pedal as required and the hand brake if I need to hit both brakes at once. Of course the Piper line has nose wheel steering and I find this very easy for me to accomplish. I am just not sure what direction I should pursue for the RV and feel I could use some flight instruction to try and figure it out. I know I will need a hand brake to hit both brakes simultaneously, and I’m thinking I will get more positive steering control on an RV by going with a tail dragger vs a nose wheel version and trying the differential toe braking. Any help you all can offer would be sincerely appreciated. If there are any AK’s amputees flying RV’s that can clue me in, it would terrific. I’m retiring next month and can work on this full time. I was commercial-instrument rated, but now have had to revert to private. Thanks Carl
[b]Carl W Bell[/b]
[b]New Venture Consulting[/b]
Office: 803.648.3407
Mobile: 803.640.2760
www.newventureconsulting.com
carlbell(at)gforcecable.com (carlbell(at)gforcecable.com)
Bob Collins
Joined: 11 Mar 2006 Posts: 470 Location: St. Paul, Minnesota
Posted: Sun Apr 22, 2007 7:39 am Post subject: RV Advice, one leg flyer |
Carl, there was just an article on this in Kitplanes a month or so ago, and the plane profiled -- along with two pilots -- was an RV. I think I've got a copy of it around here somewhere and will try to send it to you off ist.
bob
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Carl Bell
Sent: Sunday, April 22, 2007 9:39 AM
To: rv-list(at)matronics.com
Subject: RV Advice, one leg flyer
Hello all,
[b]Carl W Bell[/b]
href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
_________________ Bob Collins
St. Paul, Minn.
Letters from Flyover Country
http://rvnewsletter.blogspot.com/ |
LloydDR(at)wernerco.com Guest
Posted: Sun Apr 22, 2007 7:42 am Post subject: RV Advice, one leg flyer |
There is an article in EAA's sport aviation of a double amputee who built and flies an RV8, so I am sure it can be done with some modifications. I am traveling right now for transition training, and will find the article for you as soon as I get home. You can probably go to the EAA site and search for it if you need it faster. It was a great read, and maybe he can help you do the mods required.
Dan
N289DT
RV10E
Sent: Sunday, April 22, 2007 10:39 AM
Hello all,
[b]Carl W Bell[/b]
wdleonard(at)gmail.com Guest
Posted: Sun Apr 22, 2007 8:10 am Post subject: RV Advice, one leg flyer |
Carl,
There used to be a paraplegic on this list building a super-6 but I have forgotten his name and not heard from him lately. As I recall, he had enough strength on the right side to stomp on that right rudder for take-off.
For you, I would definitely recommend a tricycle gear. I'm sure you could fly a TD if you had your mind set on it, but it would probably require a special prosthesis so you could manipulate both pedals at once, and probably both brakes too. The prob with a TD is that you really have to dance on the pedals. You sometimes have to go very quickly from one rudder to the other in order to overt a ground loop, then quickly back again, and back again etc... In a big cross wind, a touch of break is sometimes needed to stay on the runway as the tail transitions - but you still have to dance on the pedals.
So unless you have some pent-up childhood need to fly a taildragger, get the tri-gear. I have never flown a tri-gear RV, but they shouldn't be any more difficult than the other planes you fly. Fairly easy to install hand brake systems. Side-by-side models are your best bet for transition training.
