johnd(at)data-tech.com Guest
Posted: Fri May 11, 2007 6:35 am Post subject: Brass or Stainless Safety Wire |
Should Brass or Stainless safety wire be used on my 601XL? I've looked
in AC43-13 and only found an a bit about using Brass for safetying
certain emergency type items that may need to be removed.
It seems like I've seen stainless in the 172 I've been renting so I
assume that would be fine ?
John Davis
Burnsville, NC
601 XL QB/Jabiru ?
MaxNr(at)aol.com Guest
Posted: Fri May 11, 2007 8:28 am Post subject: Brass or Stainless Safety Wire |
I am not an A&P, just a pilot (retired). This is what I have seen on military and commercial aircraft: Stainless is used on hardware to prevent movement or backing off. I have seen brass used only on things that need to be secured but can be broken if you're a little scared. Such things as door jettison handles, the knob that you pull to "blow down" the landing gear, the guard that covers a switch that is used to jettison something in flight. Also, its used to prevent the safety pin on hand held aircraft fire extinguishers from falling out. I agree that AC 43.13 should not be so vague on this issue. Good luck.
Bob Dingley
Pace,FL
XL/Lyc
See what's free at http://www.aol.com. [quote][b]
klr12(at)psu.edu Guest
Posted: Fri May 11, 2007 9:01 am Post subject: Brass or Stainless Safety Wire |
I am an A&P. Use stainless.
K. Rupert
