nuckollsr(at)cox.net Guest
Posted: Fri May 04, 2007 6:18 am Post subject: Rear-Battery version of Z-19 |
At the request of several builders, I've posted a rear-battery
version of Z-19 at:
http://aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z19RB_A_1.pdf
http://aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z19RB_A_2.pdf
The major differences between the front and rear-battery versions
is moving main bus feed from battery contactor to starter contactor.
Adding e-bus alternate feed relay to the main battery bus.
If you have an internally regulated alternator that is not a Plane
Power (built in OVP and absolute pilot control) then install the
interim Z-24 as described below. Later this year, you'll already
have hardware in place to upgrade the OVP/Control system shown
in.
http://aeroelectric.com/articles/Adapting_IR_Alternators_to_Aircraft.pdf
( IF one aspires to be "world class", )
( what ever you do must be exercised )
( EVERY day . . . )
( R. L. Nuckolls III )
n707sm
Posted: Tue Jun 12, 2007 11:36 am Post subject: Re: Rear-Battery version of Z-19 |
Hi Bob,
Thank you for all you do to support the Experimental community and especially for your time and effort spent to create Architecture drawings such as the new Z-19/RB!
I am implementing this architecture in my Eggenfellner powered RV-7A and I have a few questions:
1) For each battery (minus) it's shown to connect locally to the airframe. Providing that good, secure connections with 4AWG (or welding cable) are done locally, does this negate the need to run heavy (2AWG or 4AWG) ground cabling forward?
2) Relates to question 1. If it's necessary to run ground cabling forward, is it acceptable/reasonable to instead: a) Connect the battery minus posts with a single, short welding cable, and b) Connect another single short welding cable for local ground, and c) continue with a single large (2AWG or 4AWG) cable forward to connect to the Brass Firewall Thru Bolt for the Firewall, Panel and downstream Avionics ground busses? (This seems overdone, redundant and heavy to me, but I just want to be sure I haven't missed something here)
3) I have located all of the components for this architecture drawing with the exception of the E-BUS ALT FEED RELAY. Would you mind please providing a suggested supplier/part for this component?
Thank you again!
Very best regards,
Michael O'Brien
Posted: Tue Jun 12, 2007 2:01 pm Post subject: Rear-Battery version of Z-19 |
At 12:37 PM 6/12/2007 -0700, you wrote:
Quote: |
Hi Bob,
Yes.
Quote: | 2) Relates to question 1. If it's necessary to run ground cabling
There's a boatload of ol' mechanic's tales out there about
the hazards of local grounds in aircraft. Aside from the obvious
and predictable issues involving ground loops (when particularly
vulnerable systems share grounds spread out over the airframe),
there are no great concerns for using the airframe as a primary
ground structure. There's some value in considering the used of
a separate ground wire for tubular structures where we've see
some instances of structure getting magnetized due to high current
flow . . . but that doesn't apply to you.
Quote: | 3) I have located all of the components for this architecture drawing with
Any sealed plastic power relay in the 20+ amp class is fine.
B&C sells their S704-1. This product from Radio Shack
http://tinyurl.com/2sno9m
is fine too.
My pleasure sir.
n707sm
Posted: Mon Jun 18, 2007 9:26 am Post subject: Re: Rear-Battery version of Z-19 |
Hi Bob,
In Z-19/RB, it's called out to use 6" or less 12AWG between the Main and Engine Battery contactors and their respective busses. Without building a special mount for this, I could locate these busses close to the contactors but I would probably need about 15" of wire each. Would your suggestion be to go to 10AWG in this case?
Thank you again
Best Regards,
Michael
Posted: Mon Jun 18, 2007 6:14 pm Post subject: Rear-Battery version of Z-19 |
At 10:26 AM 6/18/2007 -0700, you wrote:
Quote: |
Hi Bob,
That's not necessary. 12AWG is good for 15+ amps. I doubt that
you're going to have battery bus totals that exceed that
value!
That 6" "rule" is a real loose thing. Obviously a well
installed wire that's a bit longer isn't going to present
that much increase in crash safety hazard.
