Peter H
Posted: Sun Apr 22, 2007 10:39 pm Post subject: PM ALTERNATOR- REGULATOR CHOICE |
Ken apologies I should have read the Z files first. I have a condenser
connected that way as in Z16. I think I need a different regulator that does
not need excitation from the battery. Bob Nucholls refers to the generic
Ford type regulator, do you know if this is OK for the PM alternator
application?
Peter
klehman(at)albedo.net Guest
Posted: Mon Apr 23, 2007 4:56 am Post subject: PM ALTERNATOR- REGULATOR CHOICE |
Peter
I'm not sure why you want a regulator that will start up without a
battery? It sounds like you do have a battery present. Do you know for
sure that your regulator will not start without a battery present?
No the Ford regulators will not work with a PM alternator. THey are for
wound field alternators. Wound field alternators have a field connection
and circuit breaker that supples current to the field winding. No such
thing with a PM alternator as the field magnetism is provided by
Permanent Magnets.
If you intend to use the B&C over voltage module with a PM alternator
you do need a disconnect relay for the module so the module can
disconnect the alternator. I use a $3. automotive relay to break an AC
line from the alternator to the regulator/rectifier. A diode or
transorb is incapable of protecting your system from a runaway regulator
so you need the relay if that is a concern. Arguably a transorb might
provide some protection from a momentary spike but we have no real
evidence to support the existance of such momentary spikes.
Don't get overly concerned about your momentary16 DC volt measurement.
Your bad connection could explain everything. I am pretty confident
that it was not caused by a misbehaving regulator. I use over voltage
protection because I run electronic fuel injection and ignition and it
is not difficult or expensive to add. Some guys use it because they have
expensive avionics or just because they want to. Some guys don't feel
the need for it. The AC volatage will normally be well above 14 volts
at all times so that is normal.
Ken
Peter Harris wrote:
application?
Peter
nuckollsr(at)cox.net Guest
Posted: Mon Apr 23, 2007 7:31 am Post subject: PM ALTERNATOR- REGULATOR CHOICE |
At 08:52 AM 4/23/2007 -0400, you wrote:
Peter
Why would one NOT want an alternator that will run
without a battery. Generators did this from day-one
and we had to give that feature up when generators got
replaced by alternators in the 60's.
Alternators on the Bonanza and Barons have self excited
for decades and the company touts this as a desirable
feature. A few months ago we did an exercise to figure
out how to make an SD-8 come up without assistance from
a battery.
This is generally considered a good thing to do and it
can be done.
( IF one aspires to be "world class", )
( what ever you do must be exercised )
( EVERY day . . . )
( R. L. Nuckolls III )
Posted: Mon Apr 23, 2007 7:33 am Post subject: PM ALTERNATOR- REGULATOR CHOICE |
At 04:35 PM 4/23/2007 +1000, you wrote:
<peterjfharris(at)bigpond.com>
application?
Read the archives and check out Z-25. This pot was stirred
several months ago.
Peter H
Posted: Mon Apr 23, 2007 1:52 pm Post subject: PM ALTERNATOR- REGULATOR CHOICE |
Thanks Ken.
I am interested in the possibility of using the alternator as a dual source
for power supply as shown in page Z11 (if I read it correctly) . Basically
two diodes back to back , alternator feed one side, battery feed the other
side and dual source power out from the centre tap. I am preparing to
install EFI in a Jabiru J3300. I will need to study how to load the
alternator when the battery is off line. I have ordered the OVM crowbar and
now sourced an alternator relay, but also need to find the right regulator
for the job. The Jab regulator will not work if the battery is disconnected.
The question about running the PM alternator with battery off line is
covered on page Z 10 note 20 which warns that some regulators will not start
without battery connected.
Still learning and thanks for the insight.
Peter
Gilles.Thesee(at)ac-greno Guest
Posted: Mon Apr 23, 2007 2:03 pm Post subject: PM ALTERNATOR- REGULATOR CHOICE |
Peter Harris a écrit :
| Quote: | but also need to find the right regulator
Peter,
Have you considered the Schicke GR6 ?
http://www.schicke-electronic.de/dgr3tech.htm
Same as the GR4 I installed some years ago, but with better heat
rejection capability.
