jconnell(at)rconnect.com Guest
Posted: Thu Apr 26, 2007 10:53 am Post subject: Engine wiring anchor points |
Guys,
I'm in the process of routing wires to the starter, alternator, CHT, and EGT probes.
Is anyone using the induction tubes from the sump for a clamp and standoff for the
wires? Also, how about using the sump-to-crankcase attach bolts for cable clamp
attachments?
Thanks...
Joe Connell
RV-9A and O-320
Dale Ensing
Joined: 11 Jan 2006 Posts: 571 Location: Aero Plantation Weddington NC
Posted: Thu Apr 26, 2007 11:46 am Post subject: Engine wiring anchor points |
I fabricated a clamp arrangement on the induction tube for the alternator wire.
I found a large rubber sleeve about 2 in long; about a 1/4 in wall thickness and with stainless steel clamps at Home Depot. The rubber sleeve was slit open from end to end and then trimmed so that the new ID fit the OD of the induction tube. A hole was drilled in a SS screw clamp to allow for a pan head screw that would become the mounting screw for a cushioned clamp which holds the alt. wire. The SS screw clamp is around the rubber sleeve on the induction tube. Now have 150 hours and it has worked well.
Note: The CHT and EGT wires need to be at least 2 inches from any high current wires. The voltage in these wire is so small that the magnetic field around the high current wire, such as the alternator wire, will produce very erratic readings.
Dale Ensing
_________________ Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
Mark Phillips in TN
Joined: 10 Jan 2006 Posts: 431 Location: Columbia, TN
Posted: Thu Apr 26, 2007 5:59 pm Post subject: Engine wiring anchor points |
In a message dated 4/26/2007 1:54:25 PM Central Daylight Time, jconnell(at)rconnect.com writes:
| Quote: | Is anyone using the induction tubes from the sump for a clamp and standoff for the
attachments?
I used the induction tubes on my plane for attaching CHT/EGT cables- large black ty-rap around the rubber tube-to-sump hose with a small ty-rap between it and the cables with no signs of degradation or loosening- I "believe" the black ones are preferable in the engine environment to the natural nylon. They are touted as "weatherable" and "weather" this means UV resistant or what, I'm not sure, but they have worked well for me. It is standard practice to use sump bolts as attach points for adel (cushion) clamps...
Mark RV-6A "Mojo" 400+ hrs...
See what's free at AOL.com.
_________________ From The PossumWorks... |
