nuckollsr(at)cox.net Guest
Posted: Thu May 10, 2007 8:10 pm Post subject: SPDT momentary push-button switch (comm flip-flop) |
At 08:44 AM 5/10/2007 -0700, you wrote:
Quote: |
At 07:50 5/10/2007, you wrote:
>I did touching the wire to ground and the frequency toggled ONCE. It was
>necessary to then touch this wire to aircraft power to get it to toggle
>a second time.
>Bill
I don't have the 155 service/installation manual, but looking at the SM
for the 155A there are some internal pull-up provisions for the external
switch.
A momentary to ground should be all that is required.
By means of whatever type switch you choose to use.
Perhaps there is some issue within your 155?
Aha! good data sir. How big are the resistors and to
what voltage do they pull up? The snipit from the
install manual suggests that pulling to ground is
the expected resting condition with the lead being
pulled up to +14 to effect a "flip".
If the radio has internal pull-ups, then a NORMALLY
CLOSED push button would be expected to provide the
necessary function but without a need for external
resistor. A Grayhill 30-6 illustrated at:
http://embrace.grayhill.com/embrace/IMAGES/PDF/E-17-20.pdf
and available from digikey at:
http://tinyurl.com/2nqymz
for about $2.65 should do the job.
Looks like you have a little bit of homework to do
Bill but I'm 90% certain that you can make a single-throw,
two-wire push button do this job.
I'm going to take the sketch referenced in the
earlier post down from the website. Given Ron's
new information, I'm not sure we want the signal
lead to "rest" in the low state.
wgill10(at)comcast.net Guest
Posted: Fri May 11, 2007 2:49 am Post subject: SPDT momentary push-button switch (comm flip-flop) |
Hello Bob,
Thank you for the reply. I understand connecting a normally closed SPST
switch to 14V, but how does opening that circuit cause a toggle when the
radio is expecting a ground once the 14V is removed?