We bench tested it, and it starts to life even with no voltage applied
to the sense wire. I did not test it with no load at all. There was
always a battery or capacitor to load it.
Gilles
http://contrails.free.fr
Peter H
Posted: Mon Apr 23, 2007 2:35 pm Post subject: Re: PM ALTERNATOR- REGULATOR CHOICE |
Thanks Bob I have now a better understanding of Z25, and Gilles. I am a bit handicapped for the Schicke as I am based here in Queensland OZ and do not speak German but I will keep it in mind and it is good to get a first hand recommendation.
I will be pleased to find another alternative recommendation.
Thanks I appreciate the good advice on this list
Peter
Posted: Tue Apr 24, 2007 4:45 am Post subject: PM ALTERNATOR- REGULATOR CHOICE |
To his credit, Peter has been asking lots of questions and I was trying
to understand whether it was worth his effort to change parts and insure
self excitation. For my Z-14 system, it doesn't matter to me whether
either alternator will self excite. If I don't like how the engine is
running, my procedure is to just switch to the second EFI system, which
runs on the other battery and alternator.
Self excitation is fine but I would encourage a bit of testing before
counting on continued operation without a battery. Especially with a
regulator that was not designed to perform without a battery. Now that
Peter's has described what he is trying to do, I agree that self
excitation or a second battery is essential for him. However self
excitation might not help much if someone inadvertantly stalled the
alternator and had a geared prop that promptly stopped turning. Self
excitation might not be as comforting if Peter's EFI Jabiru doesn't
windmill fast enough to restart his engine. For example he might want
to insure that with his system it is not possible to inadvertantly (out
of habit) turn on something like a landing light and stall the
alternator... His "dual" power source should probably be strictly for
feeding the engine. My PM alternator doesn't put out much current at
idle rpm.
Ken
Robert L. Nuckolls, III wrote:
<nuckollsr(at)cox.net>
> Peter
> for sure that your regulator will not start without a battery present?
a battery.
can be done.
Peter H
Posted: Wed Apr 25, 2007 2:09 am Post subject: PM ALTERNATOR- REGULATOR CHOICE |
Ken,
I will need about 4A to run the EFI. Ignition is dual by one magneto and one
electronic ignition module . It will be OK by me if I can cover the EFI
only. But how much current would stall the alternator and stop the engine?
Peter
Posted: Wed Apr 25, 2007 5:57 pm Post subject: PM ALTERNATOR- REGULATOR CHOICE |
Peter
Stall is perhaps not the best term for me to have used. I would think
that the best plan then would be that your alternator should be able to
supply at least 4 amps at idle in case you pull power back to idle. What
you want to avoid is any possible combination of rpm and electrical load
that could pull the voltage below what your EFI system needs to keep
running. Many automotive systems will run down to about 8 volts or they
would not be able to start the car with a weak battery. They typically
lengthen the injection pulse at low voltage to compensate for more
sluggish injector operation. I don't know how many amps the Jabiru
alternator will put out at idle but I'd guess that your plan will work
if the alternator is only powering the EFI. Definitely worth a try I
think! If it doesn't work you can always try adding a small battery.
There have been some interesting alternatives used over the years such
as gravity fed fuel to a port or nozzle that can meter enough fuel in to
keep you airborne. One then used the throttle as a mixture control.
Similarly there have been cases where someone made it to the airport
with the priming pump after their carburetor quit supplying fuel. I've
also heard that such schemes often caused more troubles than they saved ;(
Ken
Peter Harris wrote:
Ken,
Peter
Peter H
Posted: Wed Apr 25, 2007 7:47 pm Post subject: PM ALTERNATOR- REGULATOR CHOICE |
Thanks Ken. I was thinking of using a carb as the throttle body but have
since inspected the Aerocarb and found it unsuitable. There are other
possibilities, I am still cooking but most result in a compromise of some
kind.
Thanks for the input.
Peter