Good luck,
David Leonard
Turbo Rotary RV-6 N4VY
N4VY.RotaryRoster.net
www.RotaryRoster.net
On 4/22/07, Carl Bell <carlbell(at)gforcecable.com (carlbell(at)gforcecable.com)> wrote: [quote]
Hello all,
I am new to the list and starting the journey to build an RV but could use some advice before I get going. I have a bit of a dilemma which I need to work out before I order more than the RV empennage kit. I am a left leg above the knee amputee and I believe I need to work with an instructor to figure out the plane for me to build and modify as appropriate. I can fly standard Cherokee's, Arrow's, etc by using my good leg for either the left or right rudder pedal as required and the hand brake if I need to hit both brakes at once. Of course the Piper line has nose wheel steering and I find this very easy for me to accomplish. I am just not sure what direction I should pursue for the RV and feel I could use some flight instruction to try and figure it out. I know I will need a hand brake to hit both brakes simultaneously, and I'm thinking I will get more positive steering control on an RV by going with a tail dragger vs a nose wheel version and trying the differential toe braking. Any help you all can offer would be sincerely appreciated. If there are any AK's amputees flying RV's that can clue me in, it would terrific. I'm retiring next month and can work on this full time. I was commercial-instrument rated, but now have had to revert to private. Thanks Carl
[b]Carl W Bell[/b]
Vanremog(at)aol.com Guest
Posted: Sun Apr 22, 2007 9:14 am Post subject: RV Advice, one leg flyer |
In a message dated 4/22/2007 7:43:00 A.M. Pacific Daylight Time,
carlbell(at)gforcecable.com writes:
once.
Carl-
You need to get in touch with Bruce Cruikshank at Livermore, CA.
Bruce is a double amputee who flies the RV-4 "Cover Girl" that was featured
in Sport Aviation a few years back and is building an RV-9A currently. I
believe you can contact him thru KS AVIONICS 510-785-9407
_http://www.ksavionics.com_ (http://www.ksavionics.com)
If you can't get ahold of him, e-mail me direct and I will arrange to put
you in touch with him. He designed his own system to interconnect his
prosthesis to the rudder pedals and he seems to do very well. We just flew to lunch
with him yesterday.
GV (RV-6A N1GV O-360-A1A, C/S, Flying 844hrs, Silicon Valley, CA)
************************************** See what's free at http://www.aol.com
Posted: Sun Apr 22, 2007 9:47 am Post subject: RV Advice, one leg flyer |
Thanks a bunch, I will call him at KS on Monday and see if I can talk with him. I read the article and was very impressed with what he has accomplished. I hoping to get away with hand brakes and the dancing foot method since I’m used to it, but most feel a nose dragger is the way to go, which is fine with me. I want to find a CFI with a 6A, 7A or 9A and give it a go. Thanks again. Carl
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Vanremog(at)aol.com
Sent: Sunday, April 22, 2007 1:13 PM
Subject: Re: RV Advice, one leg flyer
In a message dated 4/22/2007 7:43:00 A.M. Pacific Daylight Time, carlbell(at)gforcecable.com writes:
I am new to the list and starting the journey to build an RV but could use some advice before I get going. I have a bit of a dilemma which I need to work out before I order more than the RV empennage kit. I am a left leg above the knee amputee and I believe I need to work with an instructor to figure out the plane for me to build and modify as appropriate. I can fly standard Cherokee’s, Arrow’s, etc by using my good leg for either the left or right rudder pedal as required and the hand brake if I need to hit both brakes at once. |
Carl-
Bruce is a double amputee who flies the RV-4 "Cover Girl" that was featured in Sport Aviation a few years back and is building an RV-9A currently. I believe you can contact him thru KS AVIONICS 510-785-9407 http://www.ksavionics.com
If you can't get ahold of him, e-mail me direct and I will arrange to put you in touch with him. He designed his own system to interconnect his prosthesis to the rudder pedals and he seems to do very well. We just flew to lunch with him yesterday.
See what's free at AOL.com.
| Quote: | | http://www.matronics.com/Navigator?RV-List | 01234
Posted: Sun Apr 22, 2007 9:52 am Post subject: RV Advice, one leg flyer |
Thanks Dan,
I saw the article and he is really fantastic, I am trying to do it with less special stuff and use the good foot more. I will continue to try and find a CFI with a 7A, 6A or 9A and try it out. Thx C
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Lloyd, Daniel R.
