nuckollsr(at)cox.net Guest
Posted: Mon Apr 23, 2007 8:26 am Post subject: PM ALTERNATOR SPIKE PROTECTION (NOT) |
At 10:50 AM 4/23/2007 +1000, you wrote:
<peterjfharris(at)bigpond.com>
Ken thanks for the lead to Bob's advice on spike protection. Re your
comments about the use of a capacitor is this connected across the two AC
output leads from the stator?
I have been told to just fit a diode from the regulator output to B+ for
spike protection but this would not enable isolation of battery from
regulator?
Peter
The capacitor is not for "spike protection". The single phase
PM alternators are exceedingly noisy without at least a battery
on line and the noise can be further reduced by addition of
a capacitor. Further, if you'd like for your SD-8 or similar
alternator to come up self-excited and run well without a battery,
you'd be well advised to install at least the 22,000 uF capacitor
and the resistors described in Figure Z-25 Revision L on page
27 of . . .
http://www.aeroelectric.com/articles/Rev11/AppZ_R11J.pdf
It would be pretty cool if we could eliminate the word
"spike" from the vernacular of speaking of airplane
electrical systems. The word has morphed into a dozen
different meanings on the part of some speakers . . .
and most are regarded as evil. The word is then picked
up by the neophyte student of electrical systems and
whacked about like a shuttlecock in a badminton game
with each speaker believing that he's speaking with some
level of understanding and each speaker having a different
vision of what's being discussed. Sounds like Congress!
The ONLY instance where our electrical systems are
likely to experience a true "spike" (see definition
in chapter on over voltage) is during the opening
of coil on a relay or contactor. The spike CAN be
exceedingly spectacular. See:
http://www.aeroelectric.com/Pictures/Curves/Cole-Hersee_without_Diode.gif
but (1) even if ignored, the ONLY potential victim
of such spikes is the SWITCH THAT CONTROLS the relay
or contactor. The spike DOES NOT propagate out onto
the system. Even if it did, it's of such low energy
content that a .10 uF capacitor across the bus or the
+14v input to an appliance would wash it completely. See:
http://www.aeroelectric.com/Pictures/Curves/CH_Bus_Noise_w_0p1_Cap.gif
(2) by adding the diode or other spike suppression
process, we can give the controlling switch some
relief that results in a longer service life for
the switch. See:
http://www.aeroelectric.com/Pictures/Curves/CH_w_1n5400.gif
http://www.aeroelectric.com/Pictures/Curves/CH_w_2x18v_Transorbs.gif
http://www.aeroelectric.com/Pictures/Curves/CH_w_120_Ohm.gif
ALL OTHER FORMS of bus voltage perturbation come
from instabilities of one kind or another in the
alternator system and are not properly called
"spikes." Regulator stability problems manifest
themselves as small "surges" or "dynamic instabilities
excited by transient loads". These are low energy,
non threatening things as well. The guy we need to
take note of is the "over-voltage" condition promulgated
by the uncontrolled, full-bore output of the engine
driven power source that pushes bus voltage toward
the moon until it's brought under control by some
means crafted for that purpose.
Know that the capacitor in a PM alternator system
is just there for smoothing the considerable ripple
voltage that exists on a full wave, single phase rectified
power output typical of the SD-8. I did some comparative
noise studies on an SD-8 some years ago and compiled this data:
http://www.aeroelectric.com/Pictures/Curves/SD-8_Noise_Data.pdf
Note that with a 10KuF cap (of unknown quality)
the noise under most conditions was under 700 mv pk-pk
except when the battery was disconnected on page
5. Further tests with a brand new 47KuF capacitor
brought the noise levels down nicely even with a
battery off line as shown on page 7.
Yeah, I know those traces look kinda "spikey" but
let's not speak of them in that matter. The voltages
plotted are the normal and expected performance
characteristics of the system under study and none
of the traces should cause an sense of evil or
foreboding that seems to bubble up every time folks
start worrying about "spikes".
A few months ago we studied and solved the problem
of getting the SD-8 to come up self-excited. This
is where the resistors and rectifier were added to
Z-25. At some later time and under a different
discussion topic, we considered moving the control
relay to the AC side of the PM alternator's regulator
as shown on the current revision of Z-16. However,
this is a case of not having your cake and eating
it too. Moving the control relay to the AC side of
the regulator kills our ability to come alive self
excited.
We'll have to throw the pot back on the stove to
see if we can achieve both qualities from a single
architecture.
Peter H
Posted: Mon Apr 23, 2007 3:13 pm Post subject: PM ALTERNATOR SPIKE PROTECTION (NOT) |
Bob I got a spike which destroyed my electronic ignition module when my
alternator CB popped. I was running a half baked circuit with no proper
protection, hence my journey into your excellent and informative Appendix Z.
I have ordered the OVM and now digging deeper.
Can you recommend a regulator rectifier for the Jabiru, one that can be
started like Z25 without a battery?
Peter H
jmfpublic(at)comcast.net Guest
Posted: Tue Apr 24, 2007 12:59 pm Post subject: PM ALTERNATOR SPIKE PROTECTION (NOT) |
Bob,
excited.
architecture.
Here is a possible entry for the pot. Design so that the relay and the S1 controlling switch get power either from the battery or the same bridge circuit of Z25. A diode would be placed in series from the main battery bus to the fuselink, and the output from the diode bridge would also be fed by a series diode to the upstream (bus) side of the circuit breaker. Diodes would need to be in the 100 to 200 volts range, but that is not difficult. If smaller breakers than 5 amps are available that would be better, too.
A more elegant solution would use a thyristor triggered by a pulse from the overvoltage module, but I haven't tried to draw that one. This is looking like a job for a small printed circuit board again.
Jim Foerster, J400 slowly wiring