Sent: Sunday, April 22, 2007 11:41 AM
Subject: RE: RV Advice, one leg flyer
Dan
N289DT
RV10E
Hello all,
[b]Carl W Bell[/b]
| Quote: | | href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-Listhref="http://forums.matronics.com">http://forums.matronics.com | 0123456789
Posted: Sun Apr 22, 2007 10:05 am Post subject: RV Advice, one leg flyer |
David,
I think you are right about a nose dragger and will continue to look for a CFI with one to figure it out. I did get an email from Alex from RV flight training and he has an RV 10 which may do the trick, but he is busy until June and in Texas, I’m in Aiken SC. I may just buy the tail and wings and make the final decision on the fuselage last so I can get building. I want to limit the mods to a set of handbrakes if possible, that way it will be a pretty standard plane. If it was a steer able nose wheel this would be a no brainier, I just don’t know about the castoring nose unit. I’m thinking I could also just put a welded hoop over the top of my foot for a push pull set up which would give me more speed then the dancing foot, but I think that may require a few pulleys and cable behind the pedals to make it a closed loop system. Any thoughts on this? Thanks for the advice. Carl
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of David Leonard
Sent: Sunday, April 22, 2007 12:10 PM
Carl,
Good luck,
David Leonard
Hello all,
[b]Carl W Bell[/b]
rleffler
Posted: Sun Apr 22, 2007 1:25 pm Post subject: RV Advice, one leg flyer |
Not sure what it would take to rig it, but check out a Liberty if you get a chance. It has finger brakes on the center console between the seats, one for each brake. That may solve your ground maneuvering a little easier. I suspect you could probably give them a call and explain your situation. They may be able to give you some pointers, or at least their supplier.
_________________ Bob Leffler
N410BL - Phase I
Posted: Sun Apr 22, 2007 8:49 pm Post subject: RV Advice, one leg flyer |
Carl,
The cable and pulleys to connect the pedals might work especially with a tri-gear, but consider this: The pull portion is going to be strenuous sometimes - even usually. You will need to be very securely buckled down or you will be pulling yourself forward. That will be too tight for cruise flight, so tightening yourself down before landing is another thing you have to remember. If you forget, your knee will hit the panel and all hell will break loose while you try to keep it on the runway. Also the pulley system will probably require that your foot be connected to the rudder for the entire flight (unless you come up with and easy in/out system). That will get very uncomfortable on long flights.
Plenty of 2 footed people do ground loops every year. You will be at an even higher risk.
So I still recommend the tri-gear unless you really want to live on the edge. Besides, its not like anyone is going old rule "only real men fly tail draggers" to you. Anyone who flies any plane with only one leg is man enough.
Either way, good luck.
David Leonard
On 4/22/07, Carl Bell <carlbell(at)gforcecable.com (carlbell(at)gforcecable.com)> wrote: | Quote: |
David,
.... If it was a steer able nose wheel this would be a no brainier, I just don't know about the castoring nose unit. I'm thinking I could also just put a welded hoop over the top of my foot for a push pull set up which would give me more speed then the dancing foot, but I think that may require a few pulleys and cable behind the pedals to make it a closed loop system. Any thoughts on this? Thanks for the advice. Carl
Posted: Mon Apr 23, 2007 6:28 am Post subject: RV Advice, one leg flyer |
Hi Carl-
Since you asked....
Obviously, a 7 or 8 will give you more room to make system mods than a 4,
or probably a 9.
I believe that you are correct, a TD will give you positive steering
control whereas a nose dragger will not.
If you are not already a conventional gear aviator, this may pose an
additional challenge, although I'm guessing additional challenges are a way
of life for you.
WRT rudder operation, I would take a hint from the serious acro world and
figure out a way to use bicycle racer's shoe locks, or whatever they are
properly called. These are fittings on the bottoms of the racer's shoes
that lock into mating fittings on the bicycle pedals. In the acro world,
this keeps the pilots feet on the rudders while doing hard acro. In your
case, it should allow you to push a rudder pedal with your prosthesis.
This should afford you the same rudder control ability as anyone else.
Assuming you have a full prosthetic foot, it would allow you to fly the
plane without modifications to the prosthesis.
There are aircraft in the world that use a bicycle-style hand brake lever
mounted on the control stick. With such an arrangement, you would operate
both brakes without having to do a major grip switch on landing, as opposed
to what would happen if you employed a Johnson bar type arrangement.
Another option would be to have a 'normal' master cylinder for the 'good
foot' operate both brakes.
In each of the above, there are potential issues with a lack of enough
mechanical advantage to afford adequate braking with the travel available,
but they are starting points.
For differential braking, there have been aircraft that were built with a
selector valve of sorts incorporated into the rudder control system and one
separate brake master cylinder. With such a system, to get right brake you
apply right rudder and then operate the brake lever. I'm sorry, at the
moment I can't think of which aircraft had that arrangement, but if you
like I could pester some geezers I know to see if they recall.
Yet another option is a locking tailwheel. I suspect you would find this
an inferior set up, but you could rig a TW lock to the control stick such
that when the stick is full aft against the stop, the TW is unlocked.
Moving the stick say, an inch fwd, would lock the TW for T/O and Ldg. Hard
against the stop would unlock it for tight ground maneuvering. This
configuration has also been used in the past.
Another option for brake power would be a separate lever on the throttle
side. This lever could operate both brakes as outlined above, or could
operate the left brake while your right foot operated the right brake. The
latter configuration could be cause for confusion and error when things
start happening quickly. Either arrangement would allow for full use of
the aerodynamic controls at the same time as the brake, but would mean
either brake or throttle, which is of course sub-optimal.
As I type this, it occurs to me that perhaps a system could be fashioned
that would incorporate a motorcycle or helicopter type twist grip on the
throttle lever for brake operation. Again, mechanical advantage would
likely be an issue. The corollary idea would be to have a throttle-looking
lever where pulling the lever aft powered the brakes and twisting the
locking grip operated the throttle. This could work well for you, but
would be a human factors trap for anyone else who flew in that seat.
A separate design goal might be that whatever you do, you do it such that
returning to a 'normal' configuration is relatively easy. This would pay
off should you decide to sell the aircraft.
Lastly, you might do a little research and find an aerobatic aircraft
and/or school equipped with the foot latches and give them a try.
glen matejcek
aerobubba(at)earthlink.net
khorton01(at)rogers.com Guest
Posted: Mon Apr 23, 2007 7:34 am Post subject: RV Advice, one leg flyer |
<aerobubba(at)earthlink.net>
with a
and one
brake you
the
you
British aircraft used this sort of system for many years in the
middle part of last century. But, most aircraft that I am aware of
that used this system had air operated power brakes, which solved the
mechanical advantage problem. If the rudder pedals were centred,
each brake would receive the same pressure. If the rudder pedals
were deflected a bit, one brake would get more pressure than the
other. If full rudder was applied, only that wheel would get brake
pressure. I did one flight in a Hawker Hunter with such a system.
It took some getting used to, but it did provide quite effective
control.
The DHC Chipmunk has a somewhat similar system. It has a long hand
brake lever which was operated by the pilot's left hand. The brake
pressure is distributed by a valve that is controlled by rudder
pressure, similar to the system described in the previous paragraph.
I've also got one flight in a Chipmunk, and it too appeared to be an
effective system, but it was a bit strange to taxi with, as it
doesn't have tail wheel steering - the tail wheel is free castoring.
To taxi, you pull on the hand brake to apply one or two clicks (it
works somewhat like the typical parking brake in European or Japanese
cars). You taxi with the brake partially applied - i.e. you taxi
while slightly dragging the brakes. This allows you to steer by
moving the rudder pedals, which controls where the brake pressure went.
Kevin Horton RV-8 (finishing kit)
Ottawa, Canada
http://www.kilohotel.com/rv8
Posted: Mon Apr 23, 2007 7:40 am Post subject: RV Advice, one leg flyer |
Hi Glen;
Thank you for all of your input; you have some really great ideas,
especially the bicycle shoe lock. I think I can make this a very simple
modification by using a cable and pulley in the middle of a RV 7 or 9 rudder
pedal setup that basically ties the rudder pedals together, and makes it a
closed loop system, and keeping things pretty standard. If there isn't room
going toward the firewall, I'll just put the pulley toward the spar. Then
I'm thinking I will omit the toe brakes on my side and weld a tube at
midpoint on the pedal for pushing and a hoop over the top of my foot for
pulling (or maybe the bicycle clip) and 2 hand brakes for stopping by using
them together or independently for differential braking. Do you think this
could do the trick? Most are saying I should go with a nose dragger and
preferably a 9A which almost lands itself. I hate to give up and occasional
roll or loop, but I really need the plane for X country to visit my kids
scattered about the US and of course I love flying and building things (RC).
I will draw this up and send it to Van with all the Caveats' just to make
sure that tying the pedals together won't create a problem with flutter or
something. Any thoughts on nose wheel versus tail wheel? Thanks again for
your advice. Regards Carl
Carl W Bell
n616tb(at)btsapps.com Guest
Posted: Mon Apr 23, 2007 7:56 am Post subject: RV Advice, one leg flyer |
You might consider a push-pull hand lever that is hydraulic operated. These
are quite common in sand rails for brake turning. Pull to go left and push
to go right. Simple to operate, simple to install, and does not need to
interfere with the standard foot brakes.
http://www.mooreparts.com/JAMCB1.html?zmam 626912&zmas=5&zmac &zmap=JAMCB
paste the link back together if it is on two lines.
They make these with two handles as well.
Good luck to you
[quote] --
Posted: Mon Apr 23, 2007 8:17 am Post subject: RV Advice, one leg flyer |
Tim,
Wow that's perfect, that will work well. I'll just use a standard locking
parking brake cylinder for both and of course for parking on the bottom of
the panel, aka Cherokee. Thanks, Carl
Posted: Mon Apr 23, 2007 8:41 am Post subject: RV Advice, one leg flyer |
Carl,
Now that I think about this, a dual handle control would be better. They
are two handles side by side that both pull either back or forward depending
on how you install it. I was originally thinking of space, but with two
handles you could pull them both back at once for regular braking. Still
easy to install, etc but about they are about an inch wider.
http://www.dansperformanceparts.com/buggy/tcbh/buggytcbh2.htm
two thirds of the way down the page.
[quote] --
Posted: Mon Apr 23, 2007 11:51 am Post subject: RV Advice, one leg flyer |
Tim,
I think you are right, I found those on the site from what you had
previously sent. Are many RV'ers using a parking brakes or just tie downs
and chocks? I feel pretty comfortable I can put a safe conversion in place
now, I may have to play with it a little, but this should be easier that
flying the Cherokee dancing between pedals and pulling the panel parking
brake. Thanks a lot. Which RV are you fling BTW. Carl
Posted: Mon Apr 23, 2007 1:00 pm Post subject: RV Advice, one leg flyer |
Hi Carl,
I have an RV-6. I agree it takes a lot more effort on the pedals (dancing)
to fly tail wheel. I have lots of tail wheel time and am comfortable, but
may build a nose wheel the next time. (RV-10 <bg>)
[quote] --
flyboy.bob(at)gmail.com Guest
Posted: Mon Apr 23, 2007 3:09 pm Post subject: RV Advice, one leg flyer |
Hi Carl,
I bought a RV8 project from a fellow in Galesburg, IL who has an
prosthetic leg . . . don't know if above or below the knee. He had
built an flew two other RV8s before this one with no modification that
I'm aware of.
I'll forward your email to him and hopefully he can help?
Bob Christensen
RV-8 - Finishing - N83RC
On 4/22/07, Carl Bell <carlbell(at)gforcecable.com> wrote:
Hello all,
Thanks Carl
Carl W Bell
lifeofreiley2003(at)yahoo Guest
Posted: Mon Apr 23, 2007 3:17 pm Post subject: RV Advice, one leg flyer |
I have a friend on the Taylor Airport, "Pegleg" as he
likes to be called, that has a dual lever brake system
on the RV-7A. I've flown with him and the system works
great!
Darrell
Hi Carl,
